    2. English
    3. Development
    4. VW Connect adapter not able to login
    • peltsi515
      peltsi515 last edited by
      Today the IObroker VW Connect adapter didn't first update the values from the server and after reloading the adapter the adapter cannot connect to VW server anymore. Anyone else having this kind of problems?
      Tried rebooting the IObroker with rebooting the whole computer. Didn't work.
      Car ID3
      VW connect adapter version 0.0.30
      Platform Windows
      Architecture ia32
      CPUs 4
      Speed 1797 MHz
      Model Intel(R) Atom(TM) CPU Z2760 @ 1.80GHz
      RAM 1.96 GB
      Node.js
      v10.17.0
        Thomas Braun Most Active @peltsi515 last edited by
        @peltsi515 sagte in VW Connect adapter not able to login:
        Node.js
        v10.17.0
        Update to node12 or node14
        peltsi515 BananaJoe 2 Replies Last reply Reply Quote 0
        • peltsi515
          peltsi515 @Thomas Braun last edited by
          @thomas-braun Thanks for the fast answer.
          Do you think that this could be the cause, because it has worked about three weeks perfectly with this version.
          Other question is that how you update the node.js version in windows install?
          Thomas Braun V 2 Replies Last reply Reply Quote 0
            @peltsi515 I'm running Linux, no idea about Windows.
            node10 will reach its End Of Live in a few weeks, so it is time to upgrade anyway.
            peltsi515 1 Reply Last reply Reply Quote 0
            • peltsi515
              I got the node.js updated and the IObroker controller also. No help there. The connection to VW server is still out. The We Connect ID app is working so the VW server should be ok.
              Anyone able to help?
              • Glasfaser
                Glasfaser @peltsi515 last edited by Glasfaser
                ioBroker Log from Adapter ?
                is a 401 .. 503 in your Log or ?????
                • peltsi515
                  peltsi515 @Glasfaser last edited by peltsi515
                  @glasfaser The login information (username and password, etc.) are correct I have checked those.
                  2021-03-28 22:36:56.308 - error: vw-connect.0 (5176) Login was not successful, please check your login credentials and selected type
                  2021-03-28 22:36:56.310 - error: vw-connect.0 (5176) TypeError: Cannot read property 'split' of undefined
                  2021-03-28 22:36:56.346 - error: vw-connect.0 (5176) TypeError: Cannot read property 'split' of undefined
                  at Request._callback (C:\Program Files\PeltolaIObroker\node_modules\iobroker.vw-connect\main.js:469:105)
                  at Request.self.callback (C:\Program Files\PeltolaIObroker\node_modules\iobroker.vw-connect\node_modules\request\request.js:185:22)
                  at Request.emit (events.js:315:20)
                  at Request.EventEmitter.emit (domain.js:467:12)
                  at Request. (C:\Program Files\PeltolaIObroker\node_modules\iobroker.vw-connect\node_modules\request\request.js:1154:10)
                  at IncomingMessage. (C:\Program Files\PeltolaIObroker\node_modules\iobroker.vw-connect\node_modules\request\request.js:1076:12)
                  at Object.onceWrapper (events.js:421:28)
                  at IncomingMessage.emit (events.js:327:22)
                  2021-03-28 22:36:56.350 - error: vw-connect.0 (5176) Login Failed
                  mrbungle64 1 Reply Last reply Reply Quote 0
                  • BananaJoe
                    BananaJoe Most Active @Thomas Braun last edited by
                    @thomas-braun sagte in VW Connect adapter not able to login:
                    Node.js
                    v10.17.0
                    @peltsi515
                    I would use v12
                    With v14 the Connector did not run in my enviroment
                    • mrbungle64
                      mrbungle64 Developer @peltsi515 last edited by
                      @peltsi515 said in VW Connect adapter not able to login:
                      You have to visit the Volkswagen portal and agree to the privacy policy.
                      • peltsi515
                        peltsi515 @mrbungle64 last edited by
                        @mrbungle64 Yes. Like I said the connection/adapter have worked for three weeks perfectly.
                        mrbungle64 Glasfaser 2 Replies Last reply Reply Quote 0
                        • mrbungle64
                          Sounds weird but you have to do it again 😉
                          • Glasfaser
                            @peltsi515
                            Have you create a new Account !?
                            Passwort / User not per Drag and Drop !
                            • peltsi515
                              @mrbungle64 No way. It worked. You really had to agree to them again. Thank you very much for your help!
                              • V
                                volker-gi @peltsi515 last edited by
                                @peltsi515 Hello, i also have no Connection to the WeConnect Adapter. he had yellow state since one Week. Before the function was ok. I was on the VW Connect site and the Access is OK. Only the Adapter has no function. I delete and reinstalled it with User and password. When i start it, it goes now directly to red state. Any idea?
                                • Glasfaser
                                  Glasfaser @volker-gi last edited by
                                  @volker-gi sagte in VW Connect adapter not able to login:
                                  Do you have a log from the start of the adapter
                                  adapter windows
                                  2667
