    4. Fehler im Log
    Fehler im Log
      simpixo last edited by
      Hallo zusammen
      Seit neustem habe ich den folgenden Fehler im Log, kann mir jemand sagen woher dieser kommt oder hat gar eine Lösung?
      TypeError:	2017-01-09 20:03:00.724	error	at Decoder. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
      TypeError:	2017-01-09 20:03:00.724	error	at Manager.ondecoded (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:332:8)
      TypeError:	2017-01-09 20:03:00.724	error	at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
      TypeError:	2017-01-09 20:03:00.724	error	at Manager. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
      TypeError:	2017-01-09 20:03:00.724	error	at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:228:12)
      TypeError:	2017-01-09 20:03:00.724	error	at Socket.onevent (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:270:10)
      TypeError:	2017-01-09 20:03:00.724	error	at Socket.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
      TypeError:	2017-01-09 20:03:00.724	error	at Socket. (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInMemClient.js:45:30)
      TypeError:	2017-01-09 20:03:00.724	error	at Object.that.states.States.change (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:2187:71)
      TypeError:	2017-01-09 20:03:00.724	error	at Object.cb (script.js.Stromzähler.Ermittelt_Einzelne_Werte:207:50)
      TypeError:	2017-01-09 20:03:00.724	error	Cannot read property 'val' of undefined
      message	2017-01-09 20:03:00.724	error	messagebox.system.adapter.javascript.0 [object Object] Cannot read property 'val' of undefined
      TypeError:	2017-01-09 20:03:00.714	error	at Decoder. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
      TypeError:	2017-01-09 20:03:00.714	error	at Manager.ondecoded (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:332:8)
      TypeError:	2017-01-09 20:03:00.714	error	at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
      TypeError:	2017-01-09 20:03:00.714	error	at Manager. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
      TypeError:	2017-01-09 20:03:00.714	error	at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:228:12)
      TypeError:	2017-01-09 20:03:00.714	error	at Socket.onevent (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:270:10)
      TypeError:	2017-01-09 20:03:00.714	error	at Socket.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
      TypeError:	2017-01-09 20:03:00.714	error	at Socket. (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInMemClient.js:45:30)
      TypeError:	2017-01-09 20:03:00.714	error	at Object.that.states.States.change (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:2187:71)
      TypeError:	2017-01-09 20:03:00.714	error	at Object.cb (script.js.Stromzähler.Ermittelt_Einzelne_Werte:207:50)
      TypeError:	2017-01-09 20:03:00.714	error	Cannot read property 'val' of undefined
      message	2017-01-09 20:03:00.713	error	messagebox.system.adapter.javascript.0 [object Object] Cannot read property 'val' of undefined
      • wendy2702
        wendy2702 last edited by
        bin jetzt kein Script guru aber aus meiner sich verweist dein Log auf einen Fehler in einem Script:
        Das Script "Stromzähler.Ermittelt_Einzelne_Werte" solltest du vielleicht auch mal posten.
        81.0k
