    2. English
    3. Scripting / Logic
    5. Pause script for x time
      Tomiol80 last edited by
      Hi
      Any advice how I can pause script for 720 minutes? Now if I press light button my lights turn on again immediately.
      BR,
      -Tomi-
      • Asgothian
        Asgothian Developer @Tomiol80 last edited by
        @tomiol80
        you want to:
        • define a variable "block_script"
        • set the variable to "false" before the trigger
        • your "if actual time is between" you want to extend with a logic block so that the condition reads "if actual time is between 15:00 and 23:00 and block_script = false
        • inside the trigger where you have the pause, you want to set it the variable to true
        • then start a timeout for 720 minutes. Inside the timeout, set the variable to false.
        A.
          Tomiol80 @Asgothian last edited by
          @asgothian
          Ok. Thank you very much.
          I think I got it right now.
