    4. js-controller läuft nicht mehr nach Update ioBroker
      Bj 0 last edited by wendy2702
      Habe heute auf die neusten Versionen upgedatet und javascript.0 steht immer auf rot. Alles andere läuft, ioBroker fix, Neuinstallation js usw. ausgeführt ohne Erfolg.
      Folgendes steht im Log:
      host.raspberrypi	2021-04-03 00:33:54.826	error	instance system.adapter.javascript.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      host.raspberrypi	2021-04-03 00:33:54.826	error	Caught by controller[0]: }
      host.raspberrypi	2021-04-03 00:33:54.826	error	Caught by controller[0]: ]
      host.raspberrypi	2021-04-03 00:33:54.825	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.javascript/main.js'
      host.raspberrypi	2021-04-03 00:33:54.825	error	Caught by controller[0]: '/opt/iobroker/node_modules/virtual-tsc/build/index.js',
      host.raspberrypi	2021-04-03 00:33:54.825	error	Caught by controller[0]: '/opt/iobroker/node_modules/virtual-tsc/build/server.js',
      host.raspberrypi	2021-04-03 00:33:54.825	error	Caught by controller[0]: requireStack: [
      host.raspberrypi	2021-04-03 00:33:54.825	error	Caught by controller[0]: code: 'MODULE_NOT_FOUND',
      host.raspberrypi	2021-04-03 00:33:54.824	error	Caught by controller[0]: {
      host.raspberrypi	2021-04-03 00:33:54.824	error	Caught by controller[0]: at internal/main/run_main_module.js:17:47
      host.raspberrypi	2021-04-03 00:33:54.824	error	Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:60:12)
      host.raspberrypi	2021-04-03 00:33:54.824	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:708:14)
      host.raspberrypi	2021-04-03 00:33:54.824	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:863:32)
      host.raspberrypi	2021-04-03 00:33:54.823	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1027:10)
      host.raspberrypi	2021-04-03 00:33:54.823	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:999:30)
      host.raspberrypi	2021-04-03 00:33:54.823	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/main.js:35:24)
      host.raspberrypi	2021-04-03 00:33:54.823	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:74:18)
      host.raspberrypi	2021-04-03 00:33:54.822	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:887:19)
      host.raspberrypi	2021-04-03 00:33:54.822	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:708:14)
      host.raspberrypi	2021-04-03 00:33:54.822	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:863:32)
      host.raspberrypi	2021-04-03 00:33:54.822	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1027:10)
      host.raspberrypi	2021-04-03 00:33:54.821	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:999:30)
      host.raspberrypi	2021-04-03 00:33:54.821	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/virtual-tsc/build/index.js:8:16)
      host.raspberrypi	2021-04-03 00:33:54.821	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:74:18)
      host.raspberrypi	2021-04-03 00:33:54.821	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:887:19)
      host.raspberrypi	2021-04-03 00:33:54.821	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:708:14)
      host.raspberrypi	2021-04-03 00:33:54.820	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:863:32)
      host.raspberrypi	2021-04-03 00:33:54.820	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1027:10)
      host.raspberrypi	2021-04-03 00:33:54.820	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:999:30)
      host.raspberrypi	2021-04-03 00:33:54.820	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/virtual-tsc/build/server.js:4:10)
      host.raspberrypi	2021-04-03 00:33:54.819	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:74:18)
      host.raspberrypi	2021-04-03 00:33:54.819	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:887:19)
      host.raspberrypi	2021-04-03 00:33:54.819	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:667:27)
      host.raspberrypi	2021-04-03 00:33:54.819	error	Caught by controller[0]: at Function.Module._resolveFilename (internal/modules/cjs/loader.js:815:15)
      host.raspberrypi	2021-04-03 00:33:54.819	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.javascript/main.js
      host.raspberrypi	2021-04-03 00:33:54.818	error	Caught by controller[0]: - /opt/iobroker/node_modules/virtual-tsc/build/index.js
      host.raspberrypi	2021-04-03 00:33:54.818	error	Caught by controller[0]: - /opt/iobroker/node_modules/virtual-tsc/build/server.js
      host.raspberrypi	2021-04-03 00:33:54.818	error	Caught by controller[0]: Require stack:
      host.raspberrypi	2021-04-03 00:33:54.818	error	Caught by controller[0]: Error: Cannot find module 'typescript'
      host.raspberrypi	2021-04-03 00:33:54.817	error	Caught by controller[0]: ^
      host.raspberrypi	2021-04-03 00:33:54.817	error	Caught by controller[0]: throw err;
      host.raspberrypi	2021-04-03 00:33:54.816	error	Caught by controller[0]: internal/modules/cjs/loader.js:818
      host.raspberrypi	2021-04-03 00:33:54.412	info	instance system.adapter.javascript.0 started with pid 4402
      host.raspberrypi	2021-04-02 23:33:24.376	info	Restart adapter system.adapter.javascript.0 because enabled
      Hat jemand eine Lösung?
      MOD EDIT: LOG IN CODE TAGS </> GESETZT
      Thomas Braun crunchip 2 Replies Last reply Reply Quote 0
        Thomas Braun Most Active @Bj 0 last edited by
        @bj-0
        Bitte den Text in CodeTags packen.
        • crunchip
          crunchip Forum Testing Most Active @Bj 0 last edited by
          @bj-0 sagte in js-controller läuft nicht mehr nach Update ioBroker:
          die da wären?
          B 2 Replies Last reply Reply Quote 0
            Bj 0 @crunchip last edited by
            @crunchip sagte in js-controller läuft nicht mehr nach Update ioBroker:
            die da wären?
            auf diese Versionen:
            Node.js: v12.22.0
            NPM: 6.14.11
              Bj 0 @Thomas Braun last edited by
              Ich bin neu hier. Wie packe ich Text in CodeTags?
                die da wären?
                und:
                ioBroker.admin 4.2.1
                  @bj-0
                  Text markieren, dann das </> anklicken.
                  Oder anders herum:
                  Icon anklicken, Text zwischen die Markierung kopieren.
                    Bj 0 last edited by
                    Also so:
                    host.raspberrypi	2021-04-03 01:44:56.174	error	instance system.adapter.javascript.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                    host.raspberrypi	2021-04-03 01:44:56.174	error	Caught by controller[0]: }
                    host.raspberrypi	2021-04-03 01:44:56.174	error	Caught by controller[0]: ]
                    host.raspberrypi	2021-04-03 01:44:56.174	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.javascript/main.js'
                    host.raspberrypi	2021-04-03 01:44:56.173	error	Caught by controller[0]: '/opt/iobroker/node_modules/virtual-tsc/build/index.js',
                    host.raspberrypi	2021-04-03 01:44:56.173	error	Caught by controller[0]: '/opt/iobroker/node_modules/virtual-tsc/build/server.js',
                    host.raspberrypi	2021-04-03 01:44:56.173	error	Caught by controller[0]: requireStack: [
                    host.raspberrypi	2021-04-03 01:44:56.173	error	Caught by controller[0]: code: 'MODULE_NOT_FOUND',
                    host.raspberrypi	2021-04-03 01:44:56.173	error	Caught by controller[0]: {
                    host.raspberrypi	2021-04-03 01:44:56.173	error	Caught by controller[0]: at internal/main/run_main_module.js:17:47
                    host.raspberrypi	2021-04-03 01:44:56.173	error	Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:60:12)
                    host.raspberrypi	2021-04-03 01:44:56.173	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:708:14)
                    host.raspberrypi	2021-04-03 01:44:56.172	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:863:32)
                    host.raspberrypi	2021-04-03 01:44:56.172	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1027:10)
                    host.raspberrypi	2021-04-03 01:44:56.172	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:999:30)
                    host.raspberrypi	2021-04-03 01:44:56.172	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/main.js:35:24)
                    host.raspberrypi	2021-04-03 01:44:56.172	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:74:18)
                    host.raspberrypi	2021-04-03 01:44:56.172	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:887:19)
                    host.raspberrypi	2021-04-03 01:44:56.172	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:708:14)
                    host.raspberrypi	2021-04-03 01:44:56.171	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1027:10)
                    host.raspberrypi	2021-04-03 01:44:56.171	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:999:30)
                    host.raspberrypi	2021-04-03 01:44:56.171	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/virtual-tsc/build/index.js:8:16)
                    host.raspberrypi	2021-04-03 01:44:56.171	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:74:18)
                    host.raspberrypi	2021-04-03 01:44:56.171	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:887:19)
                    host.raspberrypi	2021-04-03 01:44:56.171	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:708:14)
                    host.raspberrypi	2021-04-03 01:44:56.171	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:863:32)
                    host.raspberrypi	2021-04-03 01:44:56.170	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1027:10)
                    host.raspberrypi	2021-04-03 01:44:56.170	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:999:30)
                    host.raspberrypi	2021-04-03 01:44:56.170	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/virtual-tsc/build/server.js:4:10)
                    host.raspberrypi	2021-04-03 01:44:56.170	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:74:18)
                    host.raspberrypi	2021-04-03 01:44:56.170	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:887:19)
                    host.raspberrypi	2021-04-03 01:44:56.170	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:667:27)
                    host.raspberrypi	2021-04-03 01:44:56.170	error	Caught by controller[0]: at Function.Module._resolveFilename (internal/modules/cjs/loader.js:815:15)
                    host.raspberrypi	2021-04-03 01:44:56.170	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.javascript/main.js
                    host.raspberrypi	2021-04-03 01:44:56.169	error	Caught by controller[0]: - /opt/iobroker/node_modules/virtual-tsc/build/index.js
                    host.raspberrypi	2021-04-03 01:44:56.169	error	Caught by controller[0]: - /opt/iobroker/node_modules/virtual-tsc/build/server.js
                    host.raspberrypi	2021-04-03 01:44:56.169	error	Caught by controller[0]: Require stack:
                    host.raspberrypi	2021-04-03 01:44:56.169	error	Caught by controller[0]: Error: Cannot find module 'typescript'
                    host.raspberrypi	2021-04-03 01:44:56.169	error	Caught by controller[0]: ^
                    host.raspberrypi	2021-04-03 01:44:56.169	error	Caught by controller[0]: throw err;
                    host.raspberrypi	2021-04-03 01:44:56.168	error	Caught by controller[0]: internal/modules/cjs/loader.js:818
                    host.raspberrypi	2021-04-03 01:44:55.764	info	instance system.adapter.javascript.0 started with pid 5968
                      @bj-0
                      Schaut nicht gut aus. Was sagt
                      which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
                        @thomas-braun sagte in js-controller läuft nicht mehr nach Update ioBroker:
                        @bj-0
                        nodejs
                        v12.22.0
                        node
                        v12.22.0
                        npm
                        6.14.11
                        nodejs:
                        12.22.0-1nodesource1
                          Jan1 @Bj 0 last edited by Jan1
                          @bj-0
                          Ist es eigentlich so schwer alles zu posten, das in Code Tags zu packen und auch den Befehle mit, damit man nicht immer raten muss?
                          Da fehlt die Hälfte!
                          277
