    4. [gelöst] Zigbee Adapter: Problem mit Gruppen
      rotamint last edited by rotamint
      Systemdata Bitte Ausfüllen
      Hardwaresystem: Pi 4
      Arbeitsspeicher: 4 GB
      Festplattenart: SD-Karte
      Betriebssystem: Ubuntu
      Node-Version: 14.16.0
      Nodejs-Version: 14.16.0
      NPM-Version: 6.14.11
      Installationsart: Skript
      Image genutzt: Nein
      Stick: Conbee II
      Bei zuweisen der Lampen in die entsprechenden Gruppen erhalte ich folgende Logs:
      zigbee.0	2021-04-03 11:37:31.203	info	(8249) Zigbee started
      zigbee.0	2021-04-03 11:37:31.202	info	(8249) 0x00158d0004a03e4c (addr 15394): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
      zigbee.0	2021-04-03 11:37:31.201	info	(8249) 0x00158d00047d628b (addr 35609): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
      zigbee.0	2021-04-03 11:37:31.200	info	(8249) 0x00158d00047d3bb5 (addr 40033): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
      zigbee.0	2021-04-03 11:37:31.199	info	(8249) 0x00158d00049da7d0 (addr 43006): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
      zigbee.0	2021-04-03 11:37:31.198	info	(8249) 0x04cf8cdf3c7d9620 (addr 16925): WXCJKG13LM - Xiaomi Aqara Opple switch 3 bands (EndDevice)
      zigbee.0	2021-04-03 11:37:31.196	info	(8249) 0x842e14fffe37c623 (addr 13591): 14147206L - Lidl Livarno Lux ceiling light (Router)
      zigbee.0	2021-04-03 11:37:31.195	info	(8249) 0x842e14fffe1d9e28 (addr 15593): HG06492A - Lidl Livarno Lux GU10 spot CCT (Router)
      zigbee.0	2021-04-03 11:37:31.194	info	(8249) 0x588e81fffee38ec2 (addr 56236): HG06492A - Lidl Livarno Lux GU10 spot CCT (Router)
      zigbee.0	2021-04-03 11:37:31.192	info	(8249) 0x588e81fffef771f4 (addr 62921): HG06492A - Lidl Livarno Lux GU10 spot CCT (Router)
      zigbee.0	2021-04-03 11:37:31.191	info	(8249) 0x842e14fffe15da08 (addr 33156): HG06492A - Lidl Livarno Lux GU10 spot CCT (Router)
      zigbee.0	2021-04-03 11:37:31.190	info	(8249) 0x842e14fffe23076c (addr 56959): HG06492A - Lidl Livarno Lux GU10 spot CCT (Router)
      zigbee.0	2021-04-03 11:37:31.188	info	(8249) 0x842e14fffe230848 (addr 59205): HG06492A - Lidl Livarno Lux GU10 spot CCT (Router)
      zigbee.0	2021-04-03 11:37:31.187	info	(8249) 0x588e81fffef77a2f (addr 49811): HG06492A - Lidl Livarno Lux GU10 spot CCT (Router)
      zigbee.0	2021-04-03 11:37:31.186	info	(8249) 0x842e14fffe1b9c91 (addr 38189): HG06492A - Lidl Livarno Lux GU10 spot CCT (Router)
      zigbee.0	2021-04-03 11:37:31.184	info	(8249) 0x588e81fffeff6340 (addr 41064): HG06492A - Lidl Livarno Lux GU10 spot CCT (Router)
      zigbee.0	2021-04-03 11:37:31.183	info	(8249) 0xec1bbdfffe91cdf4 (addr 18751): HG06335 - Lidl Silvercrest smart motion sensor (EndDevice)
      zigbee.0	2021-04-03 11:37:31.181	info	(8249) 0xbc33acfffe5ede11 (addr 15735): FB20-002 - Lidl Livarno Lux switch and dimming light remote control (EndDevice)
      zigbee.0	2021-04-03 11:37:31.180	info	(8249) 0xbc33acfffe6328d8 (addr 11726): FB20-002 - Lidl Livarno Lux switch and dimming light remote control (EndDevice)
      zigbee.0	2021-04-03 11:37:31.179	info	(8249) 0x588e81fffe655d96 (addr 48383): LED1903C5/LED1835C6 - IKEA TRADFRI bulb E14 WS 470 lumen, dimmable, white spectrum, opal white (Router)
      zigbee.0	2021-04-03 11:37:31.178	info	(8249) 0x588e81fffefcc409 (addr 5547): TS0502A - TuYa Light controller (Router)
      zigbee.0	2021-04-03 11:37:31.176	info	(8249) 0x04cf8cdf3c7d4182 (addr 61114): WXCJKG13LM - Xiaomi Aqara Opple switch 3 bands (EndDevice)
      zigbee.0	2021-04-03 11:37:31.172	info	(8249) 0x001788010410074e (addr 49249): 8718696449691 - Philips Hue White A60 Single bulb E27/B22 (Router)
      zigbee.0	2021-04-03 11:37:31.118	info	(8249) Currently 22 devices are joined:
      zigbee.0	2021-04-03 11:37:31.113	info	(8249) Unable to set transmit power, unsupported function.
      zigbee.0	2021-04-03 11:37:31.112	info	(8249) --> transmitPower : normal
      zigbee.0	2021-04-03 11:37:31.111	info	(8249) Unable to disable LED, unsupported function.
      zigbee.0	2021-04-03 11:37:31.089	info	(8249) Coordinator firmware version: {"type":"ConBee2/RaspBee2","meta":{"transportrev":0,"product":0,"majorrel":38,"minorrel":104,"maintrel":0,"revision":"0x26680700"}}
      zigbee.0	2021-04-03 11:37:30.914	info	(8249) Installed Version: ioBroker/ioBroker.zigbee#master
      zigbee.0	2021-04-03 11:37:30.614	info	(8249) Starting Zigbee npm ...
      zigbee.0	2021-04-03 11:37:30.505	info	(8249) starting. Version 1.4.5 in /opt/iobroker/node_modules/iobroker.zigbee, node: v14.16.0, js-controller: 3.2.16
      zigbee.0	2021-04-03 11:37:25.153	info	(8182) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      zigbee.0	2021-04-03 11:37:25.152	info	(8182) terminating
      zigbee.0	2021-04-03 11:37:24.651	info	(8182) Zigbee: disabling joining new devices.
      zigbee.0	2021-04-03 11:37:24.648	info	(8182) cleaned everything up...
      zigbee.0	2021-04-03 11:37:24.646	info	(8182) Got terminate signal TERMINATE_YOURSELF
      zigbee.0	2021-04-03 11:35:49.002	warn	(7996) Terminated (UNCAUGHT_EXCEPTION): Without reason
      zigbee.0	2021-04-03 11:35:49.000	info	(7996) terminating
      zigbee.0	2021-04-03 11:35:48.501	info	(7996) Zigbee: disabling joining new devices.
      zigbee.0	2021-04-03 11:35:48.497	info	(7996) cleaned everything up...
      zigbee.0	2021-04-03 11:35:48.471	error	(7996) Command 0x842e14fffe1b9c91/1 genGroups.add({"groupid":1,"groupname":""}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":0,"srcEndpoin
      zigbee.0	2021-04-03 11:35:48.471	error	(7996) Error: Command 0x842e14fffe1b9c91/1 genGroups.add({"groupid":1,"groupname":""}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":0,"src
      zigbee.0	2021-04-03 11:35:48.470	error	(7996) unhandled promise rejection: Command 0x842e14fffe1b9c91/1 genGroups.add({"groupid":1,"groupname":""}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":t
      zigbee.0	2021-04-03 11:35:48.469	error	(7996) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      zigbee.0	2021-04-03 11:35:48.467	error	(7996) Command 0x588e81fffef77a2f/1 genGroups.add({"groupid":1,"groupname":""}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":0,"srcEndpoin
      zigbee.0	2021-04-03 11:35:48.467	error	(7996) Error: Command 0x588e81fffef77a2f/1 genGroups.add({"groupid":1,"groupname":""}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":0,"src
      zigbee.0	2021-04-03 11:35:48.466	error	(7996) unhandled promise rejection: Command 0x588e81fffef77a2f/1 genGroups.add({"groupid":1,"groupname":""}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":t
      zigbee.0	2021-04-03 11:35:48.465	error	(7996) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      zigbee.0	2021-04-03 11:35:48.465	error	(7996) Command 0x842e14fffe15da08/1 genGroups.add({"groupid":1,"groupname":""}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":0,"srcEndpoin
      zigbee.0	2021-04-03 11:35:48.464	error	(7996) Error: Command 0x842e14fffe15da08/1 genGroups.add({"groupid":1,"groupname":""}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":0,"src
      zigbee.0	2021-04-03 11:35:48.463	error	(7996) unhandled promise rejection: Command 0x842e14fffe15da08/1 genGroups.add({"groupid":1,"groupname":""}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":t
      zigbee.0	2021-04-03 11:35:48.460	error	(7996) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      zigbee.0	2021-04-03 11:35:48.460	error	(7996) Command 0x588e81fffee38ec2/1 genGroups.add({"groupid":2,"groupname":""}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":0,"srcEndpoin
      zigbee.0	2021-04-03 11:35:48.459	error	(7996) Error: Command 0x588e81fffee38ec2/1 genGroups.add({"groupid":2,"groupname":""}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":0,"src
      zigbee.0	2021-04-03 11:35:48.458	error	(7996) unhandled promise rejection: Command 0x588e81fffee38ec2/1 genGroups.add({"groupid":2,"groupname":""}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":t
      zigbee.0	2021-04-03 11:35:48.458	error	(7996) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      zigbee.0	2021-04-03 11:35:48.456	error	(7996) Command 0x842e14fffe1d9e28/1 genGroups.add({"groupid":2,"groupname":""}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":0,"srcEndpoin
      zigbee.0	2021-04-03 11:35:48.456	error	(7996) Error: Command 0x842e14fffe1d9e28/1 genGroups.add({"groupid":2,"groupname":""}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":0,"src
      zigbee.0	2021-04-03 11:35:48.454	error	(7996) unhandled promise rejection: Command 0x842e14fffe1d9e28/1 genGroups.add({"groupid":2,"groupname":""}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":t
      zigbee.0	2021-04-03 11:35:48.453	error	(7996) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      zigbee.0	2021-04-03 11:34:17.734	warn	(7996) Failed to ping 0x588e81fffef771f4 TS0502A
      zigbee.0	2021-04-03 11:32:14.860	info	(7996) Zigbee started
      Habe beispielsweise drei Leuchtmittel zu einer Gruppe zusammen gefasst / zugeordnet. Davon werden zwei (von den drei) Lampen korrekt geschaltet, darüber hinaus eine weitere - nicht dieser Gruppe zugeordnete Lampe aber auch! Wenn ich diese "nicht dieser Gruppe zugeordnete weitere Lampe" einer anderen Gruppe zuweise, wird diese zwar nicht mehr mit dieser Gruppe geschaltet, dafür jetzt aber eine andere Lampe ein- bzw. ausgeschaltet.
      Ansonsten läuft der Adapter absolut reibungslos und ich habe den Umzug - weg von Deconz - trotz des massiven Aufwandes bisher nicht bereut.
      Bin für jeden Hinweis dankbar und wünsche Euch allen frohe Ostertage!
      Gruß Stefan.
      • Asgothian
        Asgothian Developer @rotamint last edited by
        @rotamint
        Bitte versuche das Folgende:
        • Zigbee Adapter anhalten
        • Adapter von meinem Repository von Github installieren (in der Adpter Liste auf das folgende Icon blicken, "custom" auswählen und diesen Link benutzen: https://github.com/asgothian/ioBroker.zigbee/tarball/GroupsScreen Shot 2021-04-05 at 12.39.55 .png
        • upload durchführen (Adapter Seite, expertenansicht, der Knopf im Folgenden Bild in der MitteScreen Shot 2021-04-05 at 12.42.16 .png
        • Zigbee Adapter starten.
        Danach sollten die Abstürze bei den Gruppen weg sein. Es kann weiterhin Fehlermeldungen und Warnmeldungen geben. Diese bitte hier posten (insbesondere Fehler).
        A.
        R 2 Replies Last reply Reply Quote 0
          rotamint @Asgothian last edited by
          @asgothian
          Vielen Dank für Deinen Post - incl. Lösungsansatz! Ich habe die Installation nun nach Deiner Vorgabe ausgeführt, die Gruppen zugeordnet. Testen kann ich es erst heute Abend. Werde auf jeden Fall berichten.
          Vielen Dank nochmals, bis bald!
          Stefan.
            @asgothian
            vielen Dank nochmals für deine rasche Problembeseitigung. Ich habe jetzt intensiv getestet, kann nichts nachteiliges feststellen. Es läuft alles so, wie es sein soll!
