    4. Synology Adapter 1.0.0 Fehlermeldung
    • dslraser
      dslraser Forum Testing Most Active last edited by
      @apollon77 @instalator
      Ich habe eben Version 1.0.0 installiert
      synology.0	2021-04-10 21:48:45.511	warn	(10101) State "synology.0.DiskStationManager.hdd_info.sata_laufwerk_2.capacity" has no existing object, this might lead to an error in future versions
      synology.0	2021-04-10 21:48:45.510	warn	(10101) State "synology.0.DiskStationManager.hdd_info.sata_laufwerk_2.storage_pool" has no existing object, this might lead to an error in future versions
      synology.0	2021-04-10 21:48:45.509	warn	(10101) State "synology.0.DiskStationManager.hdd_info.sata_laufwerk_2.temperature" has no existing object, this might lead to an error in future versions
      synology.0	2021-04-10 21:48:45.508	warn	(10101) State "synology.0.DiskStationManager.hdd_info.sata_laufwerk_2.ebox_order" has no existing object, this might lead to an error in future versions
      synology.0	2021-04-10 21:48:45.508	warn	(10101) State "synology.0.DiskStationManager.hdd_info.sata_laufwerk_2.overview_status" has no existing object, this might lead to an error in future versions
      synology.0	2021-04-10 21:48:45.507	warn	(10101) State "synology.0.DiskStationManager.hdd_info.sata_laufwerk_2.model" has no existing object, this might lead to an error in future versions
      synology.0	2021-04-10 21:48:45.506	warn	(10101) State "synology.0.DiskStationManager.hdd_info.sata_laufwerk_2.diskno" has no existing object, this might lead to an error in future versions
      synology.0	2021-04-10 21:48:45.501	warn	(10101) State "synology.0.DiskStationManager.hdd_info.sata_laufwerk_1.capacity" has no existing object, this might lead to an error in future versions
      synology.0	2021-04-10 21:48:45.500	warn	(10101) State "synology.0.DiskStationManager.hdd_info.sata_laufwerk_1.storage_pool" has no existing object, this might lead to an error in future versions
      synology.0	2021-04-10 21:48:45.495	warn	(10101) State "synology.0.DiskStationManager.hdd_info.sata_laufwerk_1.temperature" has no existing object, this might lead to an error in future versions
      synology.0	2021-04-10 21:48:45.494	warn	(10101) State "synology.0.DiskStationManager.hdd_info.sata_laufwerk_1.ebox_order" has no existing object, this might lead to an error in future versions
      synology.0	2021-04-10 21:48:45.488	warn	(10101) State "synology.0.DiskStationManager.hdd_info.sata_laufwerk_1.overview_status" has no existing object, this might lead to an error in future versions
      synology.0	2021-04-10 21:48:45.484	warn	(10101) State "synology.0.DiskStationManager.hdd_info.sata_laufwerk_1.model" has no existing object, this might lead to an error in future versions
      synology.0	2021-04-10 21:48:45.476	warn	(10101) State "synology.0.DiskStationManager.hdd_info.sata_laufwerk_1.diskno" has no existing object, this might lead to an error in future versions
      apollon77 K 2 Replies Last reply Reply Quote 1
      • apollon77
        apollon77 @dslraser last edited by
        @dslraser Bitte GitHub issue anlegen. das muss auch mit der Version davor gekommen sein, daran wurde nichts geändert ind er 1.0 🙂
          Kueppert @dslraser last edited by
          @dslraser hast du ggf auch DSM7 installiert?
          • dslraser
            dslraser Forum Testing Most Active @Kueppert last edited by
            @kueppert sagte in Synology Adapter 1.0.0 Fehlermeldung:
            Nein.
            Latzi 1 Reply Last reply Reply Quote 0
            • Latzi
              Latzi @dslraser last edited by Latzi
              Gleiches Verhalten ist bei mir auch aufgetreten.
              Edit: Github-Issue ist erstellt github link
