    4. Rasperry und XS1 Fehlermeldungen
      ARI 0 last edited by ARI 0
      das System läuft kurz, dann funktioniert auch alles und folgen Fehlermeldungen mit denen ich nichts anfangen kann, nichts geht mehr (Sprachsteuerung via Alexa).
      Systemdata Meine Konfiguration
      Hardwaresystem: PI 4, CPUs 4, 600 MHz, ARMv7 Processor rev 3 (v7l)
      Arbeitsspeicher: 4 GB
      Festplattenart: SD-Karte 64 GB
      Betriebssystem: linux
      Node-Version: v12.22.1
      Nodejs-Version: v12.22.1
      NPM-Version: 6.14.12
      Image genutzt: Nein
      2021-04-11 09:33:31.238 - info: host.raspberrypi "system.adapter.xs1.2" disabled
      2021-04-11 09:33:33.987 - info: host.raspberrypi "system.adapter.xs1.2" enabled
      2021-04-11 09:33:34.045 - info: host.raspberrypi instance system.adapter.xs1.2 started with pid 23166
      2021-04-11 09:33:35.207 - info: xs1.2 (23166) starting. Version 1.0.2 in /opt/iobroker/node_modules/iobroker.xs1, node: v12.22.1, js-controller: 3.2.16
      2021-04-11 09:33:35.239 - info: xs1.2 (23166) config XS1 Addresse: http://XS1:80
      2021-04-11 09:33:35.258 - info: xs1.2 (23166) CopyList = {}
      2021-04-11 09:33:38.015 - warn: xs1.2 (23166) adapter.objects.getObjectList is deprecated, and will be removed in the future. Please use adapter.getObjectList/Async. Report this to Developer!
      2021-04-11 09:33:38.637 - info: xs1.2 (23166) Finished state creation. Added totally 54 actuators or sensors
      2021-04-11 09:34:38.704 - error: xs1.2 (23166) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      2021-04-11 09:34:38.706 - error: xs1.2 (23166) unhandled promise rejection: The state contains the forbidden properties lname, number, name, vtype!
      2021-04-11 09:34:38.711 - error: xs1.2 (23166) Error: The state contains the forbidden properties lname, number, name, vtype!
      at validateSetStateObjectArgument (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5848:23)
      at setState (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5935:21)
      at /opt/iobroker/node_modules/iobroker.xs1/xs1.js:44:15
      at new Promise ()
      at /opt/iobroker/node_modules/iobroker.xs1/xs1.js:42:16
      at pSetState (/opt/iobroker/node_modules/iobroker.xs1/xs1.js:432:34)
      at MyXS1. (/opt/iobroker/node_modules/iobroker.xs1/xs1.js:578:13)
      at MyXS1.emit (events.js:314:20)
      at IncomingMessage. (/opt/iobroker/node_modules/iobroker.xs1/xs1.js:275:34)
      at IncomingMessage.emit (events.js:314:20)
      2021-04-11 09:34:38.712 - error: xs1.2 (23166) The state contains the forbidden properties lname, number, name, vtype!
      2021-04-11 09:34:38.732 - info: xs1.2 (23166) cleaned everything up...
      2021-04-11 09:34:38.733 - info: xs1.2 (23166) terminating
      2021-04-11 09:34:38.735 - warn: xs1.2 (23166) Terminated (UNCAUGHT_EXCEPTION): Without reason
      2021-04-11 09:34:39.336 - error: host.raspberrypi instance system.adapter.xs1.2 terminated with code 6 (UNCAUGHT_EXCEPTION)
      2021-04-11 09:34:39.339 - info: host.raspberrypi Restart adapter system.adapter.xs1.2 because enabled
      2021-04-11 09:34:47.278 - info: host.raspberrypi Updating repository "default" under "http://download.iobroker.net/sources-dist.json"
      2021-04-11 09:35:09.392 - info: host.raspberrypi instance system.adapter.xs1.2 started with pid 23184
      2021-04-11 09:35:10.584 - info: xs1.2 (23184) starting. Version 1.0.2 in /opt/iobroker/node_modules/iobroker.xs1, node: v12.22.1, js-controller: 3.2.16
      2021-04-11 09:35:10.617 - info: xs1.2 (23184) config XS1 Addresse: http://XS1:80
      2021-04-11 09:35:10.620 - info: xs1.2 (23184) CopyList = {}
      2021-04-11 09:35:12.191 - warn: xs1.2 (23184) adapter.objects.getObjectList is deprecated, and will be removed in the future. Please use adapter.getObjectList/Async. Report this to Developer!
      2021-04-11 09:35:12.827 - info: xs1.2 (23184) Finished state creation. Added totally 54 actuators or sensors
      2021-04-11 09:36:12.868 - error: xs1.2 (23184) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      2021-04-11 09:36:12.870 - error: xs1.2 (23184) unhandled promise rejection: The state contains the forbidden properties lname, number, name, vtype!
      2021-04-11 09:36:12.876 - error: xs1.2 (23184) Error: The state contains the forbidden properties lname, number, name, vtype!
      at new Promise ()
      2021-04-11 09:36:12.878 - error: xs1.2 (23184) The state contains the forbidden properties lname, number, name, vtype!
      2021-04-11 09:36:12.921 - info: xs1.2 (23184) cleaned everything up...
      2021-04-11 09:36:12.922 - info: xs1.2 (23184) terminating
      2021-04-11 09:36:12.925 - warn: xs1.2 (23184) Terminated (UNCAUGHT_EXCEPTION): Without reason
      2021-04-11 09:36:13.480 - error: host.raspberrypi instance system.adapter.xs1.2 terminated with code 6 (UNCAUGHT_EXCEPTION)
      2021-04-11 09:36:13.485 - info: host.raspberrypi Restart adapter system.adapter.xs1.2 because enabled
      2021-04-11 09:36:43.535 - info: host.raspberrypi instance system.adapter.xs1.2 started with pid 23250
      2021-04-11 09:36:44.717 - info: xs1.2 (23250) starting. Version 1.0.2 in /opt/iobroker/node_modules/iobroker.xs1, node: v12.22.1, js-controller: 3.2.16
      2021-04-11 09:36:44.749 - info: xs1.2 (23250) config XS1 Addresse: http://XS1:80
      2021-04-11 09:36:44.753 - info: xs1.2 (23250) CopyList = {}
      2021-04-11 09:36:46.315 - warn: xs1.2 (23250) adapter.objects.getObjectList is deprecated, and will be removed in the future. Please use adapter.getObjectList/Async. Report this to Developer!
      2021-04-11 09:36:46.933 - info: xs1.2 (23250) Finished state creation. Added totally 54 actuators or sensors
      2021-04-11 09:37:33.098 - info: host.raspberrypi Updating repository "default" under "http://download.iobroker.net/sources-dist.json"
      2021-04-11 09:37:47.004 - error: xs1.2 (23250) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      2021-04-11 09:37:47.005 - error: xs1.2 (23250) unhandled promise rejection: The state contains the forbidden properties lname, number, name, vtype!
      2021-04-11 09:37:47.011 - error: xs1.2 (23250) Error: The state contains the forbidden properties lname, number, name, vtype!
      at new Promise ()
      2021-04-11 09:37:47.012 - error: xs1.2 (23250) The state contains the forbidden properties lname, number, name, vtype!
      2021-04-11 09:37:47.032 - info: xs1.2 (23250) cleaned everything up...
      2021-04-11 09:37:47.034 - info: xs1.2 (23250) terminating
      2021-04-11 09:37:47.036 - warn: xs1.2 (23250) Terminated (UNCAUGHT_EXCEPTION): Without reason
      2021-04-11 09:37:47.638 - error: host.raspberrypi instance system.adapter.xs1.2 terminated with code 6 (UNCAUGHT_EXCEPTION)
      2021-04-11 09:37:47.641 - info: host.raspberrypi Restart adapter system.adapter.xs1.2 because enabled
      2021-04-11 09:37:47.642 - warn: host.raspberrypi Do not restart adapter system.adapter.xs1.2 because restart loop detected
        Thomas Braun Most Active @ARI 0 last edited by
        @ari-0
        Kannst du bitte den log text in CodeTags packen? Danke.
          ARI 0 @Thomas Braun last edited by ARI 0
          Danke und bitte!
