    4. Vis lässt sich nicht von 1.3.4 zu 1.3.8 aktualisieren
    • I
      Ibot last edited by Ibot
      Systemdata
      Hardwaresystem: PI4
      Arbeitsspeicher: 4GB
      Festplattenart: USB Stick
      Betriebssystem: LInux
      Node-Version: 12.22.1
      Nodejs-Version: 12.22.1
      * Listenpunkt
      NPM-Version: 6.14.12
      Installationsart: Skrip
      Image genutzt: Ja
      Ort/Name der Imagedatei: Link ```
      • I
        Ibot @Ibot last edited by Ibot
        Hier der Fehlercode dazu nach der Aktualisierung schmiert der komplette Iobroker ab kann ihn nur durch einspielen eines Backups wieder zu laufen bringen
        $ ./iobroker upgrade vis
        Update vis from @1.3.4 to @1.3.8
        NPM version: 6.14.12npm install iobroker.vis@1.3.8 --loglevel error --prefix "/opt/iobroker" (System call)
        ERROR: internal/modules/cjs/loader.js:818  throw err;  ^Error: Cannot find module 'mime'Require stack:- /opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpload.js- /opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpgrade.js- /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js- /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js    at Function.Module._resolveFilename (internal/modules/cjs/loader.js:815:15)    at Function.Module._load (internal/modules/cjs/loader.js:667:27)    at Module.require (internal/modules/cjs/loader.js:887:19)    at require (internal/modules/cjs/helpers.js:74:18)    at Upload.uploadAdapter (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpload.js:525:24)    at /opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpgrade.js:211:28    at installNpm (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:2557:9)    at finishUpgrade (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpgrade.js:205:13)    at /opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpgrade.js:419:21    at /opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupInstall.js:223:55 {  code: 'MODULE_NOT_FOUND',  requireStack: [    '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpload.js',    '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpgrade.js',    '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js',    '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'  ]}
        ERROR: process exited with code 1```
        Thomas Braun wendy2702 Homoran 3 Replies Last reply Reply Quote 0
          Thomas Braun Most Active @Ibot last edited by
          @ibot Bitte in CodeTags einbetten.
          • wendy2702
            wendy2702 @Ibot last edited by wendy2702
            @ibot
            iobroker -v
            • I
              Ibot @wendy2702 last edited by
              @wendy2702
              3.2.16
                @ibot
                which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
                liefert?
                  Homoran Global Moderator Administrators @Ibot last edited by
                  @ibot sagte in Vis lässt sich nicht von 1.3.4 zu 1.3.8 aktualisieren:
                  Habe gerade für dich mal das Forum nach diesem Fehler durchsucht.
                  Konnte nur "Probleme" in Zusammenhang mit einer Windows-Installation finden.
                  • I
                    Ibot @Thomas Braun last edited by
                    @thomas-braun sagte in Vis lässt sich nicht von 1.3.4 zu 1.3.8 aktualisieren:
                    /usr/bin/nodejs
                    v12.22.1
                    /usr/bin/node
                    v12.22.1
                    /usr/bin/npm
                    6.14.12
                    nodejs:
                      Installiert:           12.22.1-1nodesource1
                      Installationskandidat: 12.22.1-1nodesource1
                      Versionstabelle:
                     *** 12.22.1-1nodesource1 500
                            500 https://deb.nodesource.com/node_12.x buster/main armhf Packages
                            100 /var/lib/dpkg/status
                         10.24.0~dfsg-1~deb10u1 500
                      @ibot
                      iobroker update
                      iobroker upgrade
                      Wenn das nicht funktioniert:
                      cd /opt/iobroker
                      sudo -H -u iobroker npm install iobroker.js-controller
                      I 2 Replies Last reply Reply Quote 0
                      • I
                        Ibot @Thomas Braun last edited by wendy2702
                        na dem Upgrade Befehl kommt:
                        Require stack:
                            at Upload.uploadAdapter (/opt/iobroker/node_modules/iobroker.js-controller/l        ib/setup/setupUpload.js:525:24)
                            at /opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpgrade.        js:211:28
                            at installNpm (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.j        s:2557:9)
                            at finishUpgrade (/opt/iobroker/node_modules/iobroker.js-controller/lib/setu        p/setupUpgrade.js:205:13)
                            at /opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpgrade.        js:419:21
                            at /opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupInstall.        js:223:55 {
                          requireStack: [
                            '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpload.js'        ,
                            '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpgrade.js        ',
                        MOD EDIT: CODE TAGS KORRIGIERT
                        • I
                          nach:cd /opt/iobroker
                          npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
                          npm WARN deprecated har-validator@5.1.5: this library is no longer supported
                          > iobroker.js-controller@3.2.16 preinstall /opt/iobroker/node_modules/iobroker.js-controller
                          > node lib/preinstallCheck.js
                          > unix-dgram@2.0.3 install /opt/iobroker/node_modules/unix-dgram
                          > node-gyp rebuild
                          make: Verzeichnis „/opt/iobroker/node_modules/unix-dgram/build“ wird betreten
                            CXX(target) Release/obj.target/unix_dgram/src/unix_dgram.o
                          In file included from ../../nan/nan.h:56,
                                           from ../src/unix_dgram.cc:5:
                          /home/iobroker/.cache/node-gyp/12.22.1/include/node/node.h:736:43: warning: cast between incompatible function types from ‘void (*)(v8::Local<v8::Object>)’ to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]
                                 (node::addon_register_func) (regfunc),                          \
                          /home/iobroker/.cache/node-gyp/12.22.1/include/node/node.h:770:3: note: in expansion of macro ‘NODE_MODULE_X’
                             NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)
                          ../src/unix_dgram.cc:404:1: note: in expansion of macro ‘NODE_MODULE’
                           NODE_MODULE(unix_dgram, Initialize)
                            SOLINK_MODULE(target) Release/obj.target/unix_dgram.node
                            COPY Release/unix_dgram.node
                          make: Verzeichnis „/opt/iobroker/node_modules/unix-dgram/build“ wird verlassen
                          > ursa-optional@0.9.10 install /opt/iobroker/node_modules/ursa-optional
                          > node rebuild.js
                          ursaNative bindings compilation fail. This is not an issue. Modules that depend on it will use fallbacks.
                          > diskusage@1.1.3 install /opt/iobroker/node_modules/diskusage
                          > node-gyp rebuild
                          make: Verzeichnis „/opt/iobroker/node_modules/diskusage/build“ wird betreten
                            CXX(target) Release/obj.target/diskusage/src/main.o
                                           from ../src/main.cpp:3:
                          ../src/main.cpp:42:1: note: in expansion of macro ‘NODE_MODULE’
                           NODE_MODULE(diskusage, Init)
                            CXX(target) Release/obj.target/diskusage/src/diskusage_posix.o
                            SOLINK_MODULE(target) Release/obj.target/diskusage.node
                            COPY Release/diskusage.node
                          make: Verzeichnis „/opt/iobroker/node_modules/diskusage/build“ wird verlassen
                          > iobroker.js-controller@3.2.16 install /opt/iobroker/node_modules/iobroker.js-controller
                          > node iobroker.js setup first
                          object _design/system updated
                          > @root/acme@3.1.0 postinstall /opt/iobroker/node_modules/@root/acme
                          > node scripts/postinstall
                          npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.1 (node_modules/chokidar/node_modules/fsevents):
                          npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
                          npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.7 (node_modules/osx-temperature-sensor):
                          npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.7: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
                          + iobroker.js-controller@3.2.16
                          added 254 packages from 265 contributors, removed 6 packages, updated 1 package and moved 16 packages in 96.989s
                          13 packages are looking for funding
                            run `npm fund` for details
                             │      New major version of npm available! 6.14.12 → 7.10.0      │
                             │   Changelog: https://github.com/npm/cli/releases/tag/v7.10.0   │
                             │               Run npm install -g npm to update!                │
                          mikeal created this issue in request/request
                          open Request’s Past, Present and Future #3142
                            @ibot
                            Und?
                            • I
                              iobroker ist über die webobefläche nicht mehr ereichbar soll ich das npm Update durchführen?
                                Thomas Braun Most Active @Ibot last edited by Thomas Braun
                                @ibot
                                Auf gar keinen Fall!
                                Das macht es nur schlimmer.
                                npm wird nur über den Paketmanager aktualisiert, im Zuge eine Updates von nodejs.
                                iobroker status
                                iobroker list adapters
                                iobroker list instances
                                • I
                                  iobroker status
                                  pi@raspberrypi:/opt/iobroker $ iobroker status
                                  Objects type: file
                                  States  type: file
                                  pi@raspberrypi:/opt/iobroker $ iobroker list adapters
                                  system.adapter.admin                   : admin          - v4.2.1
                                  system.adapter.discovery               : discovery      - v2.6.1
                                  system.adapter.flot                    : flot           - v1.10.6
                                  system.adapter.history                 : history        - v1.9.12
                                  system.adapter.info                    : info           - v1.7.14
                                  system.adapter.javascript              : javascript     - v5.0.14
                                  system.adapter.mqtt                    : mqtt           - v2.3.5
                                  system.adapter.mqtt-client             : mqtt-client    - v1.3.1
                                  system.adapter.node-red                : node-red       - v2.2.0
                                  system.adapter.rpi2                    : rpi2           - v1.2.0
                                  system.adapter.sonoff                  : sonoff         - v2.4.0
                                  system.adapter.vis                     : vis            - v1.3.4
                                  system.adapter.vis-hqwidgets           : vis-hqwidgets  - v1.1.7
                                  system.adapter.web                     : web            - v3.3.0
                                  system.adapter.yahka                   : yahka          - v0.12.0
                                  pi@raspberrypi:/opt/iobroker $ iobroker list instances
                                    system.adapter.discovery.0              : discovery             : raspberrypi                              - disabled
                                    system.adapter.flot.0                   : flot                  : raspberrypi                              -  enabled
                                  + system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              -  enabled, port: 1880, bind: 0.0.0.0
                                  + system.adapter.rpi2.0                   : rpi2                  : raspberrypi                              -  enabled
                                  + system.adapter.sonoff.0                 : sonoff                : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
                                    system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              -  enabled
                                  + system.adapter.yahka.0                  : yahka                 : raspberrypi                              -  enabled
                                  + instance is alive
                                    @ibot
                                    Sollte eigentlich laufen. Welche Meldungen bekommst du?
                                    Homoran I 2 Replies Last reply Reply Quote 0
                                      sehe ich auch so!
                                      @Ibot
                                      hast du mal den Browsercache gelöscht?
                                      • I
                                        Ibot @Thomas Braun last edited by Homoran
                                        Im Browser steht
                                        Cannot GET /
                                          Starte den Pi mal sauber durch:
                                          iobroker stop
                                          sudo reboot
                                          Und BrowserCache löschen, wie @Homoran schon sagte.
                                          • I
                                            Ibot @Homoran last edited by
                                            Hallo, ja habe ich sobald ich das Backup zurückspiele ist über den Browser auch alles wieder ereichbar
                                            vis update
                                            733
