    4. Deconz Adapter stürzt bei neuer Phoscon Version 2.11.00 ab.
      hilde0407 last edited by
      Der Deconz Adapter stürzt bei der neuen Phoscon Software 2.11.00 ab, sobald ein Sensor oder Schalter betätigt wird. Ein kompletten Debug Log habe ich mal angehängt:
      deconz.0	2021-04-18 15:57:04.427	debug	(18310) Subscribed to updates...
      deconz.0	2021-04-18 15:56:15.593	debug	(18310) system.adapter.admin.0: logging true
      deconz.0	2021-04-18 15:56:04.422	debug	(18310) Websocket connection closed
      deconz.0	2021-04-18 15:56:04.421	warn	(18310) Could not connect to websocket instance of deConz/Phoscon. Error: connect ECONNREFUSED 192.168.178.230:443
      deconz.0	2021-04-18 15:56:00.727	debug	(18310) system.adapter.admin.0: logging false
      deconz.0	2021-04-18 15:55:38.164	debug	(18310) system.adapter.admin.0: logging true
      deconz.0	2021-04-18 15:55:36.442	debug	(18310) system.adapter.admin.0: logging false
      deconz.0	2021-04-18 15:55:24.773	info	(18310) Adapter is ready
      deconz.0	2021-04-18 15:55:04.629	debug	(18310) Websocket connection closed
      deconz.0	2021-04-18 15:55:04.412	debug	(18310) Websocket message: {"attr":{"id":"1","lastannounced":null,"lastseen":"2021-04-18T13:55Z","manufacturername":"dresden elektronik","modelid":"ConBee II","name":"Configuration tool 1","swversion
      deconz.0	2021-04-18 15:54:59.525	debug	(18310) Websocket message: {"e":"changed","id":"35","r":"sensors","state":{"lastupdated":"2021-04-18T13:54:59.515","open":true},"t":"event","uniqueid":"00:15:8d:00:02:72:01:04-01-0006"}
      deconz.0	2021-04-18 15:54:55.553	debug	(18310) Websocket message: {"e":"changed","id":"9","r":"sensors","state":{"lastupdated":"2021-04-18T13:54:55.545","open":true},"t":"event","uniqueid":"00:15:8d:00:02:73:da:4e-01-0006"}
      deconz.0	2021-04-18 15:54:51.334	debug	(18310) Websocket message: {"e":"changed","id":"19","r":"sensors","state":{"lastupdated":"2021-04-18T13:54:51.324","presence":true},"t":"event","uniqueid":"00:15:8d:00:02:27:ce:92-01-0406"}
      deconz.0	2021-04-18 15:54:48.230	debug	(18310) Websocket message: {"config":{"battery":100,"duration":90,"on":true,"reachable":true,"temperature":0},"e":"changed","id":"19","r":"sensors","t":"event","uniqueid":"00:15:8d:00:02:27:ce:92-01-
      deconz.0	2021-04-18 15:54:39.779	debug	(18310) Subscribed to updates...
      deconz.0	2021-04-18 15:54:39.769	debug	(18310) Websocket connection closed
      deconz.0	2021-04-18 15:54:24.782	debug	(18310) Subscribed to updates...
      deconz.0	2021-04-18 15:54:24.779	debug	(18310) Code 200: Request succeded get group attributes 8: {"action":{"alert":"none","bri":127,"colormode":"hs","ct":0,"effect":"none","hue":0,"on":false,"sat":127,"scene":null,"xy":[0,0]},"devicemem
      deconz.0	2021-04-18 15:54:24.758	debug	(18310) Code 200: Request succeded get group attributes 7: {"action":{"alert":"none","bri":127,"colormode":"hs","ct":0,"effect":"none","hue":0,"on":false,"sat":127,"scene":null,"xy":[0,0]},"devicemem
      deconz.0	2021-04-18 15:54:24.739	debug	(18310) Code 200: Request succeded get group attributes 6: {"action":{"alert":"none","bri":127,"colormode":"hs","ct":0,"effect":"none","hue":0,"on":false,"sat":127,"scene":null,"xy":[0,0]},"devicemem
      deconz.0	2021-04-18 15:54:24.724	debug	(18310) Code 200: Request succeded get group attributes 4: {"action":{"alert":"none","bri":127,"colormode":"hs","ct":0,"effect":"none","hue":0,"on":false,"sat":127,"scene":null,"xy":[0,0]},"devicemem
      deconz.0	2021-04-18 15:54:24.709	debug	(18310) Code 200: Request succeded get group attributes 1: {"action":{"alert":"none","bri":127,"colormode":"hs","ct":0,"effect":"none","hue":0,"on":false,"sat":127,"scene":null,"xy":[0,0]},"devicemem
      deconz.0	2021-04-18 15:54:24.694	debug	(18310) Code 200: Request succeded get all groups: {"1":{"action":{"alert":"none","bri":127,"colormode":"hs","ct":0,"effect":"none","hue":0,"on":false,"sat":127,"scene":null,"xy":[0,0]},"devicemember
      deconz.0	2021-04-18 15:54:23.568	debug	(18310) Code 200: Request succeded get all sensors: {"1":{"config":{"configured":true,"on":true,"sunriseoffset":30,"sunsetoffset":-30},"etag":"f22703a147e68ad8ba03fcc86680ee10","manufacturername":"Ph
      deconz.0	2021-04-18 15:54:22.980	debug	(18310) Code 200: Request succeded get all lights: {"1":{"etag":"742bd69a4307c446637c9853e09d8f31","hascolor":false,"lastannounced":null,"lastseen":"2021-04-18T13:53Z","manufacturername":"dresden ele
      deconz.0	2021-04-18 15:54:22.963	info	(18310) deConz Version: 2.11.0; API version: 1.16.0
      deconz.0	2021-04-18 15:54:22.962	debug	(18310) Code 200: Request succeded get config: {"UTC":"2021-04-18T13:54:22","apiversion":"1.16.0","backup":{"errorcode":0,"status":"idle"},"bridgeid":"00212EFFFF054EC0","datastoreversion":"93","devi
      @Jey-Cee es wäre schön, wenn Du helfen könntest!
      Systemdata Beelink T45 mit Proxmox
      Hardwaresystem: NUC
      Arbeitsspeicher: 8GB
      Festplattenart: SSD
      Betriebssystem: Proxmox mit mehreren LXC Containern und einer VM für den Conbee 2 Stick
      Node-Version: 12.22.1
      Nodejs-Version: 12.22.1
      NPM-Version: 6.14.12
      Installationsart: Skript
      Image genutzt: Nein
      Ort/Name der Imagedatei: Link
      • Jey Cee
        Jey Cee Developer @hilde0407 last edited by
        @hilde0407 welche version vom Adapter ist Installiert?
        Im Log sehe ich keinen Absturz, da sieht alles gut aus bsi auf das er keine Websocket Verbindung aufbauen kann.
          hilde0407 @Jey Cee last edited by
          @jey-cee Es ist der Deconz Adapter 2.0.6 installiert!
          Sobald ich einen Schalter betätige wird der Adapter gelb und nach einiger Zeit wieder grün. Geschaltet wird aber nix!
          • Jey Cee
            @hilde0407 sagte in Deconz Adapter stürzt bei neuer Phoscon Version 2.11.00 ab.:
            Gut dann hat sich das schon erledigt, alles was v2 ist wird nicht Supportet. Der Grund dafür steht im anderen Thema.
            Bitte die 1.3.11 verwenden.
              @jey-cee Habe ich eine Chance, dass es dort funktioniert? Es würde ja bedeuten, dass ich alles neu anlernen muss!
              • Jey Cee
                @hilde0407 Eine bessere als mit der v2. Und Nein, anlernen musst du nicht alles neu. Das ist ja alles in deConz geregelt.
                Du musst nur deine Scripte anpassen, wegen der anderen Objekt Struktur.
                  @jey-cee OK ! Ich versuche es mal! Dankeschön!
