    4. HarmonyHub fehlermeldung aus Log
      ccc.ggg73 last edited by
      kann mir jemand sagen warum ich dieser Fehlermeldung bekomme?
      Das harmonyhub funktioniert einigermaßen zuverlässig aber manchmal blockiert und muss adapter neu starten.
      LG
      Giovanni
      harmony.0	2017-01-16 11:12:07.503	info	harmony.0 synced hub config
      harmony.0	2017-01-16 11:12:07.497	info	harmony.0 creating activities and devices
      harmony.0	2017-01-16 11:12:06.556	info	harmony.0 connected to Harmony Hub
      harmony.0	2017-01-16 11:12:05.201	info	harmony.0 connecting to Harmony Hub
      harmony.0	2017-01-16 11:12:05.195	info	harmony.0 discovered Harmony Hub
      harmony.0	2017-01-16 11:12:04.034	info	harmony.0 discover started
      harmony.0	2017-01-16 11:12:03.987	info	harmony.0 hub initialized
      harmony.0	2017-01-16 11:12:03.948	info	harmony.0 starting. Version 0.5.6 in /opt/iobroker/node_modules/iobroker.harmony, node: v4.7.2
      raspberrypi	2017-01-16 11:12:01.460	info	host.raspberrypi instance system.adapter.harmony.0 started with pid 951
      raspberrypi	2017-01-16 11:12:00.451	info	host.raspberrypi Restart adapter system.adapter.harmony.0 because enabled
      raspberrypi	2017-01-16 11:12:00.451	error	host.raspberrypi instance system.adapter.harmony.0 terminated with code 156 ()
      harmony.0	2017-01-16 11:12:00.420	info	harmony.0 Scheduled restart.
      harmony.0	2017-01-16 11:11:07.950	info	harmony.0 synced hub config
      harmony.0	2017-01-16 11:11:07.948	info	harmony.0 creating activities and devices
      harmony.0	2017-01-16 11:11:07.052	info	harmony.0 connected to Harmony Hub
      harmony.0	2017-01-16 11:11:05.712	info	harmony.0 connecting to Harmony Hub
      harmony.0	2017-01-16 11:11:05.711	info	harmony.0 discovered Harmony Hub
      harmony.0	2017-01-16 11:11:04.552	info	harmony.0 discover started
      harmony.0	2017-01-16 11:11:04.489	info	harmony.0 hub initialized
      harmony.0	2017-01-16 11:11:04.449	info	harmony.0 starting. Version 0.5.6 in /opt/iobroker/node_modules/iobroker.harmony, node: v4.7.2
      raspberrypi	2017-01-16 11:11:01.942	info	host.raspberrypi instance system.adapter.harmony.0 started with pid 31047
      raspberrypi	2017-01-16 11:11:00.922	info	host.raspberrypi Restart adapter system.adapter.harmony.0 because enabled
      raspberrypi	2017-01-16 11:11:00.922	error	host.raspberrypi instance system.adapter.harmony.0 terminated with code 156 ()
      harmony.0	2017-01-16 11:11:00.893	info	harmony.0 Scheduled restart.
      harmony.0	2017-01-16 11:10:07.464	info	harmony.0 synced hub config
      harmony.0	2017-01-16 11:10:07.463	info	harmony.0 creating activities and devices
      harmony.0	2017-01-16 11:10:06.517	info	harmony.0 connected to Harmony Hub
      harmony.0	2017-01-16 11:10:05.184	info	harmony.0 connecting to Harmony Hub
      harmony.0	2017-01-16 11:10:05.182	info	harmony.0 discovered Harmony Hub
      harmony.0	2017-01-16 11:10:04.019	info	harmony.0 discover started
      harmony.0	2017-01-16 11:10:03.971	info	harmony.0 hub initialized
      harmony.0	2017-01-16 11:10:03.936	info	harmony.0 starting. Version 0.5.6 in /opt/iobroker/node_modules/iobroker.harmony, node: v4.7.2
      raspberrypi	2017-01-16 11:10:01.417	info	host.raspberrypi instance system.adapter.harmony.0 started with pid 28568
      raspberrypi	2017-01-16 11:10:00.405	info	host.raspberrypi Restart adapter system.adapter.harmony.0 because enabled
      raspberrypi	2017-01-16 11:10:00.404	error	host.raspberrypi instance system.adapter.harmony.0 terminated with code 156 ()
      harmony.0	2017-01-16 11:10:00.368	warn	harmony.0 client ended
      harmony.0	2017-01-16 11:10:00.367	info	harmony.0 terminating
      harmony.0	2017-01-16 11:10:00.367	info	harmony.0 Scheduled restart.
      harmony.0	2017-01-16 11:09:07.911	info	synced hub config
      harmony.0	2017-01-16 11:09:07.896	info	creating activities and devices
      harmony.0	2017-01-16 11:09:07.001	info	connected to Harmony Hub
      harmony.0	2017-01-16 11:09:05.652	info	connecting to Harmony Hub
      harmony.0	2017-01-16 11:09:05.652	info	discovered Harmony Hub
      harmony.0	2017-01-16 11:09:04.469	info	discover started
      harmony.0	2017-01-16 11:09:04.432	info	hub initialized
      harmony.0	2017-01-16 11:09:04.293	info	starting. Version 0.5.6 in /opt/iobroker/node_modules/iobroker.harmony, node: v4.7.2
      host.raspberrypi	2017-01-16 11:09:01.919	info	instance system.adapter.harmony.0 started with pid 26237
      host.raspberrypi	2017-01-16 11:09:00.896	info	Restart adapter system.adapter.harmony.0 because enabled
      host.raspberrypi	2017-01-16 11:09:00.895	error	instance system.adapter.harmony.0 terminated with code 156 ()
      harmony.0	2017-01-16 11:09:00.872	info	terminating
      harmony.0	2017-01-16 11:09:00.851	warn	client ended
      harmony.0	2017-01-16 11:09:00.842	info	terminating
      harmony.0	2017-01-16 11:09:00.840	info	Scheduled restart.
      harmony.0	2017-01-16 11:08:07.440	info	synced hub config
      harmony.0	2017-01-16 11:08:07.405	info	creating activities and devices
      harmony.0	2017-01-16 11:08:06.471	info	connected to Harmony Hub
      harmony.0	2017-01-16 11:08:05.143	info	connecting to Harmony Hub
      harmony.0	2017-01-16 11:08:05.142	info	discovered Harmony Hub
      harmony.0	2017-01-16 11:08:03.960	info	discover started
      harmony.0	2017-01-16 11:08:03.922	info	hub initialized
      harmony.0	2017-01-16 11:08:03.791	info	starting. Version 0.5.6 in /opt/iobroker/node_modules/iobroker.harmony, node: v4.7.2
      host.raspberrypi	2017-01-16 11:08:01.365	info	instance system.adapter.harmony.0 started with pid 23714
      host.raspberrypi	2017-01-16 11:08:00.350	info	Restart adapter system.adapter.harmony.0 because enabled
      host.raspberrypi	2017-01-16 11:08:00.349	error	instance system.adapter.harmony.0 terminated with code 156 ()
      harmony.0	2017-01-16 11:08:00.301	info	terminating
      harmony.0	2017-01-16 11:08:00.281	warn	client ended
      harmony.0	2017-01-16 11:08:00.273	info	terminating
      harmony.0	2017-01-16 11:08:00.271	info	Scheduled restart.
      cloud.0	2017-01-16 11:07:39.209	info	Request devices
      harmony.0	2017-01-16 11:07:08.001	info	synced hub config
      harmony.0	2017-01-16 11:07:07.990	info	creating activities and devices
      harmony.0	2017-01-16 11:07:07.104	info	connected to Harmony Hub
      harmony.0	2017-01-16 11:07:05.746	info	connecting to Harmony Hub
      harmony.0	2017-01-16 11:07:05.746	info	discovered Harmony Hub
      cloud.0	2017-01-16 11:07:05.288	info	Request enums
      harmony.0	2017-01-16 11:07:04.563	info	discover started
      harmony.0	2017-01-16 11:07:04.521	info	hub initialized
      harmony.0	2017-01-16 11:07:04.219	info	starting. Version 0.5.6 in /opt/iobroker/node_modules/iobroker.harmony, node: v4.7.2
      host.raspberrypi	2017-01-16 11:07:01.799	info	instance system.adapter.harmony.0 started with pid 21383
      host.raspberrypi	2017-01-16 11:07:00.784	info	Restart adapter system.adapter.harmony.0 because enabled
      host.raspberrypi	2017-01-16 11:07:00.783	error	instance system.adapter.harmony.0 terminated with code 156 ()
      harmony.0	2017-01-16 11:07:00.745	warn	client ended
      harmony.0	2017-01-16 11:07:00.740	info	terminating
      harmony.0	2017-01-16 11:07:00.738	info	Scheduled restart.
      host.raspberrypi	2017-01-16 11:06:11.443	info	instance system.adapter.yr.0 terminated with code 0 (OK)
      harmony.0	2017-01-16 11:06:07.348	info	synced hub config
      harmony.0	2017-01-16 11:06:07.326	info	creating activities and devices
      harmony.0	2017-01-16 11:06:06.397	info	connected to Harmony Hub
      yr.0	2017-01-16 11:06:06.324	info	got weather data from yr.no
      harmony.0	2017-01-16 11:06:05.036	info	connecting to Harmony Hub
      harmony.0	2017-01-16 11:06:05.035	info	discovered Harmony Hub
      harmony.0	2017-01-16 11:06:03.852	info	discover started
      harmony.0	2017-01-16 11:06:03.819	info	hub initialized
      harmony.0	2017-01-16 11:06:03.692	info	starting. Version 0.5.6 in /opt/iobroker/node_modules/iobroker.harmony, node: v4.7.2
      yr.0	2017-01-16 11:06:02.230	info	starting. Version 1.0.5 in /opt/iobroker/node_modules/iobroker.yr, node: v4.7.2
      host.raspberrypi	2017-01-16 11:06:01.195	info	instance system.adapter.harmony.0 started with pid 18926
      host.raspberrypi	2017-01-16 11:06:00.335	info	instance system.adapter.yr.0 started with pid 18920
      host.raspberrypi	2017-01-16 11:06:00.182	info	Restart adapter system.adapter.harmony.0 because enabled
      host.raspberrypi	2017-01-16 11:06:00.182	error	instance system.adapter.harmony.0 terminated with code 156 ()
      harmony.0	2017-01-16 11:06:00.149	warn	client ended
      harmony.0	2017-01-16 11:06:00.141	info	terminating
      harmony.0	2017-01-16 11:06:00.139	info	Scheduled restart.
      harmony.0	2017-01-16 11:05:07.793	info	synced hub config
      harmony.0	2017-01-16 11:05:07.778	info	creating activities and devices
      harmony.0	2017-01-16 11:05:06.845	info	connected to Harmony Hub
      harmony.0	2017-01-16 11:05:05.446	info	connecting to Harmony Hub
      harmony.0	2017-01-16 11:05:05.446	info	discovered Harmony Hub
      harmony.0	2017-01-16 11:05:04.257	info	discover started
      harmony.0	2017-01-16 11:05:04.221	info	hub initialized
      harmony.0	2017-01-16 11:05:04.094	info	starting. Version 0.5.6 in /opt/iobroker/node_modules/iobroker.harmony, node: v4.7.2
      host.raspberrypi	2017-01-16 11:05:01.512	info	instance system.adapter.harmony.0 started with pid 16586
      host.raspberrypi	2017-01-16 11:05:00.499	info	Restart adapter system.adapter.harmony.0 because enabled
      host.raspberrypi	2017-01-16 11:05:00.498	error	instance system.adapter.harmony.0 terminated with code 156 ()
      harmony.0	2017-01-16 11:05:00.478	info	terminating
      harmony.0	2017-01-16 11:05:00.464	warn	client ended
      harmony.0	2017-01-16 11:05:00.458	info	terminating
      harmony.0	2017-01-16 11:05:00.457	info	Scheduled restart.
      harmony.0	2017-01-16 11:04:07.993	info	synced hub config
      harmony.0	2017-01-16 11:04:07.980	info	creating activities and devices
      harmony.0	2017-01-16 11:04:07.087	info	connected to Harmony Hub
      harmony.0	2017-01-16 11:04:05.756	info	connecting to Harmony Hub
      harmony.0	2017-01-16 11:04:05.756	info	discovered Harmony Hub
      harmony.0	2017-01-16 11:04:04.575	info	discover started
      harmony.0	2017-01-16 11:04:04.541	info	hub initialized
      harmony.0	2017-01-16 11:04:04.411	info	starting. Version 0.5.6 in /opt/iobroker/node_modules/iobroker.harmony, node: v4.7.2
      host.raspberrypi	2017-01-16 11:04:02.019	info	instance system.adapter.harmony.0 started with pid 14134
      host.raspberrypi	2017-01-16 11:04:00.996	info	Restart adapter system.adapter.harmony.0 because enabled
      host.raspberrypi	2017-01-16 11:04:00.995	error	instance system.adapter.harmony.0 terminated with code 156 ()
      harmony.0	2017-01-16 11:04:00.974	info	terminating
      harmony.0	2017-01-16 11:04:00.959	warn	client ended
      harmony.0	2017-01-16 11:04:00.951	info	terminating
      harmony.0	2017-01-16 11:04:00.950	info	Scheduled restart.
      harmony.0	2017-01-16 11:03:07.537	info	synced hub config
      harmony.0	2017-01-16 11:03:07.522	info	creating activities and devices
      harmony.0	2017-01-16 11:03:06.635	info	connected to Harmony Hub
      harmony.0	2017-01-16 11:03:05.298	info	connecting to Harmony Hub
      harmony.0	2017-01-16 11:03:05.298	info	discovered Harmony Hub
      harmony.0	2017-01-16 11:03:04.099	info	discover started
      harmony.0	2017-01-16 11:03:04.061	info	hub initialized
      harmony.0	2017-01-16 11:03:03.895	info	starting. Version 0.5.6 in /opt/iobroker/node_modules/iobroker.harmony, node: v4.7.2
      host.raspberrypi	2017-01-16 11:03:01.490	info	instance system.adapter.harmony.0 started with pid 11802
      host.raspberrypi	2017-01-16 11:03:00.478	info	Restart adapter system.adapter.harmony.0 because enabled
      host.raspberrypi	2017-01-16 11:03:00.477	error	instance system.adapter.harmony.0 terminated with code 156 ()
      harmony.0	2017-01-16 11:03:00.458	info	terminating
      harmony.0	2017-01-16 11:03:00.444	warn	client ended
      harmony.0	2017-01-16 11:03:00.438	info	terminating
      harmony.0	2017-01-16 11:03:00.436	info	Scheduled restart.
      harmony.0	2017-01-16 11:02:07.974	info	synced hub config
      harmony.0	2017-01-16 11:02:07.963	info	creating activities and devices
      harmony.0	2017-01-16 11:02:07.075	info	connected to Harmony Hub
      harmony.0	2017-01-16 11:02:05.725	info	connecting to Harmony Hub
      harmony.0	2017-01-16 11:02:05.724	info	discovered Harmony Hub
      harmony.0	2017-01-16 11:02:04.542	info	discover started
      harmony.0	2017-01-16 11:02:04.511	info	hub initialized
      harmony.0	2017-01-16 11:02:04.390	info	starting. Version 0.5.6 in /opt/iobroker/node_modules/iobroker.harmony, node: v4.7.2
      host.raspberrypi	2017-01-16 11:02:01.908	info	instance system.adapter.harmony.0 started with pid 9351
      host.raspberrypi	2017-01-16 11:02:00.886	info	Restart adapter system.adapter.harmony.0 because enabled
      host.raspberrypi	2017-01-16 11:02:00.885	error	instance system.adapter.harmony.0 terminated with code 156 ()
      harmony.0	2017-01-16 11:02:00.866	info	terminating
      harmony.0	2017-01-16 11:02:00.850	warn	client ended
      harmony.0	2017-01-16 11:02:00.844	info	terminating
      harmony.0	2017-01-16 11:02:00.842	info	Scheduled restart.
      harmony.0	2017-01-16 11:01:07.502	info	synced hub config
      harmony.0	2017-01-16 11:01:07.488	info	creating activities and devices
      harmony.0	2017-01-16 11:01:06.547	info	connected to Harmony Hub
      harmony.0	2017-01-16 11:01:05.137	info	connecting to Harmony Hub
      harmony.0	2017-01-16 11:01:05.136	info	discovered Harmony Hub
      harmony.0	2017-01-16 11:01:03.953	info	discover started
      harmony.0	2017-01-16 11:01:03.920	info	hub initialized
      harmony.0	2017-01-16 11:01:03.795	info	starting. Version 0.5.6 in /opt/iobroker/node_modules/iobroker.harmony, node: v4.7.2
      host.raspberrypi	2017-01-16 11:01:01.379	info	instance system.adapter.harmony.0 started with pid 6897
      host.raspberrypi	2017-01-16 11:01:00.365	info	Restart adapter system.adapter.harmony.0 because enabled
      host.raspberrypi	2017-01-16 11:01:00.364	error	instance system.adapter.harmony.0 terminated with code 156 ()
        Pman last edited by
        Wenn ich das Log richtig verstehe machst du jede Minute eine Restart des Adapters. Hast du das unabsichtlich im Admin unter Instanzen so eingestellt?
          @Pman:
          Wenn ich das Log richtig verstehe machst du jede Minute eine Restart des Adapters. `
          Schon, aber was ist code 156??
          81.0k
