    4. [erledigt] Alexa Sprachausgabe hängt
    • Karel Puhli
      Karel Puhli last edited by Karel Puhli
      Mahlzeit!
      Mein Alexa Adapter macht folgende Probleme. Ich muss ihn regelmäßig neustarten, damit die Sprachausgabe funktioniert. Ansonsten bleibt der Echo einfach stumm.
      Im Log nach dem Neustart finde ich keine Fehler.
      alexa2.0	2021-04-19 12:52:52.063	info	(8758) Subscribing to states...
      alexa2.0	2021-04-19 12:52:34.173	info	(8758) Alexa-Push-Connection established. Disable Polling
      alexa2.0	2021-04-19 12:52:30.667	info	(8758) starting. Version 3.8.1 in /opt/iobroker/node_modules/iobroker.alexa2, node: v12.22.1, js-controller: 3.2.16
      host.raspberrypi	2021-04-19 12:52:28.459	info	instance system.adapter.alexa2.0 started with pid 8758
      host.raspberrypi	2021-04-19 12:52:25.986	info	instance system.adapter.alexa2.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      alexa2.0	2021-04-19 12:52:25.343	info	(8736) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      alexa2.0	2021-04-19 12:52:25.341	info	(8736) terminating
      alexa2.0	2021-04-19 12:52:25.340	info	(8736) Alexa-Push-Connection Error: Error: WebSocket was closed before the connection was established
      alexa2.0	2021-04-19 12:52:25.336	info	(8736) Got terminate signal TERMINATE_YOURSELF
      host.raspberrypi	2021-04-19 12:52:25.337	info	stopInstance system.adapter.alexa2.0 send kill signal
      host.raspberrypi	2021-04-19 12:52:25.327	info	stopInstance system.adapter.alexa2.0 (force=false, process=true)
      alexa2.0	2021-04-19 12:52:25.179	info	(8736) Update cookie in adapter configuration ... restarting ...
      alexa2.0	2021-04-19 12:52:19.105	info	(8736) starting. Version 3.8.1 in /opt/iobroker/node_modules/iobroker.alexa2, node: v12.22.1, js-controller: 3.2.16
      host.raspberrypi	2021-04-19 12:52:16.612	info	instance system.adapter.alexa2.0 started with pid 8736
      host.raspberrypi	2021-04-19 12:52:14.028	info	instance system.adapter.alexa2.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      alexa2.0	2021-04-19 12:52:13.383	info	(27346) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      alexa2.0	2021-04-19 12:52:13.381	info	(27346) terminating
      host.raspberrypi	2021-04-19 12:52:13.380	info	stopInstance system.adapter.alexa2.0 send kill signal
      alexa2.0	2021-04-19 12:52:13.379	info	(27346) Got terminate signal TERMINATE_YOURSELF
      host.raspberrypi	2021-04-19 12:52:13.363	info	stopInstance system.adapter.alexa2.0 (force=false, process=true)
      Vielen Dank für Eure Hilfe.
      Systemdata Bitte Ausfüllen
      Hardwaresystem: Raspberry Pi 4 B
      Arbeitsspeicher: 4GB
      Festplattenart: SD-Kart
      Betriebssystem: Raspberry Pi OS
      Node-Version: 1
      Nodejs-Version: 12.x.x
      NPM-Version: 6.x.x
      Dr. Bakterius 1 Reply Last reply Reply Quote 0
      • Dr. Bakterius
        Dr. Bakterius Most Active @Karel Puhli last edited by
        @karel-puhli Schon die Forensuche kennen gelernt? Nein? Dann wird es Zeit! Da gab es in den letzten Tagen einige Beiträge zu diesem Thema ...
        ? 1 Reply Last reply Reply Quote 1
          A Former User @Dr. Bakterius last edited by
          @dr-bakterius Oh wie ich solche Kommentare liebe 👎
          • Negalein
            @Dr-Bakterius hätte @Karel-Puhli mit einem einfachen Link unter die Arme greifen können.
            @Karel-Puhli
            hier findest du die Themen der letzten Tage zu diesem oder ähnlichem Alexa Problem!
            https://forum.iobroker.net/search?term=alexa&in=titles&matchWords=all&sortBy=timestamp&sortDirection=desc&showAs=posts
            Dr. Bakterius 1 Reply Last reply Reply Quote 1
            • Karel Puhli
              Danke Euch!
              @Dr-Bakterius : Inhaltlich haste recht!
              • Dr. Bakterius
                Dr. Bakterius Most Active @Negalein last edited by
                @noah3112 sagte in [erledigt] Alexa Sprachausgabe hängt:
                Das fällt mir schon eine ganze Weile negativ auf. Immer wieder kommen innerhalb kurzer Zeit die selben Fragen. Das bläht nicht nur das Forum unnötig auf, sondern macht es anderen schwer relevante Antworten zu finden. Das ist unnötig! Und viele denken gar nicht daran, dass es andere mit den gleichen Problemen gibt - daher der Wink mit dem Zaunpfahl auf die Suchfunktion.
                @negalein sagte in [erledigt] Alexa Sprachausgabe hängt:
                Hätte ich, und ich helfe auch gerne. Doch so grundlegende, einfache Dinge sollte jeder selbst beherrschen der es schafft ins Internet zu kommen und sich hier zu registrieren.
                Natürlich passiert es auch, dass man nicht immer mit der Suchfunktion auch "sein" Problem findet - ist mir auch schon passiert - aber in diesem Fall braucht man nur die Thread-Betreffe der letzten paar Stunden überfliegen und findet mindestens drei die sich auf das Thema beziehen könnten. Wäre nicht schlecht solche Themen zusammen zu legen. (Hallo Moderator! 😀 )
                Karel Puhli 1 Reply Last reply Reply Quote 2
                • Karel Puhli
                  Karel Puhli @Dr. Bakterius last edited by
                  @dr-bakterius
                  Ich kenne die Suchfunktion und nutze sie auch. In diesem Fall habe ich sie anscheinend nicht sauber genutzt.
                  So, jetzt wieder zu den spannenden und sinnvolen Themen...!
                  • Dr. Bakterius
                    @karel-puhli Sorry wenn gerade du jetzt meinen kleinen Frust abbekommen hast. Nichts für ungut ... 🤝
                    Karel Puhli 1 Reply Last reply Reply Quote 0
                    • Karel Puhli
                      @dr-bakterius Alles gut! 🤝
                      Christian Wöhrle 1 Reply Last reply Reply Quote 0
                      • Christian Wöhrle
                        Christian Wöhrle @Karel Puhli last edited by
                        @karel-puhli 💗 💗
                        Ist das schön, dass ihr euch wieder lieb habt 🙂
                        793
