    2. English
    3. ioBroker general
    4. How to replace null with 0 using alias-manager
    • Tomasz Nowak
      Tomasz Nowak last edited by
      I have an object that returns a value (number) on button press but then it shows null.
      I need to convert that null tu value 0.
      I've tried the alias-manager adapter, but I don't know how to write a proper rule for that.
      This below doesn't seem to work:
      Any help appreciated!
      Homoran AlCalzone 2 Replies Last reply Reply Quote 0
        Homoran Global Moderator Administrators @Tomasz Nowak last edited by
        @tomasz-nowak sagte in How to replace null with 0 using alias-manager:
        I really don't know, but please try val === null?0:val
        Tomasz Nowak 1 Reply Last reply Reply Quote 1
        • Tomasz Nowak
          Tomasz Nowak @Homoran last edited by
          @homoran said in How to replace null with 0 using alias-manager:
          Thanks, but it doesn't seem to work 😞
            can you please try val == null?0:val
            • apollon77
              apollon77 last edited by
              Zeig doch bitte mal dwie das Alias objekt aussieht was da rausfällt.
              • AlCalzone
                AlCalzone Developer @Tomasz Nowak last edited by
                @tomasz-nowak The common.type seems wrong - the original state is numeric. Maybe that confuses the alias function.
                Tomasz Nowak 1 Reply Last reply Reply Quote 0
                • Tomasz Nowak
                  Tomasz Nowak @AlCalzone last edited by
                  @alcalzone I've changed common.type to number - no change.
                  @Homoran Tried also == and no change.
                  So I have this object: SceneId:
                  When I press a mono-switch connected that dimmer I see value "26" for a blink of an eye, than there's noting in that field (I believe its "null"). This null somehow crashes mqtt-broker, so I wanted to change "null" to "0".
                  But in an alias object:
                  Its exactly the same - 26 shows for a blink of the eye and then nothing. Both with val === null?0:val and val == null?0:val.
                  This alias object also crashes mqtt-client adapter with uncaught null exception.
                  This is full config of my alias. I'm not sure if I understand all correctly.
                  • apollon77
                    apollon77 @Tomasz Nowak last edited by
                    @tomasz-nowak Crashes? Logs please 🙂
                    Also I would like to see the Core JSON of the created alias object because that matters (not a UI) 😉
                    Go into Admin please, Objects Tab, go to that state and enable expert mode, klick on pencil on right side, in dialog "raw" and copy the json please here
                    • Tomasz Nowak
                      Tomasz Nowak @apollon77 last edited by
                      @apollon77
                      This is JSON for an alias object:
                        "user": "system.user.admin",
                        "ts": 1619609676629,
                        "common": {
                          "name": "Scene ID",
                          "role": "level",
                          "type": "number",
                          "read": true,
                          "write": true,
                          "alias": {
                            "id": "zwave2.0.Node_014.Scene_Activation.sceneId",
                            "read": "val == null?0:val"
                        "native": {},
                        "acl": {
                          "object": 1636,
                          "owner": "system.user.admin",
                          "ownerGroup": "system.group.administrator",
                          "state": 1636
                        "_id": "alias.0.Fibaro_Dimmer_1_SceneID.sceneId",
                        "type": "state"
                      and this is for the source object:
                        "type": "state",
                        "common": {
                          "role": "level",
                          "read": true,
                          "write": true,
                          "name": "Scene ID",
                          "type": "number",
                          "min": 1,
                          "max": 255
                        "native": {
                          "nodeId": 14,
                          "valueId": {
                            "commandClass": 43,
                            "endpoint": 0,
                            "property": "sceneId"
                        "from": "system.adapter.zwave2.0",
                        "ts": 1619558168447,
                        "_id": "zwave2.0.Node_014.Scene_Activation.sceneId",
                        "acl": {
                          "object": 1636,
                          "state": 1636,
                      Thanks
                      • Tomasz Nowak
                        Tomasz Nowak @Tomasz Nowak last edited by
                        Mqtt-client crash log is here (I've created an issue out of this):
                        https://github.com/Pmant/ioBroker.mqtt-client/issues/45
                        tnowak created this issue in Pmant/ioBroker.mqtt-client
                        closed Uncaught exception: Cannot read property 'from' of null #45
                        • apollon77
                          @tomasz-nowak js-controller Version??
                          • Tomasz Nowak
                            @apollon77
                            • JS-Controller version: 3.2.16
                            • Node version: v12.22.1
                            • Operating system: docker image @ Raspberry OS
                            • all adapters in current released versions
                            • apollon77
                              Ok, jetuzt mal ganz genau: was ist der exakte wert?
                              • In allen screenshots ist gar kein Wert zu sehen - auch nicht "null"
                              • Der mqtt-client Adapter crasht weil der state an sich "null" ist - also NICHT "state wert ist null" sondern es gibt gar keinen state!! Nix
                              • Aliasse greifen dann nicht weil Sie nur Werte mappen - bedeutet also das der resulting Alias auch "keinen Wert hat"
                              Am besten dazu jetzt mal
                              iobroker state get zwave2.0.Node_014.Scene_Activation.sceneId
                              machen und Ausgabe posten.
                              • Tomasz Nowak
                                @apollon77 said in How to replace null with 0 using alias-manager:
                                Yes, no value is seen on the screenshots because there no value at all for most of the time. It gets "26" or "24" depending on number of clicks, but only for a second. Then it returns to empty / null.
                                Now, because mqtt-client can't handle this correctly, I've been trying to alias this object somehow to push it to MQTT anyway. So, I can not rewrite empty object with any custom value (such as "0" for instance)?
                                • Tomasz Nowak
                                  Tomasz Nowak @Tomasz Nowak last edited by Tomasz Nowak
                                  Thats strange:
                                  And I still see this object in ioBroker admin panel
                                  • apollon77
                                    apollon77 last edited by apollon77
                                    Ok nicht englishc.
                                    Nicht Dinge vermischen!!
                                    Es gibt Objekte - das siehst Du im Admin. Und Objekte haben (vielleicht) einen Wert. Ein Wert kann da sein und einen value haben und der Wert kann auch NICHT da sein (weil nie gesetzt wurde, weil expired oder weil gelöscht.
                                    Also: Jetzt wieder zwave2 Frage ... warum existiert der state nicht?
                                    • Tomasz Nowak
                                      @apollon77
                                      That issue I've also reported here 🙂
                                      https://github.com/AlCalzone/ioBroker.zwave2/issues/597
                                      tnowak created this issue in AlCalzone/ioBroker.zwave2
                                      closed Scene_Activation.sceneId null value seems to be crashing mqtt-client #597
                                      • apollon77
                                        @tomasz-nowak ;üsste man umformulieren!
                                        Wie gesagt der crash ist ein Fehler in mqtt-client! Die Frage an zwave2 ist warum der state gelöscht wird
                                          paul53 @Tomasz Nowak last edited by
                                          @tomasz-nowak
                                          If the state expires after a second, use a script:
                                          on({id: 'zwave2.0.Node_014.Scene_Activation.sceneId'}, function(dp) {
                                              setState('0_userdata.0.Fibaro_Dimmer_1_SceneID.sceneId', dp.state.val, true);
                                              setTimeout(function() {
                                                  setState('0_userdata.0.Fibaro_Dimmer_1_SceneID.sceneId', 0, true);
                                              }, 1000);
                                          • Tomasz Nowak
                                            Tomasz Nowak @paul53 last edited by Tomasz Nowak
                                            I've never used Javascript in ioBroker, but I have installed Javascript adapter now, created that channel and object under 0_userdata.0 and......
                                            WOW, it works as it should !!!!!!!!!!!!
                                            I get 26 and 24 values on 1- and 2-click and then the objects turns to 0. And it works with mqtt-client putting it to the broker just fine:
                                            Thank you @paul53 for this quick solution! 🙌
                                            I hope mqtt-client (and probably zwave2) adapters will be address with this issue in the future, but for now I may switch my lights again!
                                            3174
