    4. "iobroker upgrade self" not working [SOLVED]
      miggedy last edited by miggedy
      Systemdata Bitte Ausfüllen
      Hardwaresystem: Pi3
      Arbeitsspeicher: 4GB
      Festplattenart: SD-Karte
      Betriebssystem: Ubuntu
      Node-Version: 12.20.0
      Nodejs-Version: 12.20.0
      NPM-Version: 6.14,.8
      Installationsart: Skript
      System is running without any issues but upgrading it not working. I'm on js-controller 3.2.16 and if I execute iobroker upgrade self I get the following output:
      pi@iobroker-pi4:~ $ iobroker upgrade self
      No connection to databases possible ...
       redis get system.host.iobroker-pi4.alive, error - Connection is closed.
      No repositories defined.
      Cannot get repository under "undefined"
      pi@iobroker-pi4:~ $
        Thomas Braun Most Active @miggedy last edited by Thomas Braun
        @miggedy
        iobroker repo list
        iobroker update
        And please keep your nodeJS installation up-to-date.
          miggedy @Thomas Braun last edited by
          Thanks @thomas-braun, sadly this didn't help.
          pi@iobroker-pi4:~ $ iobroker repo list
          stable      : http://download.iobroker.net/sources-dist.json
          beta        : http://download.iobroker.net/sources-dist-latest.json
          Active repo: beta
          pi@iobroker-pi4:~ $ iobroker update
          pi@iobroker-pi4:~ $ iobroker stop
            @miggedy
            Maybe there is still something running in the background?
            ps aux | grep ^io
              No, nothing is running anymore. That command doesn't return anything.
              Maybe also interesting:
              While iobroker is not running, these commands also fail (but work if iobroker is running):
              Cannot get list: Error: Connection is closed.
              /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:982
                                      for (const name of Object.keys(links)) {
              TypeError: Cannot convert undefined or null to object
                  at Function.keys (<anonymous>)
                  at /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:982:51
                  at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:2615:37)
                  at processImmediate (internal/timers.js:463:21)
              pi@iobroker-pi4:~ $
                @miggedy
                Not sure if this helps but try jumping to the version you want to have:
                3.3.5 is beta-stage:
                Controller "js-controller" : 3.3.5    , installed 3.3.5
                Try
                iobroker stop
                cd /opt/iobroker
                npm install iobroker.js-controller@3.3.5
                iobroker start
                iobroker status
                • crunchip
                  Test this rep
                  Stable
                  http://iobroker.live/repo/sources-dist.json
                  Latest
                  http://iobroker.live/repo/sources-dist-latest.json
                    miggedy @Thomas Braun last edited by miggedy
                    I tested the manual installation @thomas-braun mentioned (npm install...) and this worked. I'm now on 3.3.5 and running iobroker upgrade self now doesn't show any errors anymore (just that it's up-to-date).
                    In case this happens again for the next update I will try the different repo @crunchip mentioned.
                    Thank you both for your support.
