    4. Fehler nach update js-controller 3.3.9
      rewenode last edited by rewenode
      Sicher habe ich irgend eine Ankündigung oder so übersehen.
      Seit dem Update auf 3.3.9 wird mein Log mit folgenden Info-Zeilen vollgemüllt:
      State value to set for "info.0.sysinfo.cpu.currentspeed.coresSpeed" has to be stringified but received type "object"
      info.0	2021-05-14 11:13:25.673	info	(734) State value to set for "info.0.sysinfo.cpu.temperature.cores" has to be stringified but received type "object"
      info.0	2021-05-14 11:13:22.778	info	(734) State value to set for "info.0.sysinfo.cpu.currentspeed.coresSpeed" has to be stringified but received type "object"
      info.0	2021-05-14 11:13:22.705	info	(734) State value to set for "info.0.sysinfo.cpu.temperature.cores" has to be stringified but received type "object"
      info.0	2021-05-14 11:13:19.740	info	(734) State value to set for "info.0.sysinfo.cpu.currentspeed.coresSpeed" has to be stringified but received type "object"
      info.0	2021-05-14 11:13:19.671	info	(734) State value to set for "info.0.sysinfo.cpu.temperature.cores" has to be stringified but received type "object"
      info.0	2021-05-14 11:13:17.386	info	(734) State value to set for "info.0.sysinfo.cpu.currentspeed.coresSpeed" has to be stringified but received type "object"
      info.0	2021-05-14 11:13:17.327	info	(734) State value to set for "info.0.sysinfo.cpu.temperature.cores" has to be stringified but received type "object"
      host.iobroker	2021-05-14 11:13:14.440	info	Updating repository "beta" under "http://download.iobroker.net/sources-dist-latest.json"
      Also alles mit info.0.sysinfo.cpu.
      iob läuft an Sonaten klaglos seit ca. 2jahren im Docker-Container mit:
      node.js - 12.18.3
      npm - 6.14.6
      infoseite zeigt ansonsten alle Adapter als aktuell an.
      Reiner
      Thomas Braun paul53 2 Replies Last reply Reply Quote 0
        Thomas Braun Most Active @rewenode last edited by
        @rewenode
        Mach als guter Beta-Tester ein Issue auf beim info-Adapter.
        paul53 R 2 Replies Last reply Reply Quote 0
          paul53 @rewenode last edited by
          @rewenode sagte: Log mit folgenden Info-Zeilen vollgemüllt:
          Ab Version 3.3 des js-controllers sollen keine Objekte / Arrays mehr in Datenpunkte geschrieben werden, sondern nur noch per JSON.stringify(obj) gewandelte Objekte. Diese Info-Logs sollen die Adapter-Entwickler informieren, dies anzupassen.
          Wenn die Logs stören, stelle die Log-Stufe des js-controllers in der Datei /opt/iobroker/iobroker-data/iobroker.json auf "warn" (anschließend ioBroker neu starten).
            paul53 @Thomas Braun last edited by
            @thomas-braun sagte: Mach als guter Beta-Tester ein Issue auf beim info-Adapter.
            Gibt es bereits.
              rewenode @Thomas Braun last edited by
              @thomas-braun sagte in Fehler nach update js-controller 3.3.9:
              @rewenode
              Danke für die Info. War mir gar nicht bewusst, dass ich die beta installiert hatte.
              sry
                Thomas Braun Most Active @rewenode last edited by Thomas Braun
                @rewenode
                Deswegen steht es sogar in deinem LOG drin:
                Stell es auf 'default/stable' zurück.
                • crunchip
                  crunchip Forum Testing Most Active @Thomas Braun last edited by
                  @thomas-braun und auch noch riesig ganz oben angeheftet im Forum
                  31.7k
                  79.8k
                  js-controller 3.3.9
