    4. [Frage] zu Log File Einträgen - sql history
    • nieIP
      nieIP last edited by
      Hallo
      folgende Zeilen "WARNING" habe ich im Log File, wenn ich den sql Adapter neu starte.
      Ich verstehe, das etwas nicht gefunden wurde, aber was ??
      host.raspi-3	2017-01-22 00:17:14.592	warn	stopInstance system.adapter.dwd.0 not scheduled
      host.raspi-3	2017-01-22 00:17:14.591	info	stopInstance system.adapter.dwd.0
      host.raspi-3	2017-01-22 00:17:14.590	info	"system.adapter.dwd.0" disabled
      host.raspi-3	2017-01-22 00:17:14.590	info	object change system.adapter.dwd.0
      WARNING:	2017-01-22 00:17:09.222	error	cannot find logs with id = 80334195
      WARNING:	2017-01-22 00:17:08.869	error	cannot find logs with id = 80332676
      WARNING:	2017-01-22 00:17:08.781	error	cannot find logs with id = 80332596
      WARNING:	2017-01-22 00:17:08.766	error	cannot find logs with id = 80332586
      WARNING:	2017-01-22 00:17:08.071	error	cannot find logs with id = 80332462
      sql.0	2017-01-22 00:17:05.688	info	Connected to mysql
      sql.0	2017-01-22 00:17:05.670	info	enabled logging of hm-rpc.1.000313C9906EDE.1.ACTUAL_TEMPERATURE
      sql.0	2017-01-22 00:17:05.669	info	enabled logging of hm-rpc.1.000393C98D1E6A.1.SET_POINT_TEMPERATURE
      sql.0	2017-01-22 00:17:05.669	info	enabled logging of hm-rpc.1.0000D3C98C9B3A.1.STATE
      sql.0	2017-01-22 00:17:05.669	info	enabled logging of hm-rpc.1.0001D3C990BF8F.6.VOLTAGE
      sql.0	2017-01-22 00:17:05.668	info	enabled logging of hm-rega.0.25660
      • apollon77
        apollon77 last edited by
        Diese Warnings kommen von Messages aus dem System.
        Kommt das IMMER wenn du sql neustartest?
        Nimmst Du Redis? Starte des Redis mal neu …
        • nieIP
          Hallo
          ja die Meldungen kommen immer.
          Keine Ahnung was "Redis" ist.
          raspi-3	2017-01-22 22:47:56.204	error	WARNING: cannot find logs with id = 80335670
          raspi-3	2017-01-22 22:47:55.845	error	WARNING: cannot find logs with id = 80335334
          raspi-3	2017-01-22 22:47:55.720	error	WARNING: cannot find logs with id = 80335323
          raspi-3	2017-01-22 22:47:55.714	error	WARNING: cannot find logs with id = 80335322
          raspi-3	2017-01-22 22:47:55.712	error	WARNING: cannot find logs with id = 80335321
          raspi-3	2017-01-22 22:47:55.709	error	WARNING: cannot find logs with id = 80335320
          raspi-3	2017-01-22 22:47:55.707	error	WARNING: cannot find logs with id = 80335319
          raspi-3	2017-01-22 22:47:54.832	error	WARNING: cannot find logs with id = 80334928
          sql.0	2017-01-22 22:47:53.910	info	sql.0 Connected to mysql
          • apollon77
            Kann mir nicht erklären wo das herkommt …
            @Bluefox: Irgendeine Idee?
            • Goersch
              Goersch last edited by
              hier gleiches Problem - nach iobroker restart wieder OK
              Änderung, bevor die ganzen log-Ausgaben kommen:
              • zweite javascript instanz auf einem zweiten raspi angelegt (javascript.0 auf raspi1/javascript.1 auf raspi2)
              • ein script in die instanz javascript.1 verschoben
              • ping-Instanz auch dem raspi2 zugeordnet
              dann kommen relativ schnell viele Meldungen in der Form
              ` > 2017-04-06 17:40:01.955 - [32minfo[39m: javascript.0 Start javascript script.js.common.Heizung.Einstellungen
              2017-04-06 17:40:02.018 - [31merror[39m: javascript.0 script.js.common.Heizung.Einstellungen: Cannot use sync getState, use callback instead getState("javascript.0.Heizung.Einstellungen.Raum", function (err, state){});
              2017-04-06 17:40:02.032 - [31merror[39m: javascript.0 script.js.common.Heizung.Einstellungen: TypeError: Cannot read property 'val' of undefined
              at ladeRaumEinstellungen (script.js.common.Heizung.Einstellungen:151:32)
              at script.js.common.Heizung.Einstellungen:229:1 `
              bis dann diese Ausgaben anfangen
              ` > 2017-04-06 18:29:33.705 - [31merror[39m: admin.0 WARNING: cannot find log with id = 61173598
              2017-04-06 18:29:33.706 - [31merror[39m: admin.0 WARNING: cannot find log with id = 14111021
              2017-04-06 18:29:33.706 - [31merror[39m: admin.0 WARNING: cannot find log with id = 8734500
              2017-04-06 18:29:33.708 - [31merror[39m: admin.0 WARNING: cannot find log with id = 30731845
              2017-04-06 18:29:33.708 - [31merror[39m: admin.0 WARNING: cannot find log with id = 71745564 `
              • kmxak
                (achtung anfänger versucht zu helfen :mrgreen: )
                Also ich vermute hier einen Fehler im javascript.
                Und der SQL Adapter versucht einen Eintrag zu finden den es nicht gibt. Vermutlich durch einen Script fehler.
                Ich würde das Script common.Heizung.Einstellungen mal durchgehen ob da alles passt
                • Goersch
                  da passt alles - das Skript funktioniert fehlerfrei. Die Fehlermeldungen traten leider auch bei anderen Skripten auf. Nach dem restart vom iobroker war auch alles wieder ok.
                  • Goersch
                    nun ähnlicher Fehler (zumindestens die ganzen callback Fehler werden ausgegeben - nicht nur beim Skript im Beispiel):
                    ` > 2017-04-07 14:21:32.800 - [32minfo[39m: javascript.0 Start javascript script.js.common.Allgemein.GMPS
                    2017-04-07 14:21:32.807 - [31merror[39m: javascript.0 script.js.common.Allgemein.GMPS: Cannot use sync getState, use callback instead getState("javascript.0.GMPS.Aufwachzeit", function (err, state){});
                    2017-04-07 14:21:32.810 - [31merror[39m: javascript.0 script.js.common.Allgemein.GMPS: TypeError: Cannot read property 'val' of undefined
                    at initWOL (script.js.common.Allgemein.GMPS:110:38)
                    at script.js.common.Allgemein.GMPS:107:1 `
                    Was habe ich geändert:
                    • in der Instanz javascript.0 den Parameter "Nicht auf alle Zustände beim Start abonieren" aktiviert
                    • danach hat sich die Instanz neugestartet und dann fing der Fehlermeldeschwal an
                    nach "iobroker restart" wieder alles ok
