    4. Backitup Instalieren Hilfe
      tola511 last edited by
      Hallo ich bekomme Backitup nicht installiert. ich möchte vom Raspberry 2 zu einem Windows umziehen.
      hier die Meldung
      $ ./iobroker add backitup  --host raspberrypi
       Cannot read system.config: undefined (OK when migrating or restoring)
      NPM version: 6.4.1
      npm install iobroker.backitup@2.1.6 --loglevel error --prefix "/opt/iobroker" (System call)
      npm
       ERR! code Z_BUF_ERRORnpm ERR! errno -5
      npm
       ERR! zlib: unexpected end of file
      npm ERR! A complete log of this run can be found in:npm ERR!     /home/iobroker/.npm/_logs/2021-05-30T12_41_54_713Z-debug.log
      ERROR: host.raspberrypi Cannot install iobroker.backitup@2.1.6: 251
      ERROR: process exited with code 25
      Thomas Braun T 2 Replies Last reply Reply Quote 0
        Thomas Braun Most Active @tola511 last edited by
        @tola511
        cd /opt/iobroker
        npm cache clear --force
          tola511 @tola511 last edited by
          Abend
          Jetzt komme ich auf dem windows Rechner nicht weiter.
          Backup wurde durchgeführt aber jetzt komme ich nicht mehr auf den io über localhost:8081
          C:\Program Files\iobroker\SmartHome3>iobroker status [all]
          At least one iobroker host is running.
          SYSTEM/memoryLimitMB: 0
          SYSTEM/hostname:
          SYSTEM/statisticsInterval: 15000
          SYSTEM/checkDiskInterval: 300000
          SYSTEM/noChmod: false
          SYSTEM/instanceStartInterval: 2000
          SYSTEM/compact: false
          SYSTEM/allowShellCommands: false
          SYSTEM/memLimitWarn: 100
          SYSTEM/memLimitError: 50
          MULTIHOSTSERVICE/enabled: false
          MULTIHOSTSERVICE/secure: true
          NETWORK/IPv4: true
          NETWORK/IPv6: true
          OBJECTS/type: file
          OBJECTS/host: 127.0.0.1
          OBJECTS/port: 9001
          OBJECTS/user:
          OBJECTS/pass:
          OBJECTS/noFileCache: false
          OBJECTS/connectTimeout: 2000
          OBJECTS/writeFileInterval: 5000
          OBJECTS/OPTIONS/retryStrategy: (reconnectCount) => {
                      if (!ready && initError && ignoreErrors) return new Error('No more tries');
                      if (this.stop) return new Error('Client has stopped ... no retries anymore');
                      if (ready && reconnectCount >=retry_max_count) return new Error('Stop trying to reconnect');
                      // A function that receives an options object as parameter including the retry attempt,
                      // the total_retry_time indicating how much time passed since the last time connected,
                      // the error why the connection was lost and the number of times_connected in total.
                      // If you return a number from this function, the retry will happen exactly after that
                      // time in milliseconds. If you return a non-number, no further retry will happen and
                      // all offline commands are flushed with errors. Return an error to return that
                      // specific error to all offline commands.
                      if (!ready) return 300;
                      return retry_max_delay;
                      /*if (options.error.code === 'ECONNREFUSED') {
                          // End reconnecting on a specific error and flush all commands with a individual error
                          return new Error('The server refused the connection');
                      if (options.total_retry_time > 1000 * 60 * 60) {
                          // End reconnecting after a specific timeout and flush all commands with a individual error
                          return new Error('Retry time exhausted');
                      if (options.times_connected > 10) {
                          // End reconnecting with built in error
                          return undefined;
                      // reconnect after
                      return Math.max(options.attempt * 100, 3000);*/
          OBJECTS/OPTIONS/enableReadyCheck: true
          OBJECTS/OPTIONS/host: 127.0.0.1
          OBJECTS/OPTIONS/port: 9001
          OBJECTS/OPTIONS/db: 0
          OBJECTS/OPTIONS/family: 0
          OBJECTS/BACKUP/disabled: false
          OBJECTS/BACKUP/files: 24
          OBJECTS/BACKUP/hours: 48
          OBJECTS/BACKUP/period: 120
          OBJECTS/BACKUP/path:
          OBJECTS/maxQueue: 1000
          STATES/type: file
          STATES/host: 127.0.0.1
          STATES/port: 9000
          STATES/maxQueue: 1000
          STATES/user:
          STATES/pass:
          STATES/connectTimeout: 2000
          STATES/writeFileInterval: 30000
          STATES/OPTIONS/retryStrategy: (reconnectCount) => {
                          return undefined;
                      // reconnect after
          STATES/OPTIONS/enableReadyCheck: true
          STATES/OPTIONS/host: 127.0.0.1
          STATES/OPTIONS/port: 9000
          STATES/OPTIONS/db: 0
          STATES/OPTIONS/family: 0
          STATES/BACKUP/disabled: false
          STATES/BACKUP/files: 24
          STATES/BACKUP/hours: 48
          STATES/BACKUP/period: 120
          STATES/BACKUP/path:
          LOG/level: info
          LOG/maxDays: 7
          LOG/noStdout: true
          LOG/TRANSPORT/FILE1/type: file
          LOG/TRANSPORT/FILE1/enabled: true
          LOG/TRANSPORT/FILE1/filename: log/iobroker
          LOG/TRANSPORT/FILE1/fileext: .log
          LOG/TRANSPORT/SYSLOG1/type: syslog
          LOG/TRANSPORT/SYSLOG1/enabled: false
          LOG/TRANSPORT/SYSLOG1/host: localhost
          LOG/TRANSPORT/SYSLOG1/protocol: udp4
          LOG/TRANSPORT/SYSLOG1/localhost: iobroker
          dataDir: ../../iobroker-data/
          C:\Program Files\iobroker\SmartHome3>iobroker start
          2021-06-01 23:30:37,286 INFO  - Starting the service with id 'iobroker(SmartHome3)'
          2021-06-01 23:30:37,369 FATAL - WMI Operation failure: ServiceAlreadyRunning
          WMI.WmiException: ServiceAlreadyRunning
             bei WMI.WmiRoot.BaseHandler.CheckError(ManagementBaseObject result)
             bei WMI.WmiRoot.InstanceHandler.Invoke(Object proxy, MethodInfo method, Object[] args)
             bei winsw.WrapperService.Run(String[] _args, ServiceDescriptor descriptor)
             bei winsw.WrapperService.Main(String[] args)
          hoffe ihr könnt mir wieder helfen
          backitup fehler update backup errors
