    4. Aktuelle Warn und Fehlermeldungen bei Installation
      Hallo Bluefox,
      ich habe gerade nochmal eine neue Installation auf einem Cubietruck auf der HDD aufgesetzt. Mal wieder mit nodejs v6.
      Folgendes stand alles im Log:
      ! npm install iobroker.js-controller --production --prefix /opt/iobroker npm WARN deprecated letsencrypt@2.1.8: letsencrypt has been renamed to greenlock. Please find it at npm greenlock npm WARN deprecated localhost.daplie.com-certificates@1.2.5: Moved to localhost.daplie.me-certificates (node:1110) DeprecationWarning: crypto.pbkdf2 without specifying a digest is deprecated. Please specify a digest npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/package.json' npm WARN iobroker No description npm WARN iobroker No repository field. npm WARN iobroker No README data npm WARN iobroker No license field. npm install iobroker.admin --production --prefix /opt/iobroker Write "./iobroker start" to start the ioBroker Auto-start was enabled. Write "update-rc.d -f iobroker.sh remove" to disable auto-start iobroker is started. Go to "http://ip-addr:8081" to open the admin UI. /opt/iobroker └─┬ iobroker@0.7.1 └─┬ yargs@4.8.1 ├─┬ cliui@3.2.0 │ ├─┬ strip-ansi@3.0.1 │ │ └── ansi-regex@2.1.1 │ └── wrap-ansi@2.1.0 ├── decamelize@1.2.0 ├── get-caller-file@1.0.2 ├── lodash.assign@4.2.0 ├─┬ os-locale@1.4.0 │ └─┬ lcid@1.0.0 │ └── invert-kv@1.0.0 ├─┬ read-pkg-up@1.0.1 │ ├─┬ find-up@1.1.2 │ │ ├── path-exists@2.1.0 │ │ └─┬ pinkie-promise@2.0.1 │ │ └── pinkie@2.0.4 │ └─┬ read-pkg@1.1.0 │ ├─┬ load-json-file@1.1.0 │ │ ├── graceful-fs@4.1.11 │ │ ├─┬ parse-json@2.2.0 │ │ │ └─┬ error-ex@1.3.0 │ │ │ └── is-arrayish@0.2.1 │ │ ├── pify@2.3.0 │ │ └─┬ strip-bom@2.0.0 │ │ └── is-utf8@0.2.1 │ ├─┬ normalize-package-data@2.3.5 │ │ ├── hosted-git-info@2.2.0 │ │ ├─┬ is-builtin-module@1.0.0 │ │ │ └── builtin-modules@1.1.1 │ │ ├── semver@5.3.0 │ │ └─┬ validate-npm-package-license@3.0.1 │ │ ├─┬ spdx-correct@1.0.2 │ │ │ └── spdx-license-ids@1.2.2 │ │ └── spdx-expression-parse@1.0.4 │ └── path-type@1.1.0 ├── require-directory@2.1.1 ├── require-main-filename@1.0.1 ├── set-blocking@2.0.0 ├─┬ string-width@1.0.2 │ ├── code-point-at@1.1.0 │ └─┬ is-fullwidth-code-point@1.0.0 │ └── number-is-nan@1.0.1 ├── which-module@1.0.0 ├── window-size@0.2.0 ├── y18n@3.2.1 └─┬ yargs-parser@2.4.1 └── camelcase@3.0.0 ! npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/package.json' npm WARN iobroker No description npm WARN iobroker No repository field. npm WARN iobroker No README data npm WARN iobroker No license field. !
      Kann / Muss man was gegen die beiden WARN zu Anfang machen?
      und mich stört besonders:
      Einmal vor dem Tree und einmal danach.
