    4. Kein Pairing bei ZIGBEE nach neu Installation möglich
      bullhead last edited by
      Systemdata Bitte Ausfüllen
      Hardwaresystem: PI 4B
      Arbeitsspeicher: 4GB
      Festplattenart: SSD
      Betriebssystem: Mac
      Node-Version: 12.22.1
      Nodejs-Version: 12.22.1
      NPM-Version: 6.14.12
      Installationsart: Skript und Manuell
      Image genutzt: Nein
      Ort/Name der Imagedatei: Link
      Hallo habe Iobroker neu installiert und nur den zigbee adapter, wenn ich auf pairing klicke bekomme ich diese Meldung
      Error: Failed to open the network: Error: SRSP - UTIL - ledControl after 6000ms
          at Timeout._onTimeout (/opt/iobroker/node_modules/zigbee-herdsman/dist/utils/waitress.js:37:35)
          at listOnTimeout (internal/timers.js:554:17)
          at processTimers (internal/timers.js:497:7). undefined
      Pairing started
      und im LOG kommt das
      zigbee.0	2021-06-03 10:10:18.625	error	at processTimers (internal/timers.js:497:7)
      zigbee.0	2021-06-03 10:10:18.625	error	at listOnTimeout (internal/timers.js:554:17)
      zigbee.0	2021-06-03 10:10:18.625	error	at Timeout._onTimeout (/opt/iobroker/node_modules/zigbee-herdsman/dist/utils/waitress.js:37:35)
      zigbee.0	2021-06-03 10:10:18.625	error	(9410) Failed to open the network: Error: SRSP - UTIL - ledControl after 6000ms
      zigbee.0	2021-06-03 10:10:12.378	info	(9410) Zigbee: allowing new devices to join.
      zigbee.0	2021-06-03 02:51:12.107	error	at processTimers (internal/timers.js:497:7)
      zigbee.0	2021-06-03 02:51:12.107	error	at listOnTimeout (internal/timers.js:554:17)
      zigbee.0	2021-06-03 02:51:12.107	error	at Timeout._onTimeout (/opt/iobroker/node_modules/zigbee-herdsman/dist/utils/waitress.js:37:35)
      zigbee.0	2021-06-03 02:51:12.107	error	(9410) Failed to open the network: Error: SRSP - UTIL - ledControl after 6000ms
      zigbee.0	2021-06-03 02:51:05.851	info	(9410) Zigbee: allowing new devices to join.
      zigbee.0	2021-06-03 02:51:00.138	info	(9410) Zigbee started
      zigbee.0	2021-06-03 02:51:00.136	info	(9410) Currently no devices.
      zigbee.0	2021-06-03 02:51:00.121	info	(9410) --> transmitPower : normal
      zigbee.0	2021-06-03 02:51:00.119	info	(9410) Unable to disable LED, unsupported function.
      zigbee.0	2021-06-03 02:50:54.104	info	(9410) Coordinator firmware version: {"type":"zStack12","meta":{"transportrev":2,"product":0,"majorrel":2,"minorrel":6,"maintrel":3,"revision":20182308}}
      zigbee.0	2021-06-03 02:50:51.897	info	(9410) Installed Version: iobroker.zigbee@1.5.6
      zigbee.0	2021-06-03 02:50:51.612	info	(9410) Starting Zigbee npm ...
      zigbee.0	2021-06-03 02:50:51.517	info	(9410) starting. Version 1.5.6 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.22.1, js-controller: 3.2.16
      wo liegt da mein Problem
      Schon mal Danke
      • E
        eMd @bullhead last edited by
        @bullhead
        Welchen Stick hast du?
          bullhead @eMd last edited by
          @emd
          oh ganz vergessen das mit rein zu schreiben denn CC2530
          • E
            eMd last edited by
            Der ist auch schon älter. Ich habe die gleichen Probleme wie du, alte Geräte funktionieren, pairing nicht möglich...
            Ich warte auf ein Update...
              bullhead @eMd last edited by bullhead
              Am besten einen neuen kaufen aber nur welchen
              zum aufspielen habe ich keinen cc debugger dann kauf ich mir gleich das CC26X2R1
