    3. Cloud Dienste
    4. iot Adapter stürzt ab startet nicht mehr
      Flubfee last edited by
      Nachdem mein iot Adapter mehrere Wochen problemlos mit GoogleHome zusammen lief, lässt er sich ein paar Tagen nicht mehr starten. Am Anfang waren es im wesentlichen, jetzt kommt sowas:
      host.rotshio	2021-06-08 21:47:16.343	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.iot/lib/googleHome.js:10:5)
      host.rotshio	2021-06-08 21:47:16.343	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:74:18)
      host.rotshio	2021-06-08 21:47:16.343	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:887:19)
      host.rotshio	2021-06-08 21:47:16.343	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:708:14)
      host.rotshio	2021-06-08 21:47:16.342	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:863:32)
      host.rotshio	2021-06-08 21:47:16.342	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1027:10)
      host.rotshio	2021-06-08 21:47:16.342	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:963:27)
      host.rotshio	2021-06-08 21:47:16.342	error	Caught by controller[0]: at wrapSafe (internal/modules/cjs/loader.js:915:16)
      host.rotshio	2021-06-08 21:47:16.341	error	Caught by controller[0]: SyntaxError: Unexpected identifier
      host.rotshio	2021-06-08 21:47:16.341	error	Caught by controller[0]: ^^^^^^^^^^^^^^^^
      host.rotshio	2021-06-08 21:47:16.340	error	Caught by controller[0]: rar patternDirection = {role: /^indicatoR\.dirgction$/, indic�to2: true, " " ` ` name: 'DIRECUION',0 required: fal
      host.rotshio	2021-06-08 21:47:16.339	error	Caught by controller[0]: /opt/iobroker/node_modules/iobroker.type-detector/index.js:103
      host.rotshio	2021-06-08 21:47:14.486	info	instance system.adapter.iot.0 started with pid 3296
      host.rotshio	2021-06-08 21:46:44.449	info	Restart adapter system.adapter.iot.0 because enabled
      host.rotshio	2021-06-08 21:46:44.449	error	instance system.adapter.iot.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      Habe alles auf den neuesten Stand gebarch und ein paar Adapter ausgeschaltet, um RAM Probelem auf dem Rasp3B auszuschliessen.
      Vielen Dank im voraus für Eure Hilfe.
        Homoran Global Moderator Administrators @Flubfee last edited by
        @flubfee sagte in iot Adapter stürzt ab startet nicht mehr:
        sind immer noch 15!
        da ist mit Sicherheit dein RAM aufgebraucht.
          Flubfee @Homoran last edited by
          Nun ja, bis vor 3 Tagen liefs ohne Probleme.
          Gut das Du sicher bist, aber wie kann ich es messen, um die gleiche Sicherheit zu gewinnen?
            hast du doch gerade gemacht.
            im Moment ist zwar Ruhe, aber dein SWAP ist angeknabbert.
            Da gsb es also eine Zeit, als das RAM nicht mehr reichte.
            evtl. bei einem backup(??)
              Dafür ist das Swap ja da.... Und Backup soll ja nicht das laufende System zerschiessen.
                Thomas Braun Most Active @Flubfee last edited by Thomas Braun
                @flubfee
                100MB Swap ist für nix da, viel zu klein für irgendwas. Da kannst du nur schauen ob dir der Speicher mal ausgegangen ist.
                Ich würde jedenfalls sagen, das Ding geht in die Knie, wenn da was 'dickes' gestartet wird. Z.B. ein Backup.
                  Flubfee @Thomas Braun last edited by
                  Schön, Backup Adapter ist wieder ausgeschaltet.
                  Das ist nicht mein Problem, sondern iot....
                    @flubfee
                    Vielleicht auch was anderes.
                    which nodejs node npm && nodejs -v && node -v && npm -v && apt policy nodejs
                    mal anschauen. Bitte in CodeTags, nicht als Screenshot.
                      Danke Thomas,
                      der Gedanke kam mir vor ein paar Tagen auch schon:
                      pi@rotshio:~ $ which nodejs node npm && nodejs -v && node -v && npm -v && apt policy nodejs
                      /usr/bin/nodejs
                      /usr/bin/node
                      /usr/bin/npm
                      v12.22.1
                      v12.22.1
                      6.14.12
                      nodejs:
                        Installiert:           12.22.1-1nodesource1
                        Installationskandidat: 12.22.1-1nodesource1
                        Versionstabelle:
                       *** 12.22.1-1nodesource1 500
                              500 https://deb.nodesource.com/node_12.x buster/main armhf Packages
                              100 /var/lib/dpkg/status
                           10.24.0~dfsg-1~deb10u1 500
                      pi@rotshio:~ $
                        @flubfee
                        Gut, das passt.
                        iobroker update --version
                          Welch Wunder, die neueste iot Version 1.8.22 löst das Problem.
                          • haselchen
                            haselchen Most Active @Flubfee last edited by
                            @flubfee
                            Dann bitte ein (GELÖST) vor Deinen Threadtitel
                            258
