    4. Warning im Script?
    Warning im Script?
    • hg6806
      hg6806 Most Active last edited by hg6806
      habe hier immer ein Warning:
      21:13:33.999	warn	javascript.0 (1386) at Object.<anonymous> (script.js.common.Sonstiges.Pool-Solar_aktivieren:8:5)
      on({id: "mqtt.0.Wemos9-Pool.Pool-Solar-Temp.Pool-Solar-Temp"/*/Wemos9-Pool/Pool-Solar-Temp/Pool-Solar-Temp*/, change: "ne"}, async function (obj) {
        var value = obj.state.val;
        if (getState("mqtt.0.Wemos9-Pool.Pool-Solar-Temp.Pool-Solar-Temp").val > getState("mqtt.0.Wemos9-Pool.Pooltemperatur.Pooltemperatur").val + 1) {
          setState("mqtt.0.Wemos9-Pool.Poolpumpe2.GPIO.4"/*/Wemos9-Pool/Poolpumpe2/GPIO/4*/, 0);
        if (getState("mqtt.0.Wemos9-Pool.Pool-Solar-Temp.Pool-Solar-Temp").val < getState("mqtt.0.Wemos9-Pool.Pooltemperatur.Pooltemperatur").val + 0.2) {
          setState("mqtt.0.Wemos9-Pool.Poolpumpe2.GPIO.4"/*/Wemos9-Pool/Poolpumpe2/GPIO/4*/, 1);
      Woher kommt das?
        fastfoot @hg6806 last edited by
        @hg6806 Im LOG Tab findest du mehr Info dazu
        hg6806 1 Reply Last reply Reply Quote 0
        • hg6806
          hg6806 Most Active @fastfoot last edited by
          @fastfoot
          javascript.0
          2021-06-17 21:29:47.978	warn	at processImmediate (internal/timers.js:461:21)
          javascript.0
          2021-06-17 21:29:47.978	warn	at Immediate._onImmediate (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5555:41)
          javascript.0
          2021-06-17 21:29:47.978	warn	at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:502:29)
          javascript.0
          2021-06-17 21:29:47.977	warn	at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1075:38)
          javascript.0
          2021-06-17 21:29:47.977	warn	at Object.<anonymous> (script.js.common.Sonstiges.Pool-Solar_aktivieren:8:5)
          javascript.0
          2021-06-17 21:29:47.977	warn	at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1427:20)
          javascript.0
          2021-06-17 21:29:47.975	warn	You are assigning a number to the state "mqtt.0.Wemos9-Pool.Poolpumpe2.GPIO.4" which expects a string. Please fix your code to use a string or change the state type to number. This warning might become an error in future versions
          Das sind ala Warning zu Javascript
            fastfoot @hg6806 last edited by fastfoot
            @hg6806 die Warnung besagt dass ein Text erwartet wird, keine Zahl. Probiere also Steuern mit "0" und "1" anstatt 0 und 1
            • hg6806
              @fastfoot
              Danke sieht gut aus.
