    4. Adapter node-red installation Fehler
      ckuratle last edited by
      Platform: Windows
      Architecture: x64
      CPUs: 4
      Speed: 1596 MHz
      Model: Intel(R) Core(TM) i5-5250U CPU @ 1.60GHz
      RAM: 7.8 GB
      System uptime: 00:00:00
      Node.js: v14.17.1
      NPM: 6.14.13
      adapters count: 347
      Disk size: 221.2 GiB
      Disk free: 120.3 GiB
      Uptime: 00:58:35
      Active instances: 6
      Fehler
      $ ./iobroker add node-red --host NUC2(SmartHome)
      NPM version: 6.14.13
      npm install iobroker.node-red@2.3.0 --unsafe-perm --loglevel error --prefix "C:/Program Files/iobroker/SmartHome" (System call)
      npm
      ERR! code EEXISTnpm ERR! path C:\Program Files\iobroker\SmartHome\node_modules\mime\cli.jsnpm ERR! dest C:\Program Files\iobroker\SmartHome\mime
      npm ERR!
      EEXIST: file already exists, cmd shim 'C:\Program Files\iobroker\SmartHome\node_modules\mime\cli.js' -> 'C:\Program Files\iobroker\SmartHome\mime'npm ERR! File exists: C:\Program Files\iobroker\SmartHome\mimenpm ERR! Remove the existing file and try again, or run npmnpm ERR! with --force to overwrite files recklessly.
      npm ERR! A complete log of this run can be found in:npm ERR! C:\WINDOWS\ServiceProfiles\iobroker(SmartHome)\AppData\Roaming\npm-cache_logs\2021-06-19T14_38_42_273Z-debug.log
      ERROR: host.NUC2(SmartHome) Cannot install iobroker.node-red@2.3.0: 1
      ERROR: process exited with code 25
      • Glasfaser
        Glasfaser last edited by Glasfaser
        @ckuratle sagte in Adapter node-red installation Fehler:
        cd /opt/iobroker
        npm install iobroker.node-red@2.3.0 --force
          ckuratle @Glasfaser last edited by
          @glasfaser said in Adapter node-red installation Fehler:
          opt
          Danke, aber danach wollte der IOBroker nicht mehr.
          Nach der Neu-Installation habe ich als ersten Adapter den NodeRed installiert: Es hat funktioniert. Danach auch die beiden nächsten, Digitalstrom und SolarLog funktionieren
