    2. English
    3. ioBroker general
    4. iobroker AVM tr-064.0 addon
      leotzian last edited by
      Hi to all I am very new to iobroker and I want some help if anyone knows.
      I have a Fritzbox and my goal is to schedule a reboot when I want at a specific time.
      I am searching the net for about a month, and I final found iobroker.
      I had a synology nas and docker installed, I had managed to install iobroker in a conatiner and it is working good.
      I had also installed and AVM tr-064.0 adaptor ( if I call it right )
      Does anyone knows if it is possible to reboot my fritzbox at a certain time? using the addon I see my fritz data but then I don't know what to do, the forum for this plugin is in German and I don't know German.
      If this post is not in the correct category please the admin to move it.
      Thanks in advance.
      A ? 2 Replies Last reply Reply Quote 0
        Ahnungsbefreit @leotzian last edited by
        @leotzian hi, I can't check this now but as far as I remember reboot is not supported by the interface from AVM and hence also not by the adapter.
          A Former User @leotzian last edited by
          @leotzian Hi,
          does the tr-064 adapter working fine?
          The states in the objects are created?
          Must be look like here:
          If this is fine, you can reboot the Fritzbox with the button "reboot".
          If this works, create a small blockly or javascript like this ( here it reboots every night at 1 )
          or in javascript:
          schedule("0 1 * * *", async function () {
            setState("tr-064.0.states.reboot"/*reboot*/, true);
            Ahnungsbefreit @Guest last edited by
            @ilovegym is of course right, I did not remember this, maybe because I don't need to reboot my fritz.box usually.
              Hi all thanks for the answers @ilovegym yes I can see the state reboot and it is working
              I have the first screenshot you had posted, I cannot know where to find the second, as I had told you I am a newby with iobroker, Can I make something like a switch to activate it when I want?
              To explain why I want this, for some reason when DSL reconnects for some reason during the day the Down/Up it locks is 40% lower if connection happens at 3 -5AM in the morning, but this time I am sleeping, so I want when it is nessesarry to activate the reboot once in that case at 4AM.
              Thanks all again
                @leotzian Hi,
                the second screen is from the javascript-adapter, this is a nice interface to create rules, scripts etc..
                with this javascript adapter you can easy create schedules like you need.
                  leotzian @Guest last edited by leotzian
                  @ilovegym said in iobroker AVM tr-064.0 addon:
                  screenshot.png javascript-adapter
                  Do you mean Script Engine? I had installed this but I don;t see the interface like yours, then I searchedadaters menu for "Javascript-adapter" and I have no result a little help more please!
                  I had installed this one BUT I cannt see the interface you had posted before
                  • David G.
                    David G. @leotzian last edited by David G.
                    @leotzian
                      leotzian @David G. last edited by
                      @david-g thanks my friend I understood what is going on, I will try myself now you had helped me enough, I will translate the words, I will found the solution now
                      Thank you all for your help
