    2. English
    3. Cloud services
    4. Simple_api adapter syntax problem with esp32
    • kristfrizh
      kristfrizh last edited by kristfrizh
      Hii
      I have a project to send data using MQTT and restfull api using simple_api adapter.
      I have succed to send data using post via web browser
      simple api wiki
      Right now, i want to use esp32 with post and get http to sending and receive data.
      I want post the data the same like this in web browser via esp32
      192.168.0.120:8087/set/try_simple_api2?value=2
      I have build some code like this but still sent got nothing.
      anyone can help me?
      thank you very much regards
      #include <WiFi.h>
      #include <HTTPClient.h>
      const char* ssid = "asdasd";
      const char* password = "asdasd";
      const char* serverName = "http://192.168.0.120:8087/";
      unsigned long lastTime = 0;
      unsigned long timerDelay = 2000;
      void setup() {
        Serial.begin(115200);
        WiFi.begin(ssid, password);
        Serial.println("Connecting");
        while(WiFi.status() != WL_CONNECTED) {
          delay(500);
          Serial.print(".");
        Serial.println("");
        Serial.print("Connected to WiFi network with IP Address: ");
        Serial.println(WiFi.localIP());
        Serial.println("Timer set to 5 seconds (timerDelay variable), it will take 5 seconds before publishing the first reading.");
      void loop() {
        if ((millis() - lastTime) > timerDelay) {
          if(WiFi.status()== WL_CONNECTED){
            HTTPClient http;
            http.begin(serverName);
         http.addHeader("Content-Type", "text/plain");
            int httpResponseCode = http.POST("/set/try_simple_api2?value=7");
            Serial.print("HTTP Response code: ");
            Serial.println(httpResponseCode);
            // Free resources
            http.end();
          else {
            Serial.println("WiFi Disconnected");
          lastTime = millis();
      kristfrizh 1 Reply Last reply Reply Quote 0
      • kristfrizh
        kristfrizh @kristfrizh last edited by
        @kristfrizh Hii
        i just figured it out
        we don't use post at all with those syntax
        thank you
