    3. Entwicklung
    4. Admin 5 UI Anpassung
      weggetor Developer last edited by
      Hi folks,
      gibt es irgendwo einen Link zu einem HowTo wie man die Admin-Oberfläche Admin5-fähig macht ? Wird für meinen Adapter unter Admin 5.2.1 schon richtig angezeigt, aber vielleicht muss ich da noch was extra machen ?
      Der aktuelle code für index_m.html:
      <html>
      <head>
          <!-- Load ioBroker scripts and styles-->
          <link rel="stylesheet" type="text/css" href="../../css/adapter.css" />
          <link rel="stylesheet" type="text/css" href="../../lib/css/materialize.css">
          <script type="text/javascript" src="../../lib/js/jquery-3.2.1.min.js"></script>
          <script type="text/javascript" src="../../socket.io/socket.io.js"></script>
          <script type="text/javascript" src="../../js/translate.js"></script>
          <script type="text/javascript" src="../../lib/js/materialize.js"></script>
          <script type="text/javascript" src="../../js/adapter-settings.js"></script>
          <!-- Load our own files -->
          <link rel="stylesheet" type="text/css" href="style.css" />
          <script type="text/javascript" src="words.js"></script>
          <script type="text/javascript">
              // This will be called by the admin adapter when the settings page loads
              function load(settings, onChange) {
                  // example: select elements with id=key and class=value and insert value
                  if (!settings) return;
                  $('.value').each(function () {
                      var $key = $(this);
                      var id = $key.attr('id');
                      if ($key.attr('type') === 'checkbox') {
                          // do not call onChange direct, because onChange could expect some arguments
                          $key.prop('checked', settings[id])
                              .on('change', () => onChange())
                      } else {
                          $key.val(settings[id])
                              .on('keyup', () => onChange())
                  onChange(false);
                  // reinitialize all the Materialize labels on the page if you are dynamically adding inputs:
                  if (M) M.updateTextFields();
              // This will be called by the admin adapter when the user presses the save button
              function save(callback) {
                  // example: select elements with class=value and build settings object
                  var obj = {};
                      var $this = $(this);
                      if ($this.attr('type') === 'checkbox') {
                          obj[$this.attr('id')] = $this.prop('checked');
                      } else if ($this.attr('type') === 'number') {
                          obj[$this.attr('id')] = parseFloat($this.val());
                      } else {
                          obj[$this.attr('id')] = $this.val();
                  callback(obj);
          </script>
      </head>
      <body>
          <div class="m adapter-container">
              <div class="row">
                  <div class="col s12 m4 l2">
                      <img src="airconwithme.png" class="logo">
                  </div>
              </div>
              <!-- Put your content here -->
              <!-- For example columns with settings: -->
              <div class="row">
                  <div class="col s4 input-field">
                      <input type="text" class="value" id="ipaddress" />
                      <label for="ipaddress" class="translate">IP Address</label>
                      <span class="translate">IP Address of the Mitsubishi WLAN adapter</span>
                  </div>
                      <input type="text" class="value" id="username" />
                      <label for="username" class="translate">Username</label>
                      <span class="translate">Username for login on adapter website (default:admin)</span>
                  </div>
                      <input type="password" class="value" id="password" />
                      <label for="password" class="translate">Password</label>
                      <span class="translate">Password for login on adapter website (default:admin)</span>
                  </div>
              </div>
          </div>
      </body>
      </html>
