    4. viele WARN seit Systemwechsel
    • Negalein
      Platform: linux
      os: linux
      Architecture: x64
      CPUs: 2
      Speed: 3547 MHz
      Model: Intel(R) Core(TM) i5-6500 CPU @ 3.20GHz
      RAM: 6 GB
      System uptime: 1 T. 12:37:13
      Node.js: v14.17.1
      NPM: 6.14.13
      Disk size: 9.8 GiB
      Disk free: 3.7 GiB
      adapters count: 421
      Uptime: 1 T. 08:42:02
      Active instances: 54
      Hallo
      Seit dem Umzug von Synology Docker auf Proxmox (ioB als VM) hab ich viele Warn-Meldungen im Log.
      Unter anderem zB
      web.0	2021-07-07 22:08:25.904	warn	(19967) Read-only state "alexa2.0.Echo-Devices.G090U5099045059V.Player.mediaProgress" has been written without ack-flag with value "182"
      web.0	2021-07-07 22:08:22.179	warn	(19967) Read-only state "alexa2.0.Echo-Devices.G090U5099045059V.Player.mediaProgress" has been written without ack-flag with value "177"
      web.0	2021-07-07 22:08:12.292	warn	(19967) Read-only state "alexa2.0.Echo-Devices.G090U5099045059V.Player.mediaProgress" has been written without ack-flag with value "165"
      web.0	2021-07-07 22:08:12.230	warn	(19967) Read-only state "alexa2.0.Echo-Devices.G090U5099045059V.Player.mediaProgress" has been written without ack-flag with value "165"
      javascript.0	2021-07-07 22:08:08.070	warn	(10263) Read-only state "javascript.0.FensterUeberwachung.OverviewTable" has been written without ack-flag with value "<table style='width:100%; border-collapse: collapse; border: 0px solid black;'><
      web.0	2021-07-07 22:08:06.122	warn	(19967) Read-only state "alexa2.0.Echo-Devices.G090U5099045059V.Player.mediaProgress" has been written without ack-flag with value "161"
      web.0	2021-07-07 22:08:02.183	warn	(19967) Read-only state "alexa2.0.Echo-Devices.G090U5099045059V.Player.mediaProgress" has been written without ack-flag with value "155"
      javascript.0	2021-07-07 22:08:00.214	warn	(10263) at processTimers (internal/timers.js:500:7)
      javascript.0	2021-07-07 22:08:00.214	warn	(10263) at listOnTimeout (internal/timers.js:557:17)
      javascript.0	2021-07-07 22:08:00.214	warn	(10263) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/schedule.js:510:7)
      javascript.0	2021-07-07 22:08:00.214	warn	(10263) at /opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/schedule.js:552:11
      javascript.0	2021-07-07 22:08:00.214	warn	(10263) at Job.invoke (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/schedule.js:173:10)
      javascript.0	2021-07-07 22:08:00.214	warn	(10263) at Job.job (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1301:34)
      javascript.0	2021-07-07 22:08:00.213	warn	(10263) at Object.<anonymous> (script.js.Fritz.Fritz-Onlinezeit:7:27)
      javascript.0	2021-07-07 22:08:00.213	warn	(10263) getState "tr-064.0.states.externalIP" not found (3)
      web.0	2021-07-07 22:07:54.301	warn	(19967) Read-only state "alexa2.0.Echo-Devices.G090U5099045059V.Player.mediaProgress" has been written without ack-flag with value "150"
      web.0	2021-07-07 22:07:51.195	warn	(19967) Read-only state "alexa2.0.Echo-Devices.G090U5099045059V.Player.mediaProgress" has been written without ack-flag with value "144"
      web.0	2021-07-07 22:07:41.282	warn	(19967) Read-only state "alexa2.0.Echo-Devices.G090U5099045059V.Player.mediaProgress" has been written without ack-flag with value "137"
      web.0	2021-07-07 22:07:38.186	warn	(19967) Read-only state "alexa2.0.Echo-Devices.G090U5099045059V.Player.mediaProgress" has been written without ack-flag with value "132"
      web.0	2021-07-07 22:07:31.664	warn	(19967) Read-only state "alexa2.0.Echo-Devices.G090U5099045059V.Player.mediaProgress" has been written without ack-flag with value "127"
      web.0	2021-07-07 22:07:28.193	warn	(19967) Read-only state "alexa2.0.Echo-Devices.G090U5099045059V.Player.mediaProgress" has been written without ack-flag with value "121"
      web.0	2021-07-07 22:07:20.365	warn	(19967) Read-only state "alexa2.0.Echo-Devices.G090U5099045059V.Player.mediaProgress" has been written without ack-flag with value "116"
      web.0	2021-07-07 22:07:17.180	warn	(19967) Read-only state "alexa2.0.Echo-Devices.G090U5099045059V.Player.mediaProgress" has been written without ack-flag with value "110"
      Ich hab ein Backup (mit Backitup erstellt) zurückgespielt.
      Es läuft eigentlich alles, bis auf diese Menge Warn-Meldungen.
      Log wird täglich ca. 50 MB groß 😖
      Feuersturm 1 Reply Last reply Reply Quote 0
      • Feuersturm
        Feuersturm @Negalein last edited by Feuersturm
        @negalein Hi, du nutzt wohl den js-controller 3.3.x der noch im beta Stadium ist (https://forum.iobroker.net/topic/44624/js-controller-3-3-jetzt-im-beta)
        Die Warnungen müssen durch Anpassung in den entsprechenden Adaptern / Skripten gelöst werden. Schau am besten einmal nach, ob es bei den entsprechenden Adaptern auf GitHub schon passende issues gibt.
        Wenn es entsprechende issues gibt kannst du auch temporär das log Level auf error hochsetzen, bis die Adapter aktualisiert wurden.
        • Negalein
          Negalein Global Moderator @Feuersturm last edited by
          @feuersturm sagte in viele WARN seit Systemwechsel:
          Ja, den 3.3.14
          Dann werd ich mal Git durchforsten.
          • Negalein
            Es dürfte an VIS liegen.
            Aber @apollon77 weiß auch gerade nicht weiter.
            Vielleicht hat noch jemand eine Idee?
            • apollon77
              apollon77 @Negalein last edited by
              @negalein Ich würde hjetzt sagen ... zeig doch mal die Konfig des Vis Widgets was die mediaProgress anzeigt ... weil irgendwie muss das ja aus versehen schreiben
              • Negalein
                Negalein Global Moderator @apollon77 last edited by
                @apollon77 sagte in viele WARN seit Systemwechsel:
                [{"tpl":"tplValueString","data":{"oid":"alexa2.0.Echo-Devices.G090U5099045059V.Player.mediaProgressStr","g_fixed":true,"g_visibility":true,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":"","visibility-groups-action":"hide","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis.0/Buchenweg/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis.0/Buchenweg/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis.0/Buchenweg/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"visibility-oid":"","html_prepend":"","class":"mdui-blue-glow"},"style":{"left":"354px","top":"503px","color":"#ffffff","width":"78px","height":"37px","text-align":"left","font-style":"normal","font-size":"x-large","z-index":"58","font-weight":"bold","font-family":"RobotoCondensed-Light","text-shadow":"rgba(0, 0, 0, 0.9) 3px 3px 4px"},"widgetSet":"basic"}]
                • Negalein
                  Negalein Global Moderator last edited by Negalein
                  @apollon77
                  fast 2 Monate war Ruhe.
                  Heute wieder selbes Problem.
                  web.0 2021-08-24 22:01:47.187	warn	Read-only state "alexa2.0.Echo-Devices.G090U5099045059V.Player.mediaProgress" has been written without ack-flag with value "210"
