    5. Selbst signiertes Zertifikat erlauben / trusten
      DraycD last edited by
      Hi, meine Powerwall will seit dem letzten Update nicht mehr mit dem Javascript laufen da Tesla nun ein selbstsegniertes Cert. eingebunden hat.
      Bekomme immer:
      javascript.0 2021-07-11 09:41:00.017 error (1280) Request error: Error: Client network socket disconnected before secure TLS connection was established
      javascript.0 2021-07-11 09:41:00.017 error (1280) script.js.common.PowerWall-Abruf: Request PowerWall meldet Fehler: Error: Client network socket disconnected before secure TLS connection was established
      Wie kann ich in JS das Certificate erlauben?
      Hier das Script:
      Quelle & Urheber MeSwissX: https://tff-forum.de/t/powerwall-2-daten-auslesen-per-api/34214/26
      Code:
      const ipPowerwall = '192.168.1.142';
      const userEmail = "thierry@girard.li";
      const password = "thgiPowerwall";
      var logOn = false;
      createState("photovoltaik.PowerWall", 0.0); // Ladezustand PowerWall in %
      createState("photovoltaik.PowerWallErrorReported", false);
      createState("photovoltaik.PowerWallDown", false);
      createState("photovoltaik.powerWall.error", false);
      createState("photovoltaik.powerWall.down", false);
      createState("photovoltaik.powerWall.battery", 0.0); // Ladezustand PowerWall in %
      createState("photovoltaik.powerWall.power_netz", 0.0); // Energie Netz
      createState("photovoltaik.powerWall.power_battery", 0.0); // Energie Batterie
      createState("photovoltaik.powerWall.power_haus", 0.0); // Energie Haus
      createState("photovoltaik.powerWall.power_solar", 0.0); // Energie Photovoltaik
      var powerWallErrorReported = 'javascript.0.photovoltaik.PowerWallErrorReported';
      var PowerWallDown = 'javascript.0.photovoltaik.PowerWallDown';
      getPWCookie();
      function getPWCookie() {
          const https = require("https");
          const cookieUrl = 'https://'+ipPowerwall+'/api/login/Basic';
          var request = require("request");
          var agentOptions;
          var agent;
          agentOptions = {
              host: ipPowerwall
              , port: '443'
              , path: '/api/login/Basic'
              , rejectUnauthorized: false
          agent = new https.Agent(agentOptions);
          var headers = { 'Content-Type': 'application/json' };
          var dataString = '{"username": "customer","email": "'+userEmail+'","password":"'+password+'"}';
          var options = {
              url: cookieUrl,
              method: 'POST',
              headers: headers,
              body: dataString,
              agent: agent
          request(options, function (error, response, body) {
                  // if (err) log(JSON.stringify(err));
                  // if (resp) log(JSON.stringify(resp));
              if (!error && response.statusCode == 200) {
       //           if(logon) { log('powerWall_Cookie_login_success') };
                  try {
                      var json = JSON.parse(body);
                      var token = json.token;
                      getPWDataNew(token);
                  } catch (e) {
                      if (e instanceof SyntaxError) {
                          log("json parse error: " + e);
                      } else {
                          log("json parse error - other: " + e);
              } else {
                  log('Request PowerWall meldet Fehler: ' + error, 'error');
                  if (getState(powerWallErrorReported).val === false) {
                      setState(powerWallErrorReported,true);
                      //pushover
                      sendTo('pushover.0', {
                          message: 'PowerWall Error',
                          title: 'POWERWALL',
                          priority: 1,
                          sound: 'magic'
      function getPWDataNew(token) {
          const urlBatterySoe = 'https://'+ipPowerwall+'/api/system_status/soe';
          const urlAggregates = 'https://'+ipPowerwall+'/api/meters/aggregates';
          var agentOptions;
          var agent;
          agentOptions = {
              host: ipPowerwall
              , port: '443'
              , path: '/'
          var headers = {
              'Content-Type': 'application/json',
              'Cookie' : 'AuthCookie='+token
          var optionsBatterySoe = {
              url: urlBatterySoe,
              method: 'GET',
              headers: headers,
              agent: agent
          var optionsAggregates = {
              url: urlAggregates,
              method: 'GET',
              headers: headers,
              agent: agent
          request(optionsBatterySoe, function (error, response, body) {
      //            if (error) log(JSON.stringify(error));
      //            if (response) log(JSON.stringify(response));
      //            if (logon) {log('powerWall readout success!!')};
                  setState(powerWallErrorReported,false);
                  setState(PowerWallDown,false);
                  if (body) {
                      batteryPercentage(body);
              } else {
                  log('powerWall battery readout Fehler: ' + error, 'error');
          request(optionsAggregates, function (error, response, body) {
                  if (body) {
                      aggregatesVerarbeiten(body);
              } else {
                  log('powerWall aggregates readout Fehler: ' + error, 'error');
      // analyse PowerWall Battery Percentage
      function batteryPercentage(result) {
          try {
              var json = JSON.parse(result);
              var ladungPowerWall = Number(json.percentage);
              if (logOn) log("PowerWall Ladezustand: " + ladungPowerWall + " %");
              setState("javascript.0.photovoltaik.PowerWall"/*PowerWall Ladezustand in %*/,ladungPowerWall);
          } catch (e) {
              } else {
      // analyse PowerWall aggregates
      function aggregatesVerarbeiten(result) {
          try {
              var sitePower = Number(json.site.instant_power);
              var batteryPower = Number(json.battery.instant_power);
              var loadPower = Number(json.load.instant_power);
              var solarPower = Number(json.solar.instant_power);
              setState('photovoltaik.powerWall.power_netz',sitePower);
              setState('photovoltaik.powerWall.power_battery',batteryPower);
              setState('photovoltaik.powerWall.power_haus',loadPower);
              setState('photovoltaik.powerWall.power_solar',solarPower);
              if (logOn) log("PowerWall site: " + sitePower + ' battery: ' + batteryPower + ' load: ' + loadPower + ' solar: ' + solarPower);
          } catch (e) {
                  log("json aggregates parse error: " + e);
              } else {
                  log("json aggregates parse error - other: " + e);
      // Startet das Skript alle 1 minuten neu
      schedule("* * * * *", function() {
          getPWCookie();
      Hoffe ihr könnt mir helfen 😉
      P 1 Reply Last reply Reply Quote -1
        peterfido @DraycD last edited by
        @draycd
        Wenn du das Zertifikat speichern kannst, steht evtl. Hier eine Möglichkeit.
