    4. Neue Oberfläche Admin 5: Adaptertab zeigt nichts mehr an
      DerRon last edited by DerRon
      habe seit erscheinen der neuen Oberfläche das Problem, dass er mir die Adapter im Adapter-Tab nicht anzeigt, ebenso im Tab INFO unter "Meine Adapter". Er lädt und lädt und lädt, aber es kommt nichts. In der alten Oberfläche ist alles normal.
      Fehlermeldung im Browser beim Öffnen des Adapter tabs:
      [ADAPTERS] getAdapters
      instrument.ts:129 [ADAPTERS] getAdaptersInfo
      Adapters.js:531 Uncaught (in promise) TypeError: Cannot read property 'accuweather' of undefined
          at Adapters.js:531
          at Array.forEach (<anonymous>)
          at a.value (Adapters.js:524)
          at Adapters.js:674
      (anonymous) @ Adapters.js:531
      value @ Adapters.js:524
      (anonymous) @ Adapters.js:674
      Promise.then (async)
      value @ Adapters.js:315
      fi @ react-dom.production.min.js:219
      jl @ react-dom.production.min.js:259
      t.unstable_runWithPriority @ scheduler.production.min.js:18
      Wa @ react-dom.production.min.js:122
      Vl @ react-dom.production.min.js:252
      ml @ react-dom.production.min.js:243
      (anonymous) @ react-dom.production.min.js:123
      Ga @ react-dom.production.min.js:123
      F @ scheduler.production.min.js:16
      M.port1.onmessage @ scheduler.production.min.js:12
      Den Adapter Accuweather habe ich allerdings nicht installiert.
      Fehlermeldung beim Öffnen des INFO-tabs:
      adapterIssues.js:6 Uncaught (in promise) TypeError: Cannot read property 'tabs' of undefined
          at getIssues (VM83 adapterIssues.js:6)
          at showIssues (VM83 adapterIssues.js:51)
          at VM88 info.js:169
      getIssues @ adapterIssues.js:6
      showIssues @ adapterIssues.js:51
      (anonymous) @ info.js:169
      async function (async)
      (anonymous) @ info.js:132
      (anonymous) @ helper.js:237
      SocketClient.findAnswer @ socket.io.js:251
      socket.onmessage @ socket.io.js:163
      translate.js:24 "LPDDR4": {"en": "LPDDR4", "de": "LPDDR4", "ru": "LPDDR4", "pt": "LPDDR4", "nl": "LPDDR4", "fr": "LPDDR4", "es": "LPDDR4", "pl": "LPDDR4", "it": "LPDDR4", "zh-cn": "LPDDR4"},
      translate.js:24 "SOC": {"en": "SOC", "de": "SOC", "ru": "SOC", "pt": "SOC", "nl": "SOC", "fr": "SOC", "es": "SOC", "pl": "SOC", "it": "SOC", "zh-cn": "SOC"},
      translate.js:24 "os.fqdn": {"en": "os.fqdn", "de": "os.fqdn", "ru": "os.fqdn", "pt": "os.fqdn", "nl": "os.fqdn", "fr": "os.fqdn", "es": "os.fqdn", "pl": "os.fqdn", "it": "os.fqdn", "zh-cn": "os.fqdn"},
      translate.js:24 "battery.virtual": {"en": "battery.virtual", "de": "battery.virtual", "ru": "battery.virtual", "pt": "battery.virtual", "nl": "battery.virtual", "fr": "battery.virtual", "es": "battery.virtual", "pl": "battery.virtual", "it": "battery.virtual", "zh-cn": "battery.virtual"},
      translate.js:24 "system.virtual": {"en": "system.virtual", "de": "system.virtual", "ru": "system.virtual", "pt": "system.virtual", "nl": "system.virtual", "fr": "system.virtual", "es": "system.virtual", "pl": "system.virtual", "it": "system.virtual", "zh-cn": "system.virtual"},
      format-google-calender.js:196 GET https://cors-anywhere.herokuapp.com/https://www.googleapis.com/calendar/v3/calendars/mh14bh7m2bdva7pb7tkirsbcsg@group.calendar.google.com/events?key=AIzaSyA4GWhsN21aMARuc6uyl45zdq8Ue5dJu10&singleEvents=true&orderBy=starttime 403 (Forbidden)
      _init @ format-google-calender.js:196
      init @ format-google-calender.js:495
      (anonymous) @ info.js:217
      format-google-calender.js:190 Forbidden
      request.onload @ format-google-calender.js:190
      load (async)
      _init @ format-google-calender.js:184
      translate.js:24 "location": {"en": "location", "de": "location", "ru": "location", "pt": "location", "nl": "location", "fr": "location", "es": "location", "pl": "location", "it": "location", "zh-cn": "location"},
      forum.js:41 Uncaught (in promise) TypeError: Cannot read property 'title' of undefined
          at getGermanForumData (VM79 forum.js:41)
      getGermanForumData @ forum.js:41
      getGermanForumData @ forum.js:21
      writeForumData @ forum.js:14
      startForum @ forum.js:145
      (anonymous) @ info.js:135
      instrument.ts:129 Repo updated!
      Systemdata Bitte Ausfüllen
      Hardwaresystem: Pi4
      Arbeitsspeicher: 4GB
      Festplattenart: SD-Karte
      Betriebssystem: Raspberry Pi OS Lite
      Nodejs-Version: v12.22.2
      NPM-Version: 6.14.13
      Installationsart: Skript
      Image genutzt: Nein
      Adminadapter: v5.1.12
      • Glasfaser
        Glasfaser @DerRon last edited by
        @derron sagte in Neue Oberfläche Admin 5: Adaptertab zeigt nichts mehr an:
        Du weißt schon , der ist noch Beta !?
        im Tab INFO ........
        https://forum.iobroker.net/topic/46033/fragen-zum-info-adapter
          DerRon @Glasfaser last edited by
          @glasfaser said in Neue Oberfläche Admin 5: Adaptertab zeigt nichts mehr an:
          Achso, also funktioniert das bei noch bei niemandem. Dann warte ich noch ne Weile...
            Ramses123 last edited by Ramses123
            Läuft dein JS Controller auf der aktuellsten Version (3.3.14)? Das war bei mir damals das Problem, als ich den Admin von 4.x.x auf 5.1.9 upgedated habe. Auf 5.1.12 bin ich noch nicht, ist mir noch zu frisch. Ich warte immer 10-14 Tage mit dem Update, dann sind die Kinderkrankheiten meistens bekannt und ausgemerzt.
              Thomas Braun Most Active @Ramses123 last edited by Thomas Braun
              @ramses123 sagte in Neue Oberfläche Admin 5: Adaptertab zeigt nichts mehr an:
              Und warum fährst du dann nicht stable?
              In Beta 2 Wochen hinten dran zu sein ist ja nicht Sinn und Zweck vom Beta-Test.
                meicker last edited by
                ist das noch aktuell oder solte der Adapter Tab wieder etwas anzeigen ? Ich hatte das vor ein paar Tagen schon einmal, zwischenzeitlich war aber alles OK und jetzt zeigt er wieder nichts an.
                Viele Grüße,
                Marc
                  meicker @meicker last edited by
                  @meicker sagte in Neue Oberfläche Admin 5: Adaptertab zeigt nichts mehr an:
                  Viele Grüße,
                  Marc
                  Für mich war die Lösung in der Instanz vom Admin die alte Benutzeroblerfläche zu aktivieren. Danach konnte ich sie wieder deaktivieren und die Adapter wurden wieder wie gewohnt angezeigt ...
