    4. Netatmo 1.4.3 Fehlermeldung
    • htrecksler
      htrecksler Forum Testing last edited by htrecksler
      Controller: 3.2.16
      Admin: 4.2.2
      Wenn ich die Kamera (Presence) über die App von Netatmo starte kommt neuerdings folgender Log Eintrag:
      2021-07-20 19:43:11.706 - error: netatmo.0 (5898) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      2021-07-20 19:43:11.707 - error: netatmo.0 (5898) unhandled promise rejection: The state property "ack" has the wrong type "object" (should be "boolean")!
      2021-07-20 19:43:11.710 - error: netatmo.0 (5898) Error: The state property "ack" has the wrong type "object" (should be "boolean")!
      at validateSetStateObjectArgument (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5861:27)
      at Adapter.setState (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5935:21)
      at /opt/iobroker/node_modules/iobroker.js-controller/lib/tools.js:1569:16
      at new Promise ()
      at Adapter.setStateAsync (/opt/iobroker/node_modules/iobroker.js-controller/lib/tools.js:1568:16)
      at onSocketAlert (/opt/iobroker/node_modules/iobroker.netatmo/lib/netatmoWelcome.js:174:31)
      at async Socket. (/opt/iobroker/node_modules/iobroker.netatmo/lib/netatmoWelcome.js:25:46)
      2021-07-20 19:43:11.711 - error: netatmo.0 (5898) The state property "ack" has the wrong type "object" (should be "boolean")!
      2021-07-20 19:43:11.727 - info: netatmo.0 (5898) Unregistering realtime events
      2021-07-20 19:43:11.731 - info: netatmo.0 (5898) cleaned everything up...
      2021-07-20 19:43:11.732 - info: netatmo.0 (5898) terminating
      2021-07-20 19:43:11.733 - warn: netatmo.0 (5898) Terminated (UNCAUGHT_EXCEPTION): Without reason
      2021-07-20 19:43:11.899 - error: netatmo.0 (5898) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      2021-07-20 19:43:11.900 - error: netatmo.0 (5898) unhandled promise rejection: The state property "ack" has the wrong type "object" (should be "boolean")!
      2021-07-20 19:43:11.900 - error: netatmo.0 (5898) Error: The state property "ack" has the wrong type "object" (should be "boolean")!
      at new Promise ()
      2021-07-20 19:43:11.901 - error: netatmo.0 (5898) The state property "ack" has the wrong type "object" (should be "boolean")!
      2021-07-20 19:43:12.385 - error: host.iobrokerVM instance system.adapter.netatmo.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
      2021-07-20 19:43:12.390 - info: host.iobrokerVM Restart adapter system.adapter.netatmo.0 because enabled
      2021-07-20 19:43:42.425 - info: host.iobrokerVM instance system.adapter.netatmo.0 started with pid 8010
      2021-07-20 19:43:44.649 - info: netatmo.0 (8010) starting. Version 1.4.3 in /opt/iobroker/node_modules/iobroker.netatmo, node: v12.19.0, js-controller: 3.2.16
      2021-07-20 19:43:44.845 - info: netatmo.0 (8010) Registering realtime events with https://iobroker.herokuapp.com/netatmo/
      kann das jemand bestätigen?
        Thomas Braun Most Active @htrecksler last edited by
        @htrecksler sagte in Netatmo 1.4.3 Fehlermeldung:
        Nee, aber ich kann bestätigen dass deine node-Installation etwas Aufmerksamkeit bekommen sollte.
        htrecksler 1 Reply Last reply Reply Quote 0
        • htrecksler
          htrecksler Forum Testing @Thomas Braun last edited by
          @thomas-braun besser?
          2021-07-20 20:43:37.591 - error: netatmo.0 (806) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
          2021-07-20 20:43:37.593 - error: netatmo.0 (806) unhandled promise rejection: The state property "ack" has the wrong type "object" (should be "boolean")!
          2021-07-20 20:43:37.596 - error: netatmo.0 (806) Error: The state property "ack" has the wrong type "object" (should be "boolean")!
          at new Promise ()
          at runNextTicks (internal/process/task_queues.js:62:5)
          at processImmediate (internal/timers.js:434:9)
          2021-07-20 20:43:37.597 - error: netatmo.0 (806) The state property "ack" has the wrong type "object" (should be "boolean")!
          2021-07-20 20:43:37.621 - info: netatmo.0 (806) Unregistering realtime events
          2021-07-20 20:43:37.626 - info: netatmo.0 (806) cleaned everything up...
          2021-07-20 20:43:37.627 - info: netatmo.0 (806) terminating
          2021-07-20 20:43:37.628 - warn: netatmo.0 (806) Terminated (UNCAUGHT_EXCEPTION): Without reason
          2021-07-20 20:43:37.685 - error: netatmo.0 (806) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
          2021-07-20 20:43:37.685 - error: netatmo.0 (806) unhandled promise rejection: The state property "ack" has the wrong type "object" (should be "boolean")!
          2021-07-20 20:43:37.686 - error: netatmo.0 (806) Error: The state property "ack" has the wrong type "object" (should be "boolean")!
          at new Promise ()
          2021-07-20 20:43:37.687 - error: netatmo.0 (806) The state property "ack" has the wrong type "object" (should be "boolean")!
          2021-07-20 20:43:38.231 - error: host.iobrokerVM instance system.adapter.netatmo.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
          2021-07-20 20:43:38.235 - info: host.iobrokerVM Restart adapter system.adapter.netatmo.0 because enabled
          2021-07-20 20:44:08.341 - info: host.iobrokerVM instance system.adapter.netatmo.0 started with pid 890
          2021-07-20 20:44:11.725 - info: netatmo.0 (890) starting. Version 1.4.3 in /opt/iobroker/node_modules/iobroker.netatmo, node: v12.22.2, js-controller: 3.2.16
          2021-07-20 20:44:12.271 - info: netatmo.0 (890) Registering realtime events with https://iobroker.herokuapp.com/netatmo/
            Sprite01 last edited by
            Die Fehlermeldung habe ich seit dem neuesten Update (Host 3.3.15 und Admin5) jetzt auch, kann ich bestätigen.
            host.iobroker
            	2021-08-09 11:36:09.732	error	instance system.adapter.netatmo.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
            netatmo.0
            	2021-08-09 11:36:08.813	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
            netatmo.0
            	2021-08-09 11:36:08.803	error	The state property "ack" has the wrong type "object" (should be "boolean")!
            netatmo.0
            	2021-08-09 11:36:08.802	error	Error: The state property "ack" has the wrong type "object" (should be "boolean")! at validateSetStateObjectArgument (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:6017:27) at Adapter.setState (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:6091:21) at /opt/iobroker/node_modules/iobroker.js-controller/lib/tools.js:1576:16 at new Promise (<anonymous>) at Adapter.setStateAsync (/opt/iobroker/node_modules/iobroker.js-controller/lib/tools.js:1575:16) at onSocketAlert (/opt/iobroker/node_modules/iobroker.netatmo/lib/netatmoWelcome.js:174:31) at async Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.netatmo/lib/netatmoWelcome.js:25:46)
            netatmo.0
            	2021-08-09 11:36:08.799	error	unhandled promise rejection: The state property "ack" has the wrong type "object" (should be "boolean")!
            netatmo.0
            	2021-08-09 11:36:08.797	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
