    4. Harmony Adapter lässt sich nicht installieren
      csamaggi last edited by
      Halo ihr lieben,
      ich wollte nun meinen IO um den Harmony Adapter erweitern, doch dieser lässt sich nicht installieren hier mal der Auszug vom Log.
      iobroker	2017-01-28 19:03:54.003	info	exit 25
      iobroker	2017-01-28 19:03:53.967	error	host.ioBroker-Pi Cannot install iobroker.harmony: 1
      iobroker	2017-01-28 19:03:53.916	info	npm ERR! /npm-debug.log
      iobroker	2017-01-28 19:03:53.916	info	npm ERR! Please include the following file with any support request:
      iobroker	2017-01-28 19:03:53.628	info	Please check if you have git installed and in your PATH.
      iobroker	2017-01-28 19:03:53.624	info	npm ERR!
      iobroker	2017-01-28 19:03:53.624	info	npm ERR! This is most likely not a problem with npm itself.
      iobroker	2017-01-28 19:03:53.624	info	npm ERR! Failed using git.
      iobroker	2017-01-28 19:03:53.624	info	npm ERR! not found: git
      iobroker	2017-01-28 19:03:53.604	info	npm ERR! code ENOGIT
      iobroker	2017-01-28 19:03:53.601	info	npm ERR! npm v2.15.9
      iobroker	2017-01-28 19:03:53.601	info	npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "install" "iobroker.harmony" "--production" "--prefix" "/opt/iobroker"npm ERR! node v4.5.0
      iobroker	2017-01-28 19:03:53.594	info	npm ERR! Linux 4.4.13-v7+
      iobroker	2017-01-28 19:03:52.907	info	npm WARN deprecated node-xmpp-stanza@1.1.0: use @xmpp/xml package
      iobroker	2017-01-28 19:03:52.885	info	npm ERR! git clone --template=/root/.npm/_git-remotes/_templates --mirror https://github.com/swissmanu/ltx.git /root/.npm/_git-remotes/https-github-com-swissmanu-ltx-git-634cc128: undefinednpm ERR! g
      iobroker	2017-01-28 19:03:52.726	info	npm WARN addRemoteGit git+https://github.com/swissmanu/ltx.git#cdata-for-ltx-parser resetting remote /root/.npm/_git-remotes/https-github-com-swissmanu-ltx-git-634cc128 because of error: { [Error: no
      iobroker	2017-01-28 19:03:52.726	info	npm WARN addRemoteGit at FSReqWrap.oncomplete (fs.js:82:15)
      iobroker	2017-01-28 19:03:52.726	info	npm WARN addRemoteGit at /usr/lib/node_modules/npm/node_modules/which/node_modules/isexe/access.js:8:5
      iobroker	2017-01-28 19:03:52.726	info	npm WARN addRemoteGit at /usr/lib/node_modules/npm/node_modules/which/node_modules/isexe/index.js:44:5
      iobroker	2017-01-28 19:03:52.726	info	npm WARN addRemoteGit at E (/usr/lib/node_modules/npm/node_modules/which/which.js:81:29)npm WARN addRemoteGit at /usr/lib/node_modules/npm/node_modules/which/which.js:90:16
      iobroker	2017-01-28 19:03:52.716	info	at F (/usr/lib/node_modules/npm/node_modules/which/which.js:69:19)
      iobroker	2017-01-28 19:03:52.713	info	npm WARN addRemoteGit
      iobroker	2017-01-28 19:03:52.709	info	npm WARN addRemoteGit Error: not found: gitnpm WARN addRemoteGit at getNotFoundError (/usr/lib/node_modules/npm/node_modules/which/which.js:14:12)
      iobroker	2017-01-28 19:03:50.967	info	engine harmonyhubjs-client@1.1.10: wanted: {"npm":">=3.0.0"} (current: {"node":"4.5.0","npm":"2.15.9"})
      iobroker	2017-01-28 19:03:50.964	info	WARN
      iobroker	2017-01-28 19:03:50.961	info	npm
      iobroker	2017-01-28 19:03:43.969	info	npm install iobroker.harmony --production --prefix "/opt/iobroker" (System call)
      iobroker	2017-01-28 19:03:40.135	info	add harmony
      MFG Maggi
        dir fehlt ein Paket
        sudo apt-get install git
        Jetzt sag nicht dass du eine Installation unter Windoof hast.
        Da gibt es exakt zu diesem Thema bereits einiges.
          Also ich habe die Installation nicht unter Windows sondern auf einem Raspi2B.
            @csamaggi:
            Also ich habe die Installation nicht unter Windows sondern auf einem Raspi2B. `
            Dann führe den oben genannten Befehl ais ind versuche es nochmal.
              Danke das läuft nun schon mal.
