    5. Led DImmerung
    Led DImmerung
      Dennis HG last edited by Dennis HG
      Ich bin neu hier im forum und neu was Iobroker angeht.
      Ich habe ein Blockly erstellt um meine Aquariumbeleuchtung per zeit hoch und runter zu dimmen, leider geht es mal gut und an anderen Tagen wieder nicht.
      was habe ich falsch gemacht?
        <variables>
          <variable type="interval" id="Intervall2">Intervall2</variable>
          <variable type="interval" id="Intervall">Intervall</variable>
        </variables>
        <block type="schedule" id="0Q|ipoSHGTTHy-WPc1VG" x="-612" y="-151">
          <field name="SCHEDULE">{"time":{"exactTime":true,"start":"10:00"},"period":{"days":1}}</field>
            <block type="control" id="Bv3SX!80}T~MXIZuCBDu">
              <field name="OID">sonoff.0.HN LED.POWER1</field>
                <block type="logic_boolean" id="NJ~i^8n)fnkF4ZP@h;jA">
                <block type="control" id="3)VpdJzw9nM05L.4-]YC">
                  <field name="OID">sonoff.0.HN LED.Red</field>
                    <block type="math_number" id="^9lt[g{ObYpsD-u]PViE">
                      <field name="NUM">0</field>
                    <block type="timeouts_setinterval" id="Vi#Q`P{:ZIMRLk:BJ6h,">
                      <field name="NAME">Intervall</field>
                      <field name="INTERVAL">72000</field>
                      <field name="UNIT">ms</field>
                        <block type="controls_if" id="zKR.JQ.se`)o!}.i59_J">
                            <block type="logic_compare" id="^IbdJP/kYKe?{,9nO?ZQ">
                              <field name="OP">LT</field>
                                <block type="get_value" id="7x8J*FX:5%HQw2Pr;[#K">
                                <block type="math_number" id="pZk$;u-fb}7==?^Fzjp@">
                                  <field name="NUM">75</field>
                            <block type="control" id="5i:E;5iNV2F`yI:+~`JX">
                                <block type="math_arithmetic" id="]1U+y~*:i8f9Q~cX##,i">
                                  <field name="OP">ADD</field>
                                    <shadow type="math_number" id="7#M%}o.-Kf*%mZCCq^l%">
                                      <field name="NUM">1</field>
                                    <block type="get_value" id="e:it,Aq#k]_WXJ`D1lv]">
                                    <shadow type="math_number" id="g=v}(UP].U-NtC]ubRx2">
                          <statement name="ELSE">
                            <block type="timeouts_clearinterval" id=":.#q_x_6tK5#joM!ZCPm">
        <block type="schedule" id="x![=gxvyPC(Jk,Qj5-`h" x="-562" y="185">
          <field name="SCHEDULE">{"time":{"exactTime":true,"start":"19:30"},"period":{"days":1}}</field>
            <block type="control" id="$zg#03fZ[]1;H5rkc@(%">
                <block type="timeouts_setinterval" id="}V`?f`+PghYM{Ch{Fiwt">
                  <field name="NAME">Intervall2</field>
                  <field name="INTERVAL">18000</field>
                    <block type="controls_if" id="1:u8m92jNJbu~$K.}2+O">
                        <block type="logic_compare" id="R1TDC9hZWi.5S+R55hcz">
                          <field name="OP">GT</field>
                            <block type="get_value" id="EVXB_fd*0GG8[n/D9cC6">
                            <block type="math_number" id="GY6x,pQ=X16dKqfI+++#">
                        <block type="control" id="1Y`q|gikA00Em~M/4U~W">
                            <block type="math_arithmetic" id="}pxe?~Qk1~cnn:!r#P;Z">
                                <shadow type="math_number">
                                <block type="get_value" id="#ahpQ=I8]x`|c*6x[T6w">
                                <shadow type="math_number" id="6F^:XoHO2Jzs@{/l)pad">
                        <block type="timeouts_clearinterval" id="]AE#)WPJ!v{ML?VZUCsg">
      </xml>```
      code_text
      Thomas Braun paul53 2 Replies Last reply Reply Quote 0
        Thomas Braun Most Active @Dennis HG last edited by
        @dennis-hg
        Bitte CodeTags für Code verwenden.
          Dennis HG @Thomas Braun last edited by
          @thomas-braun sorry bin noch nicht so drine, ist das so richtig?
            @dennis-hg Kann man wesentlich besser lesen, oder?
              @thomas-braun ja das Stimmt 🙂
                paul53 @Dennis HG last edited by paul53
                @dennis-hg sagte: was habe ich falsch gemacht?
                19:30 Uhr: Es fehlt der Anfangswert und es wird das falsche Intervall gestoppt.
                Sollte es nicht besser so aussehen?
                  Dennis HG @paul53 last edited by Dennis HG
                  @paul53 Oh danke, das mit Intervall 1 und zwei habe ich wohl übersehen.
                  Mit dem Startwert hatte ich beides schon versucht, ergab aber kein unterschied.
                  MfG
                    Dennis HG @Dennis HG last edited by
                    Ich hätte noch eine frag.
                    Bei mir kommt es hin und wieder das der Router Neustarten, wenn es beim runterdimmen passiert bleibt der Status dann da stehen.
                    Könnte man im Skript eine Sicherung einbauen was den Verlauf prüft und dann es zu Ende bringt.
                    Ich hoffe ihr versteht mich was ich meine 🙂
