    4. ioBroker startet nicht mehr - Fehlermeldung js-controller
    • 4
      41vsy last edited by Homoran
      ich habe gestern die Daten von meiner Festplatten (an Pi4) gesichert / geklont. Seitdem startet er nicht meht. Infolge bin ich die Anleitung (https://www.iobroker.net/#de/documentation/trouble/RunsNoMore.md) durchgegangen.
      Folgende Fehlermeldung erhalte ich:
      npm install iobroker.js-controller
      > iobroker.js-controller@3.3.14 preinstall /opt/iobroker/node_modules/iobroker.js-controller
      > node lib/preinstallCheck.js
      NPM version: 6.14.12
      > iobroker.js-controller@3.3.14 install /opt/iobroker/node_modules/iobroker.js-controller
      > node iobroker.js setup first
      object system.certificates updated
      object _design/custom updated
      object _design/system updated
      The following notifications happened during sync:
      - Ignoring Directory "admin.admin" because officially not created as meta object. Please remove directory!
      - Ignoring Directory "backitup.admin" because officially not created as meta object. Please remove directory!
      - Ignoring Directory "cloud.admin" because officially not created as meta object. Please remove directory!
      - Ignoring Directory "deconz.admin" because officially not created as meta object. Please remove directory!
      - Ignoring Directory "discovery.admin" because officially not created as meta object. Please remove directory!
      - Ignoring Directory "info.admin" because officially not created as meta object. Please remove directory!
      - Ignoring Directory "javascript.admin" because officially not created as meta object. Please remove directory!
      - Ignoring Directory "shelly.admin" because officially not created as meta object. Please remove directory!
      - Ignoring Directory "vis" because officially not created as meta object. Please remove directory!
      - Ignoring Directory "vis-materialdesign.admin" because officially not created as meta object. Please remove directory!
      - Ignoring Directory "vis.0" because officially not created as meta object. Please remove directory!
      - Ignoring Directory "vis.admin" because officially not created as meta object. Please remove directory!
      - Ignoring Directory "web" because officially not created as meta object. Please remove directory!
      - Ignoring Directory "web.admin" because officially not created as meta object. Please remove directory!
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.2 (node_modules/chokidar/node_modules/fsevents):
      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.7 (node_modules/osx-temperature-sensor):
      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.7: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
      + iobroker.js-controller@3.3.14
      updated 1 package in 36.765s
      27 packages are looking for funding
        run `npm fund` for details
      Kann jemand damit etwas anfangen und hoffentlich weiterhelfen?
      VG
        Thomas Braun Most Active @41vsy last edited by
        @41vsy
        Bitte CodeTags verwenden.
        iobroker status
        liefert?
        4 1 Reply Last reply Reply Quote 0
        • 4
          41vsy @Thomas Braun last edited by
          @thomas-braun said in ioBroker startet nicht mehr - Fehlermeldung js-controller:
          iobroker status
          pi@ioBroker:/opt/iobroker $ iobroker status
          Objects type: file
          States  type: file
          CodeTags... Sorry, bin noch ganz neu im Forum und bei ioBroker
            @41vsy
            Läuft doch...
            Ob man 'ganz neu bei ioBroker' gleich mit Beta-Versionen herummachen sollte weiß ich allerdings nicht...
            iobroker list adapters
            iobroker list instances
            iobroker repo list
            • 4
              Schon mal nicht schlecht, dass er grundsätzlich noch läuft. Allerdings ist er über die IP nicht mehr zu erreichen. Die IP Adresse habe ich nochmal kontrolliert, diese habe ich korrekt eingegeben. Desweiteren laufen, unabhängig von der Erreichbarkeit auch keine Automationen bzw. die Visu nicht mehr.
              pi@ioBroker:/opt/iobroker $  iobroker list adapters
              pi@ioBroker:/opt/iobroker $ iobroker list instances
              + instance is alive
              pi@ioBroker:/opt/iobroker $ iobroker repo list
              stable      : http://download.iobroker.net/sources-dist.json
              beta        : http://download.iobroker.net/sources-dist-latest.json
              Active repo: stable
              J Thomas Braun 2 Replies Last reply Reply Quote 0
                Jan1 @41vsy last edited by Jan1
                @41vsy sagte in ioBroker startet nicht mehr - Fehlermeldung js-controller:
                Äh und wo machst das ganze jetzt bitte mit der Konsole, wenn er nicht erreichbar wäre?
                Du sprichst von der Admin Seite?
                Kann es sein, dass Du nur die IP im Browser eingibst, ohne Port Angabe?
                  @41vsy
                  Da fehlen die Adapter.
                  Entweder von Hand nachinstallieren oder damit mal versuchen:
                  https://forum.iobroker.net/topic/43325/mini-howto-cannot-find-view-system-for-search-host?_=1627306843032
                  Könnte sein das es auch in deinem Fall weiterhilft.
                    Aus einem laufenden System/ioBroker? Das geht nicht gut.
                    • 4
                      41vsy @Jan1 last edited by 41vsy
                      @jan1
                      Ich habe den Pi an einem Monitor. Port habe mit eingegeben.
                      • 4
                        Nein. Ich habe den Pi runtergefahren und die Daten (Festplatte) an einem separaten Gerät gesichert.
                          @41vsy
                          Ok, dann fehlen Dir wie Thomas schon geschrieben hat die Adapter und ohne Admin, kein Zugriff über IP via SSH.
                          Monitor am Server kann man machen,,ist aber eigentlich nie nötig, da der Zugriff eben über SSH erfolgt.
                            @41vsy
                            Ist der Pi jetzt nicht erreichbar oder lediglich der ioBroker nicht?
                            • 4
                              Das hat funktioniert. Danke. Danke. Danke.
                              • 4
                                @jan1
                                Für den ioBroker nutze ich den Monitor auch nicht. Habe ihn nur angeschlossen um die Eingabe am Terminal zu machen.
                                4 Thomas Braun 2 Replies Last reply Reply Quote 0
                                • 4
                                  41vsy @41vsy last edited by
                                  Wie sicher ihr eure Daten bzw. die Festplatte / SD-Karte? Vllt ist ja klonen nicht ganz optimal.
                                  Danke nochmal!!!
                                    @41vsy
                                    Per SSH hätte das aber die ganze Zeit dann funktionieren müssen. Ohne Monitor.
                                    Dann hast du dir 'irgendwie' die States und Objects zerschossen. In der Regel passiert das bei abruptem Stromentzug.
                                      Klonen ist aus meiner Sicht alles andere als optimal.
                                      Mach deine Backups mit dem Backitup-Adapter.
                                      4 1 Reply Last reply Reply Quote 1
                                      • 4
                                        Ok. Danke dafür. Werde das zukünftig beherzigen.
                                        657
