    4. WLED Variablentyp falsch nach JS Controller Update 3.3.15
      mguenther last edited by mguenther
      Systemdata Bitte Ausfüllen
      Hardwaresystem: Pi4
      Arbeitsspeicher: 4GB
      Festplattenart: SSD
      Betriebssystem: Debian
      Node-Version: 12.22.4
      Nodejs-Version: 12.22.4
      NPM-Version: 6.14.14
      Installationsart: Skript
      Image genutzt: Ja
      Ort/Name der Imagedatei: Original
      ich weiß nicht, ob es hier richtig ist, aber ich schreibe es mal hier hinein. Nach dem fehlerfreien Update des JS-Controllers auf 3.3.15 erscheint bei mir im LOG folgende Info:
      wled.0	2021-08-05 00:37:44.760	info	(11249) State value to set for "wled.0.8cce4ed829ab._info.leds.pin" has to be one of type "string", "number", "boolean" but received type "object"
      wled.0	2021-08-05 00:37:14.445	info	(11249) State value to set for "wled.0.8cce4ed829ab.seg.0.col.2" has to be one of type "string", "number", "boolean" but received type "object"
      wled.0	2021-08-05 00:37:14.436	info	(11249) State value to set for "wled.0.8cce4ed829ab.seg.0.col.1" has to be one of type "string", "number", "boolean" but received type "object"
      wled.0	2021-08-05 00:37:14.425	info	(11249) State value to set for "wled.0.8cce4ed829ab.seg.0.col.0" has to be one of type "string", "number", "boolean" but received type "object"
      wled.0	2021-08-05 00:37:14.182	info	(11249) State value to set for "wled.0.8cce4ed829ab._info.mac" has to be type "number" but received type "string"
      wled.0	2021-08-05 00:37:14.062	info	(11249) State value to set for "wled.0.8cce4ed829ab._info.leds.pin" has to be one of type "string", "number", "boolean" but received type "object"
      und
      wled.0	2021-08-05 00:50:26.144	info	(8316) [Error catched and send to Sentry, thank you collaborating!] error: State attribute definition missing for + ndc
      wled.0	2021-08-05 00:50:25.618	info	(8316) [Error catched and send to Sentry, thank you collaborating!] error: State attribute definition missing for + fps
      Wenn ich das richtig verstehe, scheint es hier ein "Format Problem" mit dem Adapter zugeben. Ich selber rufe diese Objekte gar nicht auf, von daher denke ich mir mal, dass der WLED Adapter hier versucht, zu kommunizieren. Bis jetzt scheint noch alles zu funktionieren...
      Marcus
      Thomas Braun F 2 Replies Last reply Reply Quote 0
        Thomas Braun Most Active @mguenther last edited by
        @mguenther
        Das war hiermit gemeint:
        Informationen zur Version
        Die neue Version fokussiert sich neben Optimierungen, Bugfixes und einigen neuen Features vor allem weiter daran den Wildwuchs in der Umsetzung einiger Adapter etwas einzugrenzen. Im Zuge dieser neuen Checks wurden eine ganze Reihe Adapter aktualisiert - zu viele um hier alle zu nennen!
        Bitte unterstützt hier weiter für ggf. noch übriggebliebene Adapter und legt bei den relevanten Adaptern im GitHub Issues an, damit diese Dinge gefixt werden können.
          Fabian1 @mguenther last edited by
          @mguenther Bitte unbedingt ein Issue auf Github beim WLED Adapter aufmachen.
          • Dutchman
            @mguenther fixed in 0.5.7 sollte heute nachmittag im latest sein und nieste Woche im stable
            T 1 Reply Last reply Reply Quote 2
              tony63526 @Dutchman last edited by
              @dutchman Vielen Dank!
              typ variable wled
