    4. Install node-red
    Install node-red
    • sissiwup
      sissiwup last edited by
      habe node-red update durchgeführt. Danach ging nix mehr.
      Danach habe ich node-red in iobroker deinstalliert.
      Wenn ich neu installieren möchte kommt:
      $ ./iobroker add node-red
      host.zotac create instance node-red
      ERROR: host.zotac error: reading io-package.json Error: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.node-red/io-package.json'
      ERROR: process exited with code 20
      bei manueller Installation kommt:
      iobroker.core@1.0.0 /opt/iobroker
      └── mongodb@2.2.22  extraneous
      npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/buildmail/package.json'
      npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/commist/package.json'
      npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/concat-stream/package.json'
      npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/duplexify/package.json'
      npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/feedparser/package.json'
      npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/follow-redirects/package.json'
      npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/fs.notify/package.json'
      npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/glob-stream/package.json'
      npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/imap/package.json'
      npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/js2xmlparser/package.json'
      npm ERR! Linux 3.16.0-4-amd64
      npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "install" "iobroker.node-red"
      npm ERR! node v6.9.2
      npm ERR! npm  v4.1.2
      npm ERR! path /opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/node_modules/mqtt/node_modules/commist/node_modules/.bin/leven
      npm ERR! code EEXIST
      npm ERR! Refusing to delete /opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/node_modules/mqtt/node_modules/commist/node_modules/.bin/leven: is outside /opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/node_modules/mqtt/node_modules/commist/node_modules/leven and not a link
      npm ERR! File exists: /opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/node_modules/mqtt/node_modules/commist/node_modules/.bin/leven
      npm ERR! Move it away, and try again.
      npm ERR! Please include the following file with any support request:
      npm ERR!     /opt/iobroker/npm-debug.log
        Ich vermute, dass node-red gerade läuft und deswegen nicht gelöscht werden kann.
        cd /opt/iobroker
        iobroker stop node-red
        cd /opt/iobroker/node_modules/iobroker.node-red/
        sudo rm * -R
        cd ..
        sudo rmdir iobroker.node-red
        cd /opt/iobroker
        sudo npm i iobroker.node-red
        • sissiwup
          Habe node-red jetzt komplett gelöscht. Der Adapter hat nur Probleme gemacht.
          Bei jeden update wurden die nachinstallierten Nodes vergessen etc.
          Die Sachen, die ich damit gemacht habe, können fast alles andere Adapter mittlerweile.
          Zusätzlich ein wenig Java-Skript und es läuft.
          81.0k
