    4. Fehler bei installation des Harmony Adapters
      DrFirebird last edited by
      bei mir kommt es zu folgendem Fehler bei der installation des Harmony Adapters:
      iobroker 2017-01-31 12:44:31.933 info exit 25
      iobroker 2017-01-31 12:44:31.903 error host.ioBroker-Pi2 Cannot install iobroker.harmony: 1
      iobroker 2017-01-31 12:44:31.877 info npm ERR! /npm-debug.log
      iobroker 2017-01-31 12:44:31.877 info npm ERR! Please include the following file with any support request:
      iobroker 2017-01-31 12:44:31.475 info npm ERR! Please check if you have git installed and in your PATH.
      iobroker 2017-01-31 12:44:31.475 info Failed using git.npm ERR! This is most likely not a problem with npm itself.
      iobroker 2017-01-31 12:44:31.465 info npm ERR!
      iobroker 2017-01-31 12:44:31.465 info npm ERR! not found: git
      iobroker 2017-01-31 12:44:31.457 info npm ERR! code ENOGIT
      iobroker 2017-01-31 12:44:31.447 info npm ERR! npm v2.15.11
      iobroker 2017-01-31 12:44:31.447 info npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "install" "iobroker.harmony" "–production" "--prefix" "/opt/iobroker"npm ERR! node v4.7.2
      iobroker 2017-01-31 12:44:31.431 info ERR! Linux 4.4.38-v7+
      iobroker 2017-01-31 12:44:31.429 info npm
      iobroker 2017-01-31 12:44:30.694 info WARN deprecated node-xmpp-stanza@1.1.0: use @xmpp/xml package
      iobroker 2017-01-31 12:44:30.690 info npm
      iobroker 2017-01-31 12:44:30.562 info ERR! git clone --template=/root/.npm/_git-remotes/_templates --mirror https://github.com/swissmanu/ltx.git /root/.npm/_git-remotes/https-github-com-swissmanu-ltx-git-634cc128: undefined
      iobroker 2017-01-31 12:44:30.555 info undefinednpm
      iobroker 2017-01-31 12:44:30.551 info git clone --template=/root/.npm/_git-remotes/_templates --mirror https://github.com/swissmanu/ltx.git /root/.npm/_git-remotes/https-github-com-swissmanu-ltx-git-634cc128:
      iobroker 2017-01-31 12:44:30.549 info ERR!
      iobroker 2017-01-31 12:44:30.547 info npm
      iobroker 2017-01-31 12:44:30.224 info npm WARN addRemoteGit git+https://github.com/swissmanu/ltx.git#cd ... ltx-parser resetting remote /root/.npm/_git-remotes/https-github-com-swissmanu-ltx-git-634cc128 because of error: { [Error: no
      iobroker 2017-01-31 12:44:30.224 info npm WARN addRemoteGit at FSReqWrap.oncomplete (fs.js:82:15)
      iobroker 2017-01-31 12:44:30.224 info npm WARN addRemoteGit at /usr/lib/node_modules/npm/node_modules/which/node_modules/isexe/access.js:8:5
      iobroker 2017-01-31 12:44:30.224 info addRemoteGit at /usr/lib/node_modules/npm/node_modules/which/which.js:90:16npm WARN addRemoteGit at /usr/lib/node_modules/npm/node_modules/which/node_modules/isexe/index.js:44:5
      iobroker 2017-01-31 12:44:30.199 info WARN
      iobroker 2017-01-31 12:44:30.192 info at E (/usr/lib/node_modules/npm/node_modules/which/which.js:81:29)npm
      iobroker 2017-01-31 12:44:30.185 info npm WARN addRemoteGit at F (/usr/lib/node_modules/npm/node_modules/which/which.js:69:19)npm WARN addRemoteGit
      iobroker 2017-01-31 12:44:30.181 info WARN addRemoteGit at getNotFoundError (/usr/lib/node_modules/npm/node_modules/which/which.js:14:12)
      iobroker 2017-01-31 12:44:30.178 info WARN addRemoteGit Error: not found: gitnpm
      iobroker 2017-01-31 12:44:30.176 info npm
      iobroker 2017-01-31 12:44:28.665 info engine harmonyhubjs-client@1.1.10: wanted: {"npm":">=3.0.0"} (current: {"node":"4.7.2","npm":"2.15.11"})
      iobroker 2017-01-31 12:44:28.662 info npm WARN
      iobroker 2017-01-31 12:44:21.363 info npm install iobroker.harmony --production --prefix "/opt/iobroker" (System call)
      Kann mir jemand helfen ?
      Gruß,
      Michael
        habe es hinbekommen …..... es fehlte ein Paket 😄
          Muehle79 last edited by
          Hallo DrFirebird,
          Welches Paket hat denn gefehlt? Ich habe das selbe Problem mit dem Adapter.
          Muehle
            Hallo und Willkommen im Forum!
            @Muehle79:
            Welches Paket hat denn gefehlt? `
            @DrFirebird:
            iobroker 2017-01-31 12:44:31.457 info npm ERR! code ENOGIT `
            sudo apt-get install git
              Super
              Danke dir. Jetzt gehts hier auch
              Muehle
              • Ranzig93
                Ranzig93 last edited by
                Hallo
                Hab das selbe Problem nur ich weis nicht wie ich git installieren
                kann weil ich ibroker per Docker installiert habe.
                Wo gebe ich da den Befehl ein ?
                Vielen dank im voraus!
                  Schau mal hier https://git-scm.com/book/de/v1/Los-geht … stallieren
                  Muehle
                  1.0k
