    4. Telegram sendet nicht mehr
    • sissiwup
      sissiwup last edited by sissiwup
      telegram hat das senden eingestellt:
      telegram.0 29239	2021-08-14 11:29:51.111	debug	Received command "send": {"text":"Anzahl Servicemeldungen:27\nEG <br>\nhttp://192.168.1.13/wh.html"}
      telegram.0 29239	2021-08-14 11:28:43.345	debug	getMe: {"id":*,"is_bot":true,"first_name":"*","username":"*_bot","can_join_groups":true,"can_read_all_group_messages":false,"supports_inline_queries":false}
      telegram.0 29239	2021-08-14 11:28:38.230	debug	Start polling with: 300(number) ms interval
      telegram.0 29239	2021-08-14 11:28:38.148	debug	Schedule restart: 4 5 * * *
      telegram.0 29239	2021-08-14 11:28:38.128	info	starting. Version 1.10.0 in /opt/iobroker/node_modules/iobroker.telegram, node: v14.17.0, js-controller: 3.3.15
      telegram.0 29239	2021-08-14 11:28:37.969	debug	statesDB connected
      telegram.0 29239	2021-08-14 11:28:37.968	debug	States connected to redis: 127.0.0.1:9000
      telegram.0 29239	2021-08-14 11:28:37.923	debug	States create User PubSub Client
      telegram.0 29239	2021-08-14 11:28:37.922	debug	States create System PubSub Client
      telegram.0 29239	2021-08-14 11:28:37.919	debug	Redis States: Use Redis connection: 127.0.0.1:9000
      telegram.0 29239	2021-08-14 11:28:37.919	debug	objectDB connected
      telegram.0 29239	2021-08-14 11:28:37.917	debug	Objects connected to redis: 127.0.0.1:9001
      telegram.0 29239	2021-08-14 11:28:37.909	debug	Objects client initialize lua scripts
      telegram.0 29239	2021-08-14 11:28:37.908	debug	Objects create User PubSub Client
      telegram.0 29239	2021-08-14 11:28:37.908	debug	Objects create System PubSub Client
      telegram.0 29239	2021-08-14 11:28:37.908	debug	Objects client ready ... initialize now
      telegram.0 29239	2021-08-14 11:28:37.897	debug	Redis Objects: Use Redis connection: 127.0.0.1:9001
      host.zotac 2021-08-14 11:28:37.558	info	instance system.adapter.telegram.0 started with pid 29239
      host.zotac 2021-08-14 11:28:35.510	info	instance system.adapter.telegram.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      Fehler sehe ich keine. Adapter ist grün. Es komme auch nicht die "-" Meldungen zum Start / Stop
      Token und Passwort habe ich nicht geändert. Hat auch schonmal funktioniert.
      • haselchen
        haselchen Most Active @sissiwup last edited by
        @sissiwup
        Ich hab 8 Instanzen, laufen alle.
        Heute Nacht hatte ich 2-3 Polling Warnungen im Log.
        Kann bei dem ganzen Traffic mal passieren.
        Ich benutze allerdings kein Redis.
        Den Scheduled Restart solltest du mal löschen.
        Für mich unsinnig den Adapter jeden Tag um 5 Uhr oder so ähnlich,neu zu starten.
        sissiwup crunchip 2 Replies Last reply Reply Quote 0
        • sissiwup
          sissiwup @haselchen last edited by sissiwup
          @haselchen sagte in Telegram sendet nicht mehr:
          @sissiwup
          Ok, das mit den restart kann ich machen. Was bedeutet "redis" in diesen Zusammenhang?
          PS: telegram über homematic und über server laufen auch noch ohne Probleme.
          • crunchip
            crunchip Forum Testing Most Active @haselchen last edited by
            tust du sehr wohl, man achte auf den Port, das ist die interne iobroker redis Datenbank
            das war mal so eingebaut, da telegram hin und wieder Probleme bereitete und damit behoben wurde
            @sissiwup sagte in Telegram sendet nicht mehr:
            hast du mal versucht etwas anderes zu senden, als deine "html"
            sissiwup 1 Reply Last reply Reply Quote 0
            • haselchen
              @sissiwup
              Ist nur ne Vermutung, weil ich das in deinem Log gelesen habe.
              Einen erklärenden Beitrag kann dazu bestimmt @Homoran leisten 🙂
              • sissiwup
                sissiwup @crunchip last edited by sissiwup
                @crunchip sagte in Telegram sendet nicht mehr:
                ja, ich habe auch mal nur "test" las Text gesendet. Im log taucht das auch brav auf. Nur mehr sagt er auch nicht. Log steht auf debug.
                telegram.0 29239	2021-08-14 12:09:46.997	debug	Received command "send": {"text":"Test","disable_notification":true}
                PS: Ich mache das über Blocky.
                Normal kam aber auch immer eine Meldung wenn der Adpater neu gestartet wurde ... (telegram)
                • crunchip
                  crunchip Forum Testing Most Active @sissiwup last edited by
                  mal javascript instanz neu starten, vllt hilfts
                  kannst auch mal so testen, ob das funktioniert, such dir nen Datenpunkt in den Objekten und rechts über das Zahnrad...Einstellungen telegram mal aktivieren
                  • sissiwup
                    @crunchip
                    @crunchip
                    Habs zum laufen bekommen, wodran es nun wirklich lag?
                    Ich habe vom bot eine Nachricht an den iobroker gesendet.
                    Hier habe ich dass Passwort geändert. Dann hat er gefragt ob ich
                    die User neuer anlegen möchte (im Telegram Adapter, nachdem ich dort auch das Passwort geändert habe)
                    danach ging es auch wieder mit dem Senden
