    4. Errors beim Das Wetter-Adapter
    • O
      Oli last edited by
      ich bekomme seit neusten für den Adapter "Das Wetter" folgende Fehlermeldungen im Log:
      2021-08-16 10:01:13.516	error	instance system.adapter.daswetter.0 terminated with code 15 (UNKNOWN_ERROR)
      daswetter.0
      2021-08-16 10:01:13.476	error	exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextHours.Location_1.Day_4.Hour_5.pressure_value: Cannot check object existence of "daswetter.0.NextHours.Location_1.Day_4.Hour_5.pressure_value": Connection is closed.]
      daswetter.0
      2021-08-16 10:01:13.475	error	Cannot check object existence of "daswetter.0.NextHours.Location_1.Day_4.Hour_5.pressure_value": Connection is closed.
      daswetter.0
      2021-08-16 10:01:13.472	error	exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextHours.Location_1.Day_4.Hour_5.humidity_value: Cannot check object existence of "daswetter.0.NextHours.Location_1.Day_4.Hour_5.humidity_value": Connection is closed.]
      daswetter.0
      2021-08-16 10:01:13.471	error	Cannot check object existence of "daswetter.0.NextHours.Location_1.Day_4.Hour_5.humidity_value": Connection is closed.
      daswetter.0
      2021-08-16 10:01:13.468	error	exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextHours.Location_1.Day_4.Hour_5.rain_value: Cannot check object existence of "daswetter.0.NextHours.Location_1.Day_4.Hour_5.rain_value": Connection is closed.]
      daswetter.0
      2021-08-16 10:01:13.465	error	Cannot check object existence of "daswetter.0.NextHours.Location_1.Day_4.Hour_5.rain_value": Connection is closed.
      daswetter.0
      2021-08-16 10:01:13.463	error	exception in await insertIntoList [Error: DB closed]
      daswetter.0
      2021-08-16 10:01:13.461	warn	get state error: Connection is closed.
      daswetter.0
      2021-08-16 10:01:12.951	warn	Terminated (UNKNOWN_ERROR): Without reason
      daswetter.0
      2021-08-16 10:01:12.949	error	force terminate
      Datenpunkte sind vorhanden
      Instanz wurde schon mehrmals gestoppt und neu gestartet
      ioBroker wurde schon neu gestartet
      Weis jemand woran das liegen könnte?
      • Glasfaser
        Glasfaser @Oli last edited by
        @oli sagte in Errors beim Das Wetter-Adapter:
        Lösche alle Datenpunkte von dasWetter und lasse Sie neuanlegen.
          AndreasE112 @Glasfaser last edited by AndreasE112
          @glasfaser Hallo zusammen, ich hatte das gleiche Problem und hab die Datenpunkte gelöscht. Zuerst hab ich die Instanz gestoppt.
          Nun läuft mein Admin nicht mehr und ich komm nur noch mit Putty drauf.
          Kennt jemand abhilfe ?
          Hat sich erledigt... nach 15 Minuten warten und googlen läufts wieder
          adapter error log
