    4. Gelöst-Hilfe Fehler nach Restore
      Wurzeldoktor last edited by Wurzeldoktor
      Hallo habe mein Proxmox übersiedelt.
      Auf ne SSD von ner HD 🙂
      Gut ok habe das Backup eingespielt, möchte Iobroker starten - geht nicht 😕
      Gut ich installiere ne VM neu mit Debian 10.6.0 und spiele das Backup per Backit Up wieder ein...
      dann erhalte ich folgende ausgabe:
      Error: Cannot find module '../encodings'
      Require stack:
      - /opt/iobroker/node_modules/iobroker.admin/node_modules/iconv-lite/lib/index.js
      - /opt/iobroker/node_modules/iobroker.admin/node_modules/raw-body/index.js
      - /opt/iobroker/node_modules/iobroker.admin/node_modules/body-parser/lib/read.js
      - /opt/iobroker/node_modules/iobroker.admin/node_modules/body-parser/lib/types/json.js
      - /opt/iobroker/node_modules/iobroker.admin/node_modules/body-parser/index.js
      - /opt/iobroker/node_modules/iobroker.admin/node_modules/express/lib/express.js
      - /opt/iobroker/node_modules/iobroker.admin/node_modules/express/index.js
      - /opt/iobroker/node_modules/iobroker.admin/lib/web.js
      - /opt/iobroker/node_modules/iobroker.admin/main.js
          at Function.Module._resolveFilename (internal/modules/cjs/loader.js:815:15)
          at Function.Module._load (internal/modules/cjs/loader.js:667:27)
          at Module.require (internal/modules/cjs/loader.js:887:19)
          at require (internal/modules/cjs/helpers.js:74:18)
          at Object.getCodec (/opt/iobroker/node_modules/iobroker.admin/node_modules/iconv-lite/lib/index.js:65:27)
          at Object.getDecoder (/opt/iobroker/node_modules/iobroker.admin/node_modules/iconv-lite/lib/index.js:127:23)
          at getDecoder (/opt/iobroker/node_modules/iobroker.admin/node_modules/raw-body/index.js:45:18)
          at readStream (/opt/iobroker/node_modules/iobroker.admin/node_modules/raw-body/index.js:180:15)
          at getRawBody (/opt/iobroker/node_modules/iobroker.admin/node_modules/raw-body/index.js:108:12)
          at read (/opt/iobroker/node_modules/iobroker.admin/node_modules/body-parser/lib/read.js:77:3)
      kann mir wer helfen bitte?
      beim restore von Snapshot erhalte ich folgendes:
      daniel@iobroker:~$ iobroker status
       Cannot read system.config: null (OK when migrating or restoring)
       Cannot find view "system" for search "host"
      Objects type: file
      States  type: file
      daniel@iobroker:~$ iobroker info
      Platform       : linux
      os             : linux
      Architecture   : x64
      CPUs           : 4
      Speed          : 3192 MHz
      Model          : Common KVM processor
      RAM            : 7.7 GB
      System uptime  : 00:00:36
      Node.js        : v12.22.4
      Disk size      : 27.4 GiB
      Disk free      : 19.7 GiB
      NPM            : v6.14.14
      daniel@iobroker:~$ iobroker status instance
       Cannot find view "system" for search "instance"
      Uncaught Rejection: Error: Cannot find view "system"
          at ObjectsInRedisClient._getObjectView (/opt/iobroker/node_modules/@iobroker/db-objects-redis/lib/objects/objectsInRedisClient.js:3292:59)
          at processTicksAndRejections (internal/process/task_queues.js:97:5)
      Thomas Braun J 2 Replies Last reply Reply Quote 0
        Thomas Braun Most Active @Wurzeldoktor last edited by
        @wurzeldoktor
        Such nach dem [Mini-HowTo]
        Das sieht danach aus...
          Jan1 @Wurzeldoktor last edited by
          @wurzeldoktor
          und ändere mal die Überschrift, da Du mit dem Restor ein Problem hast und nicht mit dem Backup 😉
            Wurzeldoktor @Thomas Braun last edited by
            Mensch Danke haha
            hat spitze funktioniert 🙂 vielen Dank
