    4. [Gelöst] Nach Update: Error: Cannot find module
    • xxx_turbo_xxx
      xxx_turbo_xxx last edited by xxx_turbo_xxx
      nach einem Update bekomme ich ioBroker nicht mehr zum Laufen.
      Fehler:
      pi@raspberrypi:/opt/iobroker $ node -v
      v12.22.5
      pi@raspberrypi:/opt/iobroker $ npm -v
      6.14.14
      pi@raspberrypi:/opt/iobroker $ iobroker list instances
      internal/modules/cjs/loader.js:818
        throw err;
          at Function.Module._resolveFilename (internal/modules/cjs/loader.js:815:15)
          at Function.Module._load (internal/modules/cjs/loader.js:667:27)
          at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:60:12)
          at internal/main/run_main_module.js:17:47 {
        code: 'MODULE_NOT_FOUND',
        requireStack: []
      Was ist da schief gelaufen und wie bekomme ich das wieder hin?
      Danke für eure Unterstützung!
        Thomas Braun Most Active @xxx_turbo_xxx last edited by
        @xxx_turbo_xxx sagte in Nach Update: Error: Cannot find module:
        nach einem Update
        Und welches Update?
        which nodejs node npm && nodejs -v && node -v && npm -v && apt policy nodejs
        cd /opt/iobroker
        sudo -H -u iobroker npm install iobroker.js-controller
        xxx_turbo_xxx 2 Replies Last reply Reply Quote 0
        • xxx_turbo_xxx
          xxx_turbo_xxx @Thomas Braun last edited by
          nach apt-get update und apt-get upgrade
          pi@raspberrypi:/opt/iobroker $ which nodejs node npm && nodejs -v && node -v && npm -v && apt policy nodejs
          /usr/bin/nodejs
          /usr/bin/node
          /usr/bin/npm
          v12.22.5
          v12.22.5
          6.14.14
          nodejs:
            Installiert:           12.22.5-1nodesource1
            Installationskandidat: 12.22.5-1nodesource1
            Versionstabelle:
           *** 12.22.5-1nodesource1 500
                  500 https://deb.nodesource.com/node_12.x buster/main armhf Packages
                  100 /var/lib/dpkg/status
               10.24.0~dfsg-1~deb10u1 500
          • xxx_turbo_xxx
            pi@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-controller
            npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
            > iobroker.js-controller@3.3.15 preinstall /opt/iobroker/node_modules/iobroker.js-controller
            > node lib/preinstallCheck.js
            NPM version: 6.14.14
            > iobroker.js-controller@3.3.15 install /opt/iobroker/node_modules/iobroker.js-controller
            > node iobroker.js setup first
             Cannot read system.config: null (OK when migrating or restoring)
            object 0_userdata.0.example_state created
            object 0_userdata.0 created
            object alias.0 created
            object system.certificates created
            object system.repositories created
            object system.config created
            object enum.functions created
            object enum.rooms created
            object system.group.user created
            object system.group.administrator created
            object _design/custom created
            object _design/system created
            object system.meta.uuid created: e7208598-4b56-c6e1-1dde-2e6a782357cf
            object system.user.admin created
            The following notifications happened during sync:
            - Ignoring Directory "admin.admin" because officially not created as meta object. Please remove directory!
            - Ignoring Directory "alexa2.admin" because officially not created as meta object. Please remove directory!
            - Ignoring Directory "backitup.admin" because officially not created as meta object. Please remove directory!
            - Ignoring Directory "cloud.admin" because officially not created as meta object. Please remove directory!
            - Ignoring Directory "discovery.admin" because officially not created as meta object. Please remove directory!
            - Ignoring Directory "ds18b20.admin" because officially not created as meta object. Please remove directory!
            - Ignoring Directory "dwd.admin" because officially not created as meta object. Please remove directory!
            - Ignoring Directory "ebus.admin" because officially not created as meta object. Please remove directory!
            - Ignoring Directory "find-my-iphone.admin" because officially not created as meta object. Please remove directory!
            - Ignoring Directory "flot" because officially not created as meta object. Please remove directory!
            - Ignoring Directory "flot.admin" because officially not created as meta object. Please remove directory!
            - Ignoring Directory "fritzdect.admin" because officially not created as meta object. Please remove directory!
            - Ignoring Directory "ham.admin" because officially not created as meta object. Please remove directory!
            - Ignoring Directory "harmony.admin" because officially not created as meta object. Please remove directory!
            - Ignoring Directory "hue-extended.admin" because officially not created as meta object. Please remove directory!
            - Ignoring Directory "hue.admin" because officially not created as meta object. Please remove directory!
            - Ignoring Directory "ical.admin" because officially not created as meta object. Please remove directory!
            - Ignoring Directory "influxdb.admin" because officially not created as meta object. Please remove directory!
            - Ignoring Directory "info.admin" because officially not created as meta object. Please remove directory!
            - Ignoring Directory "iot.admin" because officially not created as meta object. Please remove directory!
            - Ignoring Directory "javascript.admin" because officially not created as meta object. Please remove directory!
            - Ignoring Directory "luftdaten.admin" because officially not created as meta object. Please remove directory!
            - Ignoring Directory "mobile" because officially not created as meta object. Please remove directory!
            - Ignoring Directory "mobile.admin" because officially not created as meta object. Please remove directory!
            - Ignoring Directory "modbus.admin" because officially not created as meta object. Please remove directory!
            - Ignoring Directory "mqtt.admin" because officially not created as meta object. Please remove directory!
            - Ignoring Directory "octoprint.admin" because officially not created as meta object. Please remove directory!
            - Ignoring Directory "openweathermap.admin" because officially not created as meta object. Please remove directory!
            - Ignoring Directory "ping.admin" because officially not created as meta object. Please remove directory!
            - Ignoring Directory "pollenflug.admin" because officially not created as meta object. Please remove directory!
            - Ignoring Directory "pushover.admin" because officially not created as meta object. Please remove directory!
            - Ignoring Directory "rpi2.admin" because officially not created as meta object. Please remove directory!
            - Ignoring Directory "samsung.admin" because officially not created as meta object. Please remove directory!
            - Ignoring Directory "shelly.admin" because officially not created as meta object. Please remove directory!
            - Ignoring Directory "shuttercontrol.admin" because officially not created as meta object. Please remove directory!
            - Ignoring Directory "simple-api.admin" because officially not created as meta object. Please remove directory!
            - Ignoring Directory "smartmeter.admin" because officially not created as meta object. Please remove directory!
            - Ignoring Directory "socketio.admin" because officially not created as meta object. Please remove directory!
            - Ignoring Directory "solarwetter.admin" because officially not created as meta object. Please remove directory!
            - Ignoring Directory "sonos.admin" because officially not created as meta object. Please remove directory!
            - Ignoring Directory "tado.admin" because officially not created as meta object. Please remove directory!
            - Ignoring Directory "tankerkoenig.admin" because officially not created as meta object. Please remove directory!
            - Ignoring Directory "tr-064.admin" because officially not created as meta object. Please remove directory!
            - Ignoring Directory "upnp.admin" because officially not created as meta object. Please remove directory!
            - Ignoring Directory "vaillant.admin" because officially not created as meta object. Please remove directory!
            - Ignoring Directory "vis" because officially not created as meta object. Please remove directory!
            - Ignoring Directory "vis.0" because officially not created as meta object. Please remove directory!
            - Ignoring Directory "vis.admin" because officially not created as meta object. Please remove directory!
            - Ignoring Directory "web" because officially not created as meta object. Please remove directory!
            - Ignoring Directory "web.admin" because officially not created as meta object. Please remove directory!
            - Ignoring Directory "yahka.admin" because officially not created as meta object. Please remove directory!
            Renamed repository "default to "stable"
            Renamed repository "latest to "beta"
            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.2 (node_modules/chokidar/node_modules/fsevents):
            npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"        any"} (current: {"os":"linux","arch":"arm"})
            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@^1.0.7 (node_modules/iobroker.info/node_module        s/osx-temperature-sensor):
            npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.7: wanted {"os":"da        rwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
            + iobroker.js-controller@3.3.15
            added 36 packages from 58 contributors in 47.074s
            49 packages are looking for funding
              run `npm fund` for details
            mikeal created this issue in request/request
            open Request’s Past, Present and Future #3142
              Homoran Global Moderator Administrators @xxx_turbo_xxx last edited by
              sieh mal nach dem "Mini-HowTo"
              xxx_turbo_xxx 1 Reply Last reply Reply Quote 0
              • xxx_turbo_xxx
                xxx_turbo_xxx @Homoran last edited by
                @homoran und schwups... da isser wieder 🙂
                Vielen Dank!
                error nodurle not found
