    4. sonoff v2.4.5 The "string" argument must be of type string
      lylabsiob last edited by
      Systemdata Bitte Ausfüllen
      Hardwaresystem: Synology NAS DS916
      Arbeitsspeicher: 8GB
      Festplattenart: HDD
      Betriebssystem: DSM 6.2.4-25556
      Node-Version: v12.22.5
      Nodejs-Version: 10.x.x
      NPM-Version: 6.14.14
      Installationsart: docker
      Image genutzt: Ja
      Ort/Name der Imagedatei: buanet/iobroker:latest-v5
      Hallo, der Sonoff-Adapter wirft nach Update immer den folgenden Fehler:
      TypeError [ERR_INVALID_ARG_TYPE]: The "string" argument must be of type string or an instance of Buffer or ArrayBuffer. Received type number (1) at Function.byteLength (buffer.js:725:11) at publish (/opt/iobroker/node_modules/mqtt-packet/writeToStream.js:334:51) at generate (/opt/iobroker/node_modules/mqtt-packet/writeToStream.js:34:14) at Writable.write [as _write] (/opt/iobroker/node_modules/mqtt-connection/lib/writeToStream.js:13:9) at doWrite (_stream_writable.js:403:12) at writeOrBuffer (_stream_writable.js:387:5) at Writable.write (_stream_writable.js:318:11) at Connection.Duplexify._write (/opt/iobroker/node_modules/duplexify/index.js:208:22) at doWrite (/opt/iobroker/node_modules/readable-stream/lib/_stream_writable.js:428:64) at writeOrBuffer (/opt/iobroker/node_modules/readable-stream/lib/_stream_writable.js:417:5)
      Irgendeine Idee?
      Problem wurde vor 16 Tagen von einem Bot gemeldet: https://github.com/ioBroker/ioBroker.sonoff/issues/209
      iobroker-sentry-github-app[bot] created this issue in ioBroker/ioBroker.sonoff
      closed TypeError [ERR_INVALID_ARG_TYPE]: The "string" argument must be one of type string, Buffer, or ArrayBuffer. Received type number #209
