    4. vofo-speedtest: Create state error = Error: DB closed
      Thomas Braun Most Active last edited by Thomas Braun
      Seit heute meldet sich der vofo-speedtest mit dieser Meldung:
      2021-09-02 17:23:00.118  - info: host.chet instance system.adapter.vofo-speedtest.0 started with pid 1284
      2021-09-02 17:23:31.245  - warn: vofo-speedtest.0 (1284) Could not perform strict object check of state vofo-speedtest.0.Results.upload_MB_calc: DB closed
      2021-09-02 17:23:31.276  - warn: vofo-speedtest.0 (1284) Could not perform strict object check of state vofo-speedtest.0.Results.upload_MB: DB closed
      2021-09-02 17:23:31.281  - warn: vofo-speedtest.0 (1284) Could not perform strict object check of state vofo-speedtest.0.Results.upload_Mb: DB closed
      2021-09-02 17:23:31.283  - warn: vofo-speedtest.0 (1284) Could not perform strict object check of state vofo-speedtest.0.Results.download_MB_calc: DB closed
      2021-09-02 17:23:31.286  - warn: vofo-speedtest.0 (1284) Could not perform strict object check of state vofo-speedtest.0.Results.download_Mb_calc: DB closed
      2021-09-02 17:23:31.297  - error: vofo-speedtest.0 (1284) Create state error = Error: DB closed
      2021-09-02 17:23:31.298  - error: vofo-speedtest.0 (1284) Create state error = Error: DB closed
      2021-09-02 17:23:31.300  - error: vofo-speedtest.0 (1284) Create state error = Error: DB closed
      2021-09-02 17:23:31.301  - error: vofo-speedtest.0 (1284) Create state error = Error: DB closed
      2021-09-02 17:23:31.331  - info: host.chet instance system.adapter.vofo-speedtest.0 terminated with code 0 (NO_ERROR)
      Wo kann/muss da was eingestellt werden? Die Werte werden dem history-Adapter übergeben.
      Edit: Hat sich wohl erledigt. Der nächste Lauf war wieder wie üblich.
