    4. Error JavaScript
    Error JavaScript
      A Former User last edited by
      Keine Ahnung was ich damit anfangen kann. Kam nach dem Update auf 12.22.6
      iobroker fix hab ich schon gestartet und hilft nicht.
      javascript.0
      2021-09-05 22:33:54.173	error	In file included from ../src/binding.cc:6:/home/iobroker/.cache/node-gyp/12.22.6/include/node/node.h:736:43: warning: cast between incompatible function types from ‘void (*)(Nan::ADDON_REGISTER_FUNCTION_ARGS_TYPE)’ {aka ‘void (*)(v8::Local<v8::Object>)’} to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type] (node::addon_register_func) (regfunc), \ ^/home/iobroker/.cache/node-gyp/12.22.6/include/node/node.h:770:3: note: in expansion of macro ‘NODE_MODULE_X’ NODE_MODULE_X(modname, regfunc, NULL, 0) // NOLINT (readability/null_usage) ^~~~~~~~~~~~~../src/binding.cc:2003:1: note: in expansion of macro ‘NODE_MODULE’ NODE_MODULE(sshcrypto, init) ^~~~~~~~~~~
      javascript.0
      2021-09-05 22:33:52.733	error	In file included from ../src/binding.cc:1:/home/iobroker/.cache/node-gyp/12.22.6/include/node/node.h:736:43: warning: cast between incompatible function types from ‘void (*)(Nan::ADDON_REGISTER_FUNCTION_ARGS_TYPE)’ {aka ‘void (*)(v8::Local<v8::Object>)’} to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type] (node::addon_register_func) (regfunc), \ ^/home/iobroker/.cache/node-gyp/12.22.6/include/node/node.h:770:3: note: in expansion of macro ‘NODE_MODULE_X’ NODE_MODULE_X(modname, regfunc, NULL, 0) // NOLINT (readability/null_usage) ^~~~~~~~~~~~~../src/binding.cc:153:1: note: in expansion of macro ‘NODE_MODULE’ NODE_MODULE(cpufeatures, init) ^~~~~~~~~~~
      Plattform
      linux
      Betriebssystem
      linux
      Architektur
      x64
      Node.js
      v12.22.6
      NPM
      6.14.15
      Aktive Instanzen
      41
      location
      /opt/iobroker/
      |Hardwaresystem:| NUC
      |Arbeitsspeicher:| 8GB |
        Thomas Braun Most Active @Guest last edited by
        @brainbug
        nodeJS ist wie installiert?
        npm Cache gelöscht?
          A Former User @Thomas Braun last edited by A Former User
          Wie in der Installationsanleitung und dann immer per Update auf die nächste Version.
          npm Cache gelöscht?
          Ich Google, keine Ahnung wie das geht.
          Wenn ich es gemacht habe schreibe ich.
            @brainbug
            which nodejs node npm && nodejs -v && node -v && npm -v && sudo apt update && sudo apt update && apt policy nodejs
            cd /opt/iobroker
            npm cache clear --force
              which nodejs node npm && nodejs -v && node -        v && npm -v && sudo apt update && sudo apt update && apt policy nodejs
              /usr/bin/nodejs
              /usr/bin/node
              /usr/bin/npm
              v12.22.6
              v12.22.6
              6.14.15
              OK:1 http://deb.debian.org/debian buster InRelease
              Holen:2 http://security.debian.org/debian-security buster/updates InRelease [65,        4 kB]
              Holen:3 http://deb.debian.org/debian buster-updates InRelease [51,9 kB]
              OK:4 https://deb.nodesource.com/node_12.x buster InRelease
              Es wurden 117 kB in 0 s geholt (255 kB/s).
              Abhängigkeitsbaum wird aufgebaut.
              Statusinformationen werden eingelesen.... Fertig
              Alle Pakete sind aktuell.
              OK:2 http://security.debian.org/debian-security buster/updates InRelease
              OK:3 http://deb.debian.org/debian buster-updates InRelease
              nodejs:
                Installiert:           12.22.6-deb-1nodesource1
                Installationskandidat: 12.22.6-deb-1nodesource1
                Versionstabelle:
               *** 12.22.6-deb-1nodesource1 500
                      500 https://deb.nodesource.com/node_12.x buster/main amd64 Packages
                      100 /var/lib/dpkg/status
                   10.24.0~dfsg-1~deb10u1 500
                      500 http://deb.debian.org/debian buster/main amd64 Packages
                      500 http://security.debian.org/debian-security buster/updates/main amd64        Packages
              /opt/iobroker$ npm cache clear --force
              npm WARN using --force I sure hope you know what you are doing.
              Cache löschen erledigt.
              iobroker neugestartet und Fehler scheint weg zu sein, ich beobachte es.
                A Former User @Guest last edited by
                Nachdem ich gerade auf 3.3.16 upgedatet habe kam die Meldung wieder.
                javascript.0
                2021-09-09 17:38:59.164	error	In file included from ../src/binding.cc:6: /home/iobroker/.cache/node-gyp/12.22.6/include/node/node.h:736:43: warning: cast between incompatible function types from ‘void (*)(Nan::ADDON_REGISTER_FUNCTION_ARGS_TYPE)’ {aka ‘void (*)(v8::Local<v8::Object>)’} to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type] (node::addon_register_func) (regfunc), \ ^ /home/iobroker/.cache/node-gyp/12.22.6/include/node/node.h:770:3: note: in expansion of macro ‘NODE_MODULE_X’ NODE_MODULE_X(modname, regfunc, NULL, 0) // NOLINT (readability/null_usage) ^~~~~~~~~~~~~ ../src/binding.cc:2003:1: note: in expansion of macro ‘NODE_MODULE’ NODE_MODULE(sshcrypto, init) ^~~~~~~~~~~
                javascript.0
                2021-09-09 17:38:57.941	error	In file included from ../src/binding.cc:1: /home/iobroker/.cache/node-gyp/12.22.6/include/node/node.h:736:43: warning: cast between incompatible function types from ‘void (*)(Nan::ADDON_REGISTER_FUNCTION_ARGS_TYPE)’ {aka ‘void (*)(v8::Local<v8::Object>)’} to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type] (node::addon_register_func) (regfunc), \ ^ /home/iobroker/.cache/node-gyp/12.22.6/include/node/node.h:770:3: note: in expansion of macro ‘NODE_MODULE_X’ NODE_MODULE_X(modname, regfunc, NULL, 0) // NOLINT (readability/null_usage) ^~~~~~~~~~~~~ ../src/binding.cc:153:1: note: in expansion of macro ‘NODE_MODULE’ NODE_MODULE(cpufeatures, init) ^~~~~~~~~~~
