    2. English
    3. ioBroker general
    4. [Gelöst] Adapters show invalid mode
      DBh last edited by DBh
      After installing iobroker on a Raspi from scratch some of the adapters show "invalid mode":
      The instances themselves show no version number (although when updating they show the most recent one):
      Any ideas what went wrong?
        fastfoot @DBh last edited by
        @dbh sagte in Adapters show invalid mode:
        from scratch
        how exactly did you install?
          DBh @fastfoot last edited by
          @fastfoot :
          sudo curl -sL https://deb.nodesource.com/setup_12.x | sudo -E bash -
          sudo apt install -y nodejs
          sudo reboot now
          sudo curl -sL https://iobroker.net/install.sh | bash -
          sudo reboot now
          Raspbian was installed with the Raspi_Imager_1.6.2
            Thomas Braun Most Active @DBh last edited by
            is the only line that is necessary for a clean installation.
            What does your system reply to
            iobroker status
            iobroker update -i
            iobroker list adapters
            iobroker list instances
              DBh @Thomas Braun last edited by
              Hi Thomas,
              here the response to the commands:
              pi@pi04:/opt/iobroker $ iobroker status
              Objects type: file
              States type: file
              pi@pi04:/opt/iobroker $ iobroker update -i
              Used repository: default
              hash changed or no sources cached => force download of new sources
              update done
              Adapter "admin" : 5.1.23 , installed 5.1.23
              Adapter "backitup" : 2.1.17 , installed 2.1.17
              Adapter "discovery" : 2.7.0 , installed 2.7.0
              Adapter "heos" : 1.8.6 , installed 1.8.6
              Adapter "info" : 1.9.8 , installed 1.9.8
              Adapter "javascript" : 5.2.8 , installed 5.2.8
              Controller "js-controller" : 3.3.15 , installed 3.3.15
              Adapter "node-red" : 2.4.0 , installed 2.4.0
              Adapter "shelly" : 4.0.7 , installed 4.0.7
              Adapter "simple-api" : 2.6.1 , installed 2.6.1
              Adapter "socketio" : 3.1.4 , installed 3.1.4
              Adapter "vis" : 1.4.3 , installed 1.4.3
              Adapter "web" : 3.4.7 , installed 3.4.7
              pi@pi04:/opt/iobroker $ iobroker list adapters
              system.adapter.admin : admin - v5.1.23
              system.adapter.backitup : backitup - v2.1.17
              system.adapter.discovery : discovery - v2.7.0
              system.adapter.heos : heos - v1.8.6
              system.adapter.info : info - v1.9.8
              system.adapter.javascript : javascript - v5.2.8
              system.adapter.node-red : node-red - v2.4.0
              system.adapter.shelly : shelly - v4.0.7
              system.adapter.web : web - v3.4.7
              pi@pi04:/opt/iobroker $ iobroker list instances
              • system.adapter.admin.0 : admin : pi04 - enabled, port: 8081, bind: 0.0.0.0, run as: admin
              • system.adapter.backitup.0 : backitup : pi04 - enabled
              • system.adapter.discovery.0 : discovery : pi04 - enabled
                system.adapter.heos.0 : heos : pi04 - enabled
                system.adapter.info.0 : info : pi04 - enabled
              • system.adapter.javascript.0 : javascript : pi04 - enabled
              • system.adapter.node-red.0 : node-red : pi04 - enabled, port: 1880, bind: 0.0.0.0
              • system.adapter.shelly.0 : shelly : pi04 - enabled, port: 1882, bind: 0.0.0.0
                system.adapter.web.0 : web : pi04 - enabled
              • system.adapter.web.1 : web : pi04 - enabled, port: 8082, bind: 0.0.0.0, run as: admin
              • instance is alive
              Cheers
              Dieter
                Thomas Braun Most Active @DBh last edited by Thomas Braun
                @dbh
                Ich denke einem Dieter kann man auch deutsch antworten.
                Bitte Ausgaben aus der Konsole in CodeTags einbetten.
                  DBh last edited by
                  Klar 😉
                  Objects type: file
                  States  type: file
                  update done
                  + system.adapter.admin.0                  : admin                 : pi04                                     -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                  + system.adapter.backitup.0               : backitup              : pi04                                     -  enabled
                  + system.adapter.discovery.0              : discovery             : pi04                                     -  enabled
                  + system.adapter.javascript.0             : javascript            : pi04                                     -  enabled
                  + system.adapter.node-red.0               : node-red              : pi04                                     -  enabled, port: 1880, bind: 0.0.0.0
                  + system.adapter.shelly.0                 : shelly                : pi04                                     -  enabled, port: 1882, bind: 0.0.0.0
                  + system.adapter.web.1                    : web                   : pi04                                     -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                  + instance is alive
                  Thomas Braun paul53 2 Replies Last reply Reply Quote 0
                    @dbh
                    iobroker start info
                    Und warum zwei Instanzen von web?
                      Habe ich, nachdem das Problem aufgetreten ist, nochmals installiert.
                        @dbh
                        Widerspricht dem KISS-Prinzip. Schmeiß den raus.
                          paul53 @DBh last edited by paul53
                          @dbh
                          Was steht in den drei Objekten
                          • system.adapter.heos.0
                          • system.adapter.info.0
                          • system.adapter.web.0
                          unter "OBJEKTDATEN" hinter common.mode? Expertenmodus aktivieren!
                            "_id": "system.adapter.web.0",
                            "type": "instance",
                            "common": {
                              "name": "web",
                              "version": "3.4.7",
                              "title": "WEB server",
                              "titleLang": {
                                "en": "WEB server",
                                "de": "WEB-Server",
                                "ru": "Веб сервер",
                                "pt": "Servidor web",
                                "nl": "Web Server",
                                "fr": "Serveur Web",
                                "it": "Server web",
                                "es": "Servidor web",
                                "pl": "Serwer internetowy",
                                "zh-cn": "Web服务器"
                              "desc": {
                                "en": "opens a webserver for other adapters",
                                "de": "Stellt webserver für 'ioBroker Adapter' zur Verfügung",
                                "ru": "Запускает веб сервер для 'ioBroker драйверов'",
                                "pt": "abre um servidor web para outros adaptadores",
                                "nl": "opent een webserver voor andere adapters",
                                "fr": "ouvre un serveur web pour d'autres adaptateurs",
                                "it": "apre un server web per altri adattatori",
                                "es": "abre un servidor web para otros adaptadores",
                                "pl": "otwiera serwer internetowy dla innych kart",
                                "zh-cn": "为其他适配器服务的web服务器"
                              "mode": "daemon",
                            DBh @paul53 last edited by
                            Bin leider noch nicht so fit, du hast wahrscheinlich eine Konsolenkommando gemein. In der Weboberfläche sehe ich die Objekte nicht.
                              @dbh sagte: In der Weboberfläche sehe ich die Objekte nicht.
                              Unter "system" (rot).
                              Dann die Eigenschaften (Bleistift rechts).
                                Danke für die Unterstützung!
                                  "type": "instance",
                                  "protectedNative": [],
                                  "encryptedNative": [],
                                  "notifications": [],
                                  "instanceObjects": [],
                                  "objects": [],
                                  "common": {
                                    "name": "web",
                                    "title": "ioBroker web Adapter",
                                    "logLevel": "info",
                                    "host": "pi04",
                                    "enabled": true
                                  "native": {},
                                  "user": "system.user.admin",
                                  "ts": 1631008143484
                                  "type": "instance",
                                  "objects": [],
                                  "_id": "system.adapter.info.0",
                                  "common": {
                                    "name": "info",
                                    "title": "Information page",
                                    "logLevel": "info",
                                    "host": "pi04",
                                    "enabled": true
                                  "native": {},
                                  "ts": 1631009504485
                                  "type": "meta",
                                  "common": {
                                    "name": "admin",
                                    "type": "admin"
                                  "from": "system.host.pi04.cli",
                                  "ts": 1631003881490,
                                  "native": {},
                                  "_id": "heos.admin"
                                  @dbh
                                  Da ist wohl beim Erstellen der Instanzen einiges schief gelaufen.
                                  Lösche die Instanzen und erstelle sie neu. Falls es dann immer noch so aussieht, lösche die Adapter und installiere sie neu.
                                    @paul53 Danke, mache ich
                                      @paul53 Das Löschen und Neuanlegen der Instanzen hat gereicht. Läuft, besten Dank!
                                        @dbh sagte: Löschen und Neuanlegen der Instanzen hat gereicht.
                                        Dann markiere bitte das Thema in der Überschrift des ersten Beitrags als [Gelöst].
                                        • apollon77
                                          apollon77 last edited by
                                          Seeehr interessant ... Kann mir das gerade nicht erklären so recht. Falls der nächste das Problem hat wäre interessnt bo auch ein "upload" des betroffenen Adapters das fixt und falls der Adapter neu installiert war das Install log.
                                          Bzw Frage an die bisher betroffenen: Waren es neu installierte Adapter oder ist es "plötzlich aus heiteremHimmel" aufgetreten? Oder nach einem Update?
                                          Schlo 1 Reply Last reply Reply Quote 0
                                          • Schlo
                                            Schlo @apollon77 last edited by
                                            @apollon77
                                            Ich hatte ein ähnliches Problem. Ich nutze das aktuelle Docker-Image von ioBroker und bei mir waren alle Instanzen außer Admin, Backup und Discovery fehlerhaft oder sind nicht (richtig) gestartet.
                                            Löschen und über Adapter neu installieren hat es dann auch gefixt.
                                            Die Fehler treten nur (aber immer nachvollziehbar) auf, wenn ich die Installation per Geräte und Dienste finden -> Letzten Scan verwenden -> Instanz auswählen und "Instanzen erstellen" starte. Was ich als Newbie natürlich erst mal so gemacht hatte.
                                            Vielleicht hilft ja dieser Hinweis.
                                            OstfrieseUnterwegs 1 Reply Last reply Reply Quote 0
                                            invalid mode
                                            3197
