    4. Web Adapter 2.0.0 Nach update
      knopers1 last edited by
      ich habe geradeeben den WEB Adapter auf die V 2.0.0 aktualisiert.
      Jetzt ist der grüne Punkt unter Instanzen nicht da!
      Im Log steht:
      iobroker	2017-02-05 19:22:41.644	error	host.iobroker instance system.adapter.web.0 terminated with code 0 (OK)
      web.0	2017-02-05 19:22:41.153	info	web.0 starting. Version 2.0.0 in /opt/iobroker/node_modules/iobroker.web, node: v4.6.1
      iobroker	2017-02-05 19:22:37.776	info	host.iobroker instance system.adapter.web.0 started with pid 1251
      iobroker	2017-02-05 19:22:07.755	info	host.iobroker Restart adapter system.adapter.web.0 because enabled
      iobroker	2017-02-05 19:22:07.753	error	host.iobroker instance system.adapter.web.0 terminated with code 0 (OK)
      web.0	2017-02-05 19:22:07.276	info	web.0 starting. Version 2.0.0 in /opt/iobroker/node_modules/iobroker.web, node: v4.6.1
      iobroker	2017-02-05 19:22:03.879	info	host.iobroker instance system.adapter.web.0 started with pid 1241
      iobroker	2017-02-05 19:21:33.858	info	host.iobroker Restart adapter system.adapter.web.0 because enabled
      iobroker	2017-02-05 19:21:33.857	error	host.iobroker instance system.adapter.web.0 terminated with code 0 (OK)
      web.0	2017-02-05 19:21:33.395	info	web.0 starting. Version 2.0.0 in /opt/iobroker/node_modules/iobroker.web, node: v4.6.1
      iobroker	2017-02-05 19:21:30.159	info	host.iobroker instance system.adapter.web.0 started with pid 1190
      host.iobroker	2017-02-05 19:21:00.131	info	Restart adapter system.adapter.web.0 because enabled
      host.iobroker	2017-02-05 19:21:00.130	error	instance system.adapter.web.0 terminated with code 0 (OK)
      web.0	2017-02-05 19:21:00.089	info	http server listening on port 8082
      web.0	2017-02-05 19:21:00.072	error	at require (internal/module.js:12:17)
      web.0	2017-02-05 19:21:00.072	error	at Module.require (module.js:353:17)
      web.0	2017-02-05 19:21:00.072	error	at Function.Module._load (module.js:300:12)
      web.0	2017-02-05 19:21:00.072	error	at Module.load (module.js:343:32)
      web.0	2017-02-05 19:21:00.072	error	at Object.Module._extensions..js (module.js:416:10)
      web.0	2017-02-05 19:21:00.072	error	at Module._compile (module.js:409:26)
      web.0	2017-02-05 19:21:00.072	error	at Object. (/opt/iobroker/node_modules/iobroker.web/node_modules/iobroker.socketio/node_modules/socket.io/node_modules/engine.io/lib/server.js:8:16)
      web.0	2017-02-05 19:21:00.072	error	at Function.Module._load (module.js:276:25)
      web.0	2017-02-05 19:21:00.072	error	at Function.Module._resolveFilename (module.js:325:15)
      web.0	2017-02-05 19:21:00.072	error	Error: Cannot find module 'base64id'
      web.0	2017-02-05 19:21:00.060	error	uncaught exception: Cannot find module 'base64id'
      web.0	2017-02-05 19:20:59.608	info	starting. Version 2.0.0 in /opt/iobroker/node_modules/iobroker.web, node: v4.6.1
      host.iobroker	2017-02-05 19:20:56.413	info	instance system.adapter.web.0 started with pid 1143
      cloud.0	2017-02-05 19:20:27.350	info	2017-02-05T18:20:27.349Z Connected system.user.admin
      cloud.0	2017-02-05 19:20:27.022	info	Connection changed: CONNECTED
      cloud.0	2017-02-05 19:20:26.294	info	Connecting with https://iobroker.net:10555 with "knopers1_0338ffd0-cd25-11e6-b350-8d1e309c9d96"
      cloud.0	2017-02-05 19:20:26.182	info	starting. Version 0.6.3 in /opt/iobroker/node_modules/iobroker.cloud, node: v4.6.1
      host.iobroker	2017-02-05 19:20:26.386	info	Restart adapter system.adapter.web.0 because enabled
      Liegt es an der konfiguration des Adapters?
        kann ich noch etwas machen, oder soll ich meine alte Sicherung schon mal aufspielen?
        im Log steht etwas von:
        kann man dies nachinstallieren?
          @knopers1:
          Liegt es an der konfiguration des Adapters? `
          eher nicht.
          dein log sagt:
          @knopers1:
          web.0   2017-02-05 19:21:00.072   error   Error: Cannot find module 'base64id' `
          ich kenne das modul nicht 😞
          ich selber habe bereits 2.0.1 von Github drauf. kann mich nicht erinnern, dass ich damals Probleme hatte.
          Vielleicht versuchst du auch mal die 2.0.1.
          Andererseits hast du node v4.6.1, das ist IMHO nicht die neueste von v4.x
          Vielleicht kann jemand anderes etwas dazu sagen.
            @knopers1:
            kann man dies nachinstallieren? `
            https://www.npmjs.com/package/base64id
            Was hast du für eine Hardware?
              RPI 3
              root@iobroker:~# npm install base64id
              base64id@1.0.0 node_modules/base64id
              root@iobroker:~#
              Nach Neustart keine Änderung….
              Log: * host.iobroker 2017-02-05 19:48:02.315 error instance system.adapter.web.0 terminated with code 0 (OK)
              web.0 2017-02-05 19:48:02.260 info http server listening on port 8082
              web.0 2017-02-05 19:48:02.242 error at require (internal/module.js:12:17)
              web.0 2017-02-05 19:48:02.242 error at Module.require (module.js:353:17)
              web.0 2017-02-05 19:48:02.242 error at Function.Module._load (module.js:300:12)
              web.0 2017-02-05 19:48:02.242 error at Module.load (module.js:343:32)
              web.0 2017-02-05 19:48:02.242 error at Object.Module._extensions..js (module.js:416:10)
              web.0 2017-02-05 19:48:02.242 error at Module._compile (module.js:409:26)
              web.0 2017-02-05 19:48:02.242 error at Object. (/opt/iobroker/node_modules/iobroker.web/node_modules/iobroker.socketio/node_modules/socket.io/node_modules/engine.io/lib/server.js:8:16)
              web.0 2017-02-05 19:48:02.242 error at Function.Module._load (module.js:276:25)
              web.0 2017-02-05 19:48:02.242 error at Function.Module._resolveFilename (module.js:325:15)
              web.0 2017-02-05 19:48:02.242 error Error: Cannot find module 'base64id'
              web.0 2017-02-05 19:48:02.229 error uncaught exception: Cannot find module 'base64id'
              web.0 2017-02-05 19:48:01.745 info starting. Version 2.0.0 in /opt/iobroker/node_modules/iobroker.web, node: v4.6.1
                puuuhhhh,
                die V2.0.1 vom Github geht !!! :mrgreen:
                Glück gehabt. ich wollte alles schon Platt machen!
                Danke!
