    4. Keine Problem mit iot.0
    • Horst Böttcher
      Horst Böttcher last edited by
      Systemdata
      Hardwaresystem: RPI 4 & RPI 4
      Arbeitsspeicher: 4GB
      Festplattenart: SD-Karte
      Betriebssystem: 2021-03-04-raspios-buster-armhf-lite
      Node-Version: ? Node.js ?
      Nodejs-Version: v12.22.6
      NPM-Version: 6.14.15
      Installationsart: Neu
      Ort/Name der Imagedatei: Link
      Ich habe Gestern ein Neues System auf beiden Raspberry Pi 4 Modell B, 4GB RAM installiert hat auch bestens funktioniert
      doch jetzt zu meinem Problem
      2021-09-24 03:21:37.019 - info: iot.0 (802) Connection changed: disconnect
      2021-09-24 03:21:37.046 - info: iot.0 (802) Connection lost
      2021-09-24 03:22:12.025 - info: iot.0 (802) Connection changed: disconnect
      2021-09-24 03:22:48.471 - warn: hue-extended.0 (834) Error connecting to Hue Bridge: Host not reachable. Already retried 10x so far. Try again in 1 minute..
      2021-09-24 03:22:52.031 - info: iot.0 (802) Connection changed: disconnect
      2021-09-24 03:23:12.309 - info: iot.0 (802) Connection changed: connect
      2021-09-24 04:00:01.627 - info: iot.0 (802) Connection changed: disconnect
      2021-09-24 04:00:01.631 - info: iot.0 (802) Connection lost
      2021-09-24 04:00:01.626 - info: hue-extended.0 (834) Adapter stopped und unloaded.
      2021-09-24 04:00:01.589 - info: admin.0 (757) terminating http server on port 8081
      2021-09-24 04:00:01.586 - info: backitup.0 (779) cleaned everything up...
      2021-09-24 04:00:01.578 - info: web.0 (819) terminated http server on port 8082
      2021-09-24 04:00:01.564 - info: host.MasterPI received SIGTERM
      2021-09-24 04:00:01.695 - info: host.MasterPI stopInstance system.adapter.admin.0 (force=false, process=true)
      2021-09-24 04:00:01.697 - info: host.MasterPI stopInstance system.adapter.javascript.0 (force=false, process=true)
      2021-09-24 04:00:01.706 - info: host.MasterPI stopInstance system.adapter.discovery.0 (force=false, process=false)
      2021-09-24 04:00:01.707 - info: host.MasterPI stopInstance system.adapter.backitup.0 (force=false, process=true)
      2021-09-24 04:00:01.709 - info: host.MasterPI stopInstance system.adapter.iot.0 (force=false, process=true)
      2021-09-24 04:00:01.710 - info: host.MasterPI stopInstance system.adapter.web.0 (force=false, process=true)
      2021-09-24 04:00:01.711 - info: host.MasterPI stopInstance system.adapter.hue-extended.0 (force=false, process=true)
      2021-09-24 04:00:01.712 - info: host.MasterPI stopInstance system.adapter.broadlink2.0 (force=false, process=false)
      2021-09-24 04:00:01.713 - info: host.MasterPI stopInstance system.adapter.chromecast.0 (force=false, process=false)
      2021-09-24 04:00:01.778 - info: admin.0 (757) Got terminate signal TERMINATE_YOURSELF
      2021-09-24 04:00:01.788 - info: web.0 (819) Got terminate signal TERMINATE_YOURSELF
      2021-09-24 04:00:01.791 - info: iot.0 (802) Got terminate signal TERMINATE_YOURSELF
      2021-09-24 04:00:01.784 - info: backitup.0 (779) Got terminate signal TERMINATE_YOURSELF
      2021-09-24 04:00:01.804 - info: web.0 (819) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
      2021-09-24 04:00:01.804 - info: hue-extended.0 (834) Got terminate signal TERMINATE_YOURSELF
      2021-09-24 04:00:01.801 - info: iot.0 (802) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
      2021-09-24 04:00:01.810 - info: backitup.0 (779) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
      2021-09-24 04:00:01.811 - info: hue-extended.0 (834) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
      2021-09-24 04:00:01.813 - info: admin.0 (757) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
      2021-09-24 04:00:01.819 - info: host.MasterPI stopInstance system.adapter.admin.0 send kill signal
      2021-09-24 04:00:01.823 - info: host.MasterPI stopInstance system.adapter.javascript.0 send kill signal
      2021-09-24 04:00:01.824 - info: host.MasterPI stopInstance system.adapter.backitup.0 send kill signal
      2021-09-24 04:00:01.825 - info: host.MasterPI stopInstance system.adapter.iot.0 send kill signal
      2021-09-24 04:00:01.826 - info: host.MasterPI stopInstance system.adapter.web.0 send kill signal
      2021-09-24 04:00:01.827 - info: host.MasterPI stopInstance system.adapter.hue-extended.0 send kill signal
      2021-09-24 04:00:01.790 - info: javascript.0 (772) Got terminate signal TERMINATE_YOURSELF
      2021-09-24 04:00:01.866 - info: javascript.0 (772) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
      2021-09-24 04:00:02.840 - info: host.MasterPI stopInstance system.adapter.javascript.0 killing pid 772
      2021-09-24 04:00:03.056 - info: host.MasterPI instance system.adapter.backitup.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
      2021-09-24 04:00:03.058 - info: host.MasterPI instance system.adapter.iot.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
      2021-09-24 04:00:03.059 - info: host.MasterPI instance system.adapter.web.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
      2021-09-24 04:00:03.060 - info: host.MasterPI instance system.adapter.hue-extended.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
      2021-09-24 04:00:03.162 - info: host.MasterPI instance system.adapter.admin.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
      2021-09-24 04:00:03.163 - info: host.MasterPI All instances are stopped.
      2021-09-24 04:00:03.293 - info: host.MasterPI instance system.adapter.javascript.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
      2021-09-24 04:00:03.294 - info: host.MasterPI All instances are stopped.
      2021-09-24 04:00:03.359 - info: host.MasterPI terminated
      2021-09-24 04:00:30.548 - info: host.MasterPI iobroker.js-controller version 3.3.18 js-controller starting
      2021-09-24 04:00:30.561 - info: host.MasterPI Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
      2021-09-24 04:00:30.563 - info: host.MasterPI hostname: MasterPI, node: v12.22.6
      2021-09-24 04:00:30.564 - info: host.MasterPI ip addresses: 192.168.178.88 2001:16b8:5ce0:4000:bbeb:b20b:4e70:4b7f fe80::2758:4cb:b605:a38c
      2021-09-24 04:00:31.923 - info: host.MasterPI connected to Objects and States
      2021-09-24 04:00:32.010 - info: host.MasterPI added notifications configuration of host
      2021-09-24 04:00:33.349 - info: host.MasterPI 26 instances found
      2021-09-24 04:00:33.425 - info: host.MasterPI starting 7 instances
      2021-09-24 04:00:33.668 - info: host.MasterPI instance system.adapter.admin.0 started with pid 678
      2021-09-24 04:00:38.022 - info: host.MasterPI instance system.adapter.javascript.0 started with pid 689
      2021-09-24 04:00:39.478 - info: admin.0 (678) starting. Version 5.1.25 in /opt/iobroker/node_modules/iobroker.admin, node: v12.22.6, js-controller: 3.3.18
      2021-09-24 04:00:39.590 - info: admin.0 (678) requesting all states
      2021-09-24 04:00:39.592 - info: admin.0 (678) requesting all objects
      2021-09-24 04:00:57.335 - info: admin.0 (678) received all objects
      2021-09-24 04:00:57.669 - info: host.MasterPI instance system.adapter.backitup.0 started with pid 700
      2021-09-24 04:00:58.267 - info: admin.0 (678) http server listening on port 8081
      2021-09-24 04:00:58.269 - info: admin.0 (678) Use link "http://localhost:8081" to configure.
      2021-09-24 04:01:01.660 - info: host.MasterPI instance system.adapter.iot.0 started with pid 715
      2021-09-24 04:01:01.744 - info: backitup.0 (700) starting. Version 2.1.17 in /opt/iobroker/node_modules/iobroker.backitup, node: v12.22.6, js-controller: 3.3.18
      2021-09-24 04:01:01.909 - info: backitup.0 (700) [iobroker] backup was activated at 02:40 every 1 day(s)
      2021-09-24 04:01:02.732 - info: javascript.0 (689) starting. Version 5.2.8 in /opt/iobroker/node_modules/iobroker.javascript, node: v12.22.6, js-controller: 3.3.18
      2021-09-24 04:01:03.189 - info: javascript.0 (689) requesting all states
      2021-09-24 04:01:03.193 - info: javascript.0 (689) requesting all objects
      2021-09-24 04:01:04.568 - info: javascript.0 (689) received all objects
      2021-09-24 04:01:04.585 - info: javascript.0 (689) received all states
      2021-09-24 04:01:05.758 - info: host.MasterPI instance system.adapter.web.0 started with pid 736
      2021-09-24 04:01:07.649 - info: iot.0 (715) starting. Version 1.8.22 in /opt/iobroker/node_modules/iobroker.iot, node: v12.22.6, js-controller: 3.3.18
      2021-09-24 04:01:07.797 - info: iot.0 (715) Connecting with a18wym7vjdl22g.iot.eu-west-1.amazonaws.com
      2021-09-24 04:01:08.994 - info: iot.0 (715) [GHOME] deconz.0.Lights.4 is auto added with type ct.
      2021-09-24 04:01:09.171 - info: iot.0 (715) [GHOME] deconz.0.Lights.5 is auto added with type ct.
      2021-09-24 04:01:09.197 - info: iot.0 (715) Connection changed: connect
      2021-09-24 04:01:09.314 - info: iot.0 (715) [GHOME] deconz.0.Lights.6 is auto added with type ct.
      2021-09-24 04:01:09.372 - info: iot.0 (715) [GHOME] deconz.0.Lights.10 is auto added with type ct.
      2021-09-24 04:01:09.427 - info: iot.0 (715) [GHOME] deconz.0.Lights.11 is auto added with type ct.
      2021-09-24 04:01:09.503 - info: iot.0 (715) [GHOME] deconz.0.Lights.16 is auto added with type dimmer.
      2021-09-24 04:01:09.566 - info: iot.0 (715) [GHOME] deconz.0.Lights.17 is auto added with type dimmer.
      2021-09-24 04:01:09.669 - info: host.MasterPI instance system.adapter.hue-extended.0 started with pid 751
      2021-09-24 04:01:09.672 - info: iot.0 (715) [GHOME] deconz.0.Lights.18 is auto added with type ct.
      2021-09-24 04:01:09.747 - info: iot.0 (715) [GHOME] deconz.0.Lights.19 is auto added with type dimmer.
      2021-09-24 04:01:09.802 - info: iot.0 (715) [GHOME] deconz.0.Lights.21 is auto added with type ct.
      2021-09-24 04:01:09.856 - info: iot.0 (715) [GHOME] deconz.0.Lights.22 is auto added with type ct.
      2021-09-24 04:01:09.900 - info: iot.0 (715) [GHOME] hue-extended.0.lights.019-hue_play_1 is auto added with type info.
      2021-09-24 04:01:09.967 - info: web.0 (736) starting. Version 3.4.7 in /opt/iobroker/node_modules/iobroker.web, node: v12.22.6, js-controller: 3.3.18
      2021-09-24 04:01:10.907 - info: web.0 (736) socket.io server listening on port 8082
      2021-09-24 04:01:10.921 - info: web.0 (736) http server listening on port 8082
      2021-09-24 04:01:13.734 - error: host.MasterPI startInstance system.adapter.chromecast.0: required adapter "net-tools" not found!
      2021-09-24 04:01:14.288 - info: hue-extended.0 (751) starting. Version 2.0.0 in /opt/iobroker/node_modules/iobroker.hue-extended, node: v12.22.6, js-controller: 3.3.18
      2021-09-24 04:01:14.365 - info: hue-extended.0 (751) Establishing connection to bridge..
      2021-09-24 04:01:14.531 - info: hue-extended.0 (751) Using polling for state updates.
      2021-09-24 05:03:17.079 - info: iot.0 (715) Connection changed: disconnect
      2021-09-24 05:03:17.081 - info: iot.0 (715) Connection lost
      2021-09-24 05:03:22.362 - info: iot.0 (715) Connection changed: connect
      2021-09-24 05:54:52.692 - info: iot.0 (715) Connection changed: disconnect
      2021-09-24 05:54:52.692 - info: iot.0 (715) Connection lost
      2021-09-24 05:55:27.699 - info: iot.0 (715) Connection changed: disconnect
      2021-09-24 05:56:07.705 - info: iot.0 (715) Connection changed: disconnect
      2021-09-24 05:56:28.988 - info: iot.0 (715) Connection changed: connect
      2021-09-24 06:24:00.687 - error: iot.0 (715) [GHOME] Cannot updateState: Request contains an invalid argument.
      2021-09-24 06:24:00.800 - error: iot.0 (715) [GHOME] Cannot updateState: Request contains an invalid argument.
      2021-09-24 06:24:37.494 - error: iot.0 (715) [GHOME] Cannot updateState: Request contains an invalid argument.
      2021-09-24 07:20:59.343 - info: iot.0 (715) Connection changed: disconnect
      2021-09-24 07:20:59.344 - info: iot.0 (715) Connection lost
      2021-09-24 07:21:34.350 - info: iot.0 (715) Connection changed: disconnect
      2021-09-24 07:22:14.356 - info: iot.0 (715) Connection changed: disconnect
      2021-09-24 07:22:29.037 - warn: hue-extended.0 (751) Error connecting to Hue Bridge: Host not reachable. Already retried 10x so far. Try again in 1 minute..
      2021-09-24 07:23:04.361 - info: iot.0 (715) Connection changed: disconnect
      2021-09-24 07:23:32.157 - warn: hue-extended.0 (751) Error connecting to Hue Bridge: Host not reachable. Already retried 11x so far. Try again in 1 minute..
      2021-09-24 07:24:14.368 - info: iot.0 (715) Connection changed: disconnect
      2021-09-24 07:24:35.277 - warn: hue-extended.0 (751) Error connecting to Hue Bridge: Host not reachable. Already retried 12x so far. Try again in 1 minute..
      2021-09-24 07:25:38.397 - warn: hue-extended.0 (751) Error connecting to Hue Bridge: Host not reachable. Already retried 13x so far. Try again in 1 minute..
      2021-09-24 07:26:04.376 - info: iot.0 (715) Connection changed: disconnect
      2021-09-24 07:26:41.517 - warn: hue-extended.0 (751) Error connecting to Hue Bridge: Host not reachable. Already retried 14x so far. Try again in 1 minute..
      2021-09-24 07:27:44.637 - warn: hue-extended.0 (751) Error connecting to Hue Bridge: Host not reachable. Already retried 15x so far. Try again in 1 minute..
      2021-09-24 07:28:42.384 - info: iot.0 (715) Connection changed: disconnect
      2021-09-24 07:28:47.757 - warn: hue-extended.0 (751) Error connecting to Hue Bridge: Host not reachable. Already retried 16x so far. Try again in 1 minute..
      2021-09-24 07:30:50.618 - info: iot.0 (715) Connection changed: connect
      2021-09-24 08:55:56.395 - info: iot.0 (715) Connection changed: disconnect
      2021-09-24 08:55:56.397 - info: iot.0 (715) Connection lost
      2021-09-24 08:56:31.403 - info: iot.0 (715) Connection changed: disconnect
      2021-09-24 08:57:11.408 - info: iot.0 (715) Connection changed: disconnect
      2021-09-24 08:57:32.077 - warn: hue-extended.0 (751) Error connecting to Hue Bridge: Host not reachable. Already retried 10x so far. Try again in 1 minute..
      2021-09-24 08:58:01.415 - info: iot.0 (715) Connection changed: disconnect
      2021-09-24 08:58:35.197 - warn: hue-extended.0 (751) Error connecting to Hue Bridge: Host not reachable. Already retried 11x so far. Try again in 1 minute..
      2021-09-24 08:59:11.421 - info: iot.0 (715) Connection changed: disconnect
      2021-09-24 09:00:31.699 - info: iot.0 (715) Connection changed: connect
      2021-09-24 12:53:44.816 - info: iot.0 (715) Connection changed: disconnect
      2021-09-24 12:53:44.817 - info: iot.0 (715) Connection lost
      2021-09-24 12:54:09.850 - error: iot.0 (715) Error by device connection: "getaddrinfo EAI_AGAIN a18wym7vjdl22g.iot.eu-west-1.amazonaws.com"
      2021-09-24 12:54:09.851 - error: iot.0 (715) DNS name of a18wym7vjdl22g.iot.eu-west-1.amazonaws.com cannot be resolved: connection will be retried in 10 seconds.
      2021-09-24 12:54:09.853 - info: iot.0 (715) Connection changed: disconnect
      2021-09-24 12:54:19.910 - warn: iot.0 (715) Looks like your connection certificates are invalid. Please renew them via configuration dialog.
      2021-09-24 12:54:19.911 - info: iot.0 (715) Connection changed: disconnect
      2021-09-24 12:54:20.171 - info: iot.0 (715) Connection changed: connect
      2021-09-24 13:57:43.835 - error: iot.0 (715) [GHOME] Cannot updateState: Request contains an invalid argument.
      2021-09-24 13:57:45.913 - error: iot.0 (715) [GHOME] Cannot updateState: Request contains an invalid argument.
      2021-09-24 13:57:49.260 - error: iot.0 (715) [GHOME] Cannot updateState: Request contains an invalid argument.
      2021-09-24 13:57:58.115 - error: iot.0 (715) [GHOME] Cannot updateState: Request contains an invalid argument.
      2021-09-24 13:57:59.322 - error: iot.0 (715) [GHOME] Cannot updateState: Request contains an invalid argument.
