    4. [gelöst] Error: spawn /bin/ping ENOENT nach Update
      PeterImNetz last edited by PeterImNetz
      Ich habe heute meinen ibroker im Docker (buanet) auf den JS controller auf 3.3.18 aktualisiert.
      Seitdem bekomme ich massenhaft Fehlermeldungen von meinem ping Adapter. Das ist sicher ein Rechteproblem, aber wie kann ich das fixen?
      ping.0
      	2021-10-02 11:02:49.410	error	Error: ping.probe: there was an error while executing the ping program. check the path or permissions...: Error: spawn /bin/ping ENOENT
      ping.0
      	2021-10-02 11:02:49.405	error	Error: ping.probe: there was an error while executing the ping program. check the path or permissions...: Error: spawn /bin/ping ENOENT
      ping.0
      	2021-10-02 11:02:49.401	error	Error: ping.probe: there was an error while executing the ping program. check the path or permissions...: Error: spawn /bin/ping ENOENT
      ping.0
      	2021-10-02 11:02:49.396	error	Error: ping.probe: there was an error while executing the ping program. check the path or permissions...: Error: spawn /bin/ping ENOENT
      ping.0
      	2021-10-02 11:02:49.391	error	Error: ping.probe: there was an error while executing the ping program. check the path or permissions...: Error: spawn /bin/ping ENOENT
      ping.0
      	2021-10-02 11:02:49.385	error	Error: ping.probe: there was an error while executing the ping program. check the path or permissions...: Error: spawn /bin/ping ENOENT
      ping.0
      	2021-10-02 11:02:49.379	error	Error: ping.probe: there was an error while executing the ping program. check the path or permissions...: Error: spawn /bin/ping ENOENT
      Glasfaser AlCalzone 3 Replies Last reply Reply Quote 0
      • Glasfaser
        Glasfaser @PeterImNetz last edited by
        @peterimnetz sagte in Error: spawn /bin/ping ENOENT nach Update JS controller:
        ENOENT
        Zeige mal die Ausgabe von :
        iobroker status
        which nodejs node npm && nodejs -v && node -v && npm -v && sudo apt update && sudo apt update && apt policy nodejs
        dann versuche mal :
        pkill -u iobroker
        iobroker fix
        und anschließend den Container neu starten.
          PeterImNetz @Glasfaser last edited by
          @glasfaser
          Habe ich alles gemacht:
          root@9f56db605ef8:/opt/iobroker# iobroker status
          Objects type: file
          States  type: file
          root@9f56db605ef8:/opt/iobroker# which nodejs node npm && nodejs -v && node -v && npm -v && sudo apt update && sudo apt update && apt policy nodejs
          /usr/bin/node
          /usr/bin/npm
          root@9f56db605ef8:/opt/iobroker# iobroker fix
          library: loaded
          Library version=2021-08-05
              Welcome to the ioBroker installation fixer!
              Script version: 2021-04-07
              Installing prerequisites (1/3)
          Get:1 http://deb.debian.org/debian bullseye InRelease [113 kB]
          Get:2 http://security.debian.org/debian-security bullseye-security InRelease [44,1 kB]
          Get:3 https://deb.nodesource.com/node_12.x bullseye InRelease [4.586 B]
          Get:4 http://deb.debian.org/debian bullseye-updates InRelease [39,4 kB]
          Get:5 http://security.debian.org/debian-security bullseye-security/main amd64 Packages [41,5 kB]
          Get:6 http://deb.debian.org/debian bullseye/main amd64 Packages [8.178 kB]
          Get:7 https://deb.nodesource.com/node_12.x bullseye/main amd64 Packages [768 B]
          Get:8 http://deb.debian.org/debian bullseye-updates/main amd64 Packages [2.300 B]
          Fetched 8.423 kB in 2s (3.405 kB/s)
          Reading package lists... Done
          Installed gcc-c++
          Installed python-dev
              Checking ioBroker user and directory permissions (2/3)
          Created /etc/sudoers.d/iobroker
              Checking autostart (3/3)
          Unsupported init system, cannot enable autostart!
              Your installation was fixed successfully
              Run iobroker start to start ioBroker again!
          Das ändert leider nichts, nach dem Neustart des Containers kommt immer noch die Fehlermeldung
          ping.0
          	2021-10-02 13:05:36.820	error	Error: ping.probe: there was an error while executing the ping program. check the path or permissions...: Error: spawn /bin/ping ENOENT
          ping.0
          	2021-10-02 13:05:36.816	error	Error: ping.probe: there was an error while executing the ping program. check the path or permissions...: Error: spawn /bin/ping ENOENT
          ping.0
          	2021-10-02 13:05:36.811	error	Error: ping.probe: there was an error while executing the ping program. check the path or permissions...: Error: spawn /bin/ping ENOENT
          ping.0
          	2021-10-02 13:05:36.807	error	Error: ping.probe: there was an error while executing the ping program. check the path or permissions...: Error: spawn /bin/ping ENOENT
          ping.0
          	2021-10-02 13:05:36.803	error	Error: ping.probe: there was an error while executing the ping program. check the path or permissions...: Error: spawn /bin/ping ENOENT
          ping.0
          	2021-10-02 13:05:36.798	error	Error: ping.probe: there was an error while executing the ping program. check the path or permissions...: Error: spawn /bin/ping ENOENT
          ping.0
          	2021-10-02 13:05:36.793	error	Error: ping.probe: there was an error while executing the ping program. check the path or permissions...: Error: spawn /bin/ping ENOENT
          Glasfaser Thomas Braun 2 Replies Last reply Reply Quote 0
          • Glasfaser
            /usr/bin/node
            /usr/bin/npm
            Da fehlt einiges ... da sollte mehr kommen
            nochmal :
            • AlCalzone
              AlCalzone Developer @PeterImNetz last edited by
              ENOENT
              bedeutet, dass das Programm nicht existiert. Ist der Pfad /bin/ping denn im Container vorhanden?
                Thomas Braun Most Active @PeterImNetz last edited by Thomas Braun
                @peterimnetz
                ping darf u. U. nur mit root-Rechten ausgeführt werden. Da muss wohl dem iobroker noch was eingeräumt werden. Aber von Docker hab ich keinen Plan.
                • Glasfaser
                  Glasfaser @Thomas Braun last edited by Glasfaser
                  @thomas-braun sagte in Error: spawn /bin/ping ENOENT nach Update JS controller:
                  Kann man das gleiche machen :
                  https://forum.iobroker.net/topic/45347/ping-adapter-liefert-unter-ubuntu-nur-false/8
                  @PeterImNetz
                  Bitte erstmal die Ausgabe von oben angefordert Posten
                  dann
                  Zeige mal :
                  ls -la /bin/ping
                    @glasfaser said in Error: spawn /bin/ping ENOENT nach Update JS controller:
                    ls -la /bin/ping
                    So einfach ist das - es gibt kein ping in dem Container 🤦‍♂️
                    root@9f56db605ef8:/opt/iobroker# ls -la /bin/ping
                    ls: cannot access '/bin/ping': No such file or directory
                    OK, Danke - das erklärt es natürlich...
                    • Glasfaser
                      Glasfaser @Glasfaser last edited by Glasfaser
                      @PeterImNetz
                      @glasfaser sagte in Error: spawn /bin/ping ENOENT nach Update JS controller:
                      nochmal :
                      Nochmal :
                      Was ist hiermit .... da fehlte die hälfte der Ausgabe !?
                      EDIT:
                      nimm mal bei dir :
                      which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
                        PeterImNetz @Glasfaser last edited by PeterImNetz
                        Ja, das ist ziemlich wenig
                        Ich habe keine Idee wieso das executeable weg war, aber so einfach war dann auch die Lösung...
                        • Glasfaser
                          Glasfaser @PeterImNetz last edited by Glasfaser
                          Kann du uns noch verraten welche Docker Version du von buanet hast ,
                          denn der ( Fehler ) ist heute hier auch aufgetreten .
                          https://forum.iobroker.net/topic/48224/error-ping-probe-ping-und-sony-bravia-adapter
                          An JS controller auf 3.3.18 aktualisiert , kann ich mir erstmal nicht vorstellen , da ich auch ein buanet Docker habe .
                            Works as desired - https://github.com/buanet/ioBroker.docker/issues/200#issuecomment-932781681
                            Mit der Umstellung auf Debian Bullseye slim v5.2.0 gibt es kein ping mehr im Docker
                            Das Paket iputils-ping muss nun manuell mit beim Bauen des Containers berücksichtigt werden:
                            peterimnetz created this issue in buanet/ioBroker.docker
                            closed Executeable of ping is missing in image #200
                            1394
