    4. [gelöst] Fehler bei Installationen
    • Plasmachef
      Plasmachef last edited by Plasmachef
      Hallo Zusammen,
      seit kurzen bekommen ich bei der Installation eines Adapters folgende Mitteilungen
      $ iobroker add whatsapp-cmb auto --host raspberrypi
      NPM version: 6.14.11
      npm install iobroker.whatsapp-cmb@0.1.6 --loglevel error --prefix "/opt/iobroker" (System call)
      npm ERR! code EACCES
      npm ERR! syscall unlinknpm ERR! path /opt/iobroker/node_modules/.canvas.DELETE/build/Makefilenpm ERR! errno -13
      npm ERR! Error: EACCES: permission denied, unlink '/opt/iobroker/node_modules/.canvas.DELETE/build/Makefile'
      npm ERR! [OperationalError: EACCES: permission denied, unlink '/opt/iobroker/node_modules/.canvas.DELETE/build/Makefile'] {npm ERR! cause: [Error: EACCES: permission denied, unlink '/opt/iobroker/node_modules/.canvas.DELETE/build/Makefile'] {npm ERR! errno: -13,npm ERR! code: 'EACCES',npm ERR! syscall: 'unlink',npm ERR! path: '/opt/iobroker/node_modules/.canvas.DELETE/build/Makefile'npm ERR! },npm ERR! errno: -13,npm ERR! code: 'EACCES',npm ERR! syscall: 'unlink',npm ERR! path: '/opt/iobroker/node_modules/.canvas.DELETE/build/Makefile',npm ERR! parent: 'iobroker'npm ERR! }npm ERR! npm ERR! The operation was rejected by your operating system.
      npm ERR! It is likely you do not have the permissions to access this file as the current usernpm ERR! npm ERR! If you believe this might be a permissions issue, please double-check thenpm ERR! permissions of the file and its containing directories, or try runningnpm ERR! the command again as root/Administrator.
      npm ERR! /home/iobroker/.npm/_logs/2021-10-03T17_27_16_512Z-debug.log
      host.raspberrypi Cannot install iobroker.whatsapp-cmb@0.1.6: 243
      ERROR: Process exited with code 25
      auch dieser Befehl an der Console läuft auf das selbe Ergebnis
      sudo iobroker add whatsapp-cmb auto --host raspberrypi
      Kann mir bitte wer helfen?
      Danke 🙂
        Thomas Braun Most Active @Plasmachef last edited by Thomas Braun
        @plasmachef sagte in Fehler bei Installationen:
        sudo iobroker
        Das ist dein Fehler.
        An der Stelle wird NIE mit sudo (root-Rechten) hantiert...
        iobroker stop
        iobroker fix
        iobroker start
        mal probieren. Wenn nicht noch mehr krumm ist könnte das vielleicht schon reichen.
        Ansonsten das tun was im Log steht. Den Ordner löschen.
        • Glasfaser
          Glasfaser @Thomas Braun last edited by
          Das Verzeichniss gibt es gar nicht bei ioBroker mit einem Punkt vorraus
          .canvans
            Thomas Braun Most Active @Glasfaser last edited by
            @glasfaser @Plasmachef
            Mal irgendwann unter Windows da rumgegurkt?
            Schaut für mich aus wie ein versteckter Ordner.
            Plasmachef 1 Reply Last reply Reply Quote 0
            • Plasmachef
              Plasmachef @Thomas Braun last edited by
              Danke für die Tipps!
              Sie haben mich auf die richte Spur geführt.
              Es lag an einer defekten Installation von Canvas.
              Uninstall und Install haben das Problem gelöst 🙂
              installation schlägt fehl
