    4. MQTT Broker/Client 2.4.0 kommunikation mit openHASP
    • Günter Königsberger
      Günter Königsberger last edited by Günter Königsberger
      If the payload is a json object containing a val property, iobroker uses the val property only as value of that object...
      This seems to be an issue of the iobroker.mqtt server: This piece of code handles the incoming messages. They parse the payload using a Fast solution, resulting in false positives. It is even mentioned in that code what the right solution is...
      Changing iobroker.mqtt\lib\server.js line 541 to ignore events fixes the issue:
                  // Fast solution
                  if (_message.val !== undefined && _message.event === undefined) {
      Systemdata Bitte Ausfüllen
      Hardwaresystem: Raspberry 4
      Arbeitsspeicher: 4GB
      Festplattenart: SD-Karte
      Betriebssystem: linux
      Node-Version: 10.x.x
      Nodejs-Version: 12.20.1
      NPM-Version: 6.14.10
      Installationsart: Skript
      Image genutzt: Ja
      Ort/Name der Imagedatei: Link
