    4. Gelöst: Raspi stirbt nach Backup ab
      Steinmetz_4 last edited by Steinmetz_4
      ich habe das Problem, dass der Raspi 4 ( 8GB, SSD als Datenträger) nach dem Backup hängen bleibt. Ich muss ihn dann morgens stromlos machen und dann läuft er wieder bis zum nächsten Backup.
      2021-10-13 02:30:37.975 - info: host.raspberrypi instance system.adapter.ical.4 terminated with code 0 (NO_ERROR)
      2021-10-13 02:30:41.789 - info: daswetter.0 (25820) Terminated (NO_ERROR): Without reason
      2021-10-13 02:30:42.308 - info: daswetter.0 (25820) cleaned everything up...
      2021-10-13 02:30:42.329 - info: host.raspberrypi instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
      2021-10-13 02:35:00.132 - info: host.raspberrypi instance system.adapter.dwd.0 started with pid 26139
      2021-10-13 02:35:02.437 - info: dwd.0 (26139) starting. Version 2.7.7 in /opt/iobroker/node_modules/iobroker.dwd, node: v12.22.6, js-controller: 3.3.18
      2021-10-13 02:35:04.163 - info: host.raspberrypi instance system.adapter.netatmo-crawler.0 started with pid 26154
      2021-10-13 02:35:06.958 - info: netatmo-crawler.0 (26154) starting. Version 0.5.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v12.22.6, js-controller: 3.3.18
      2021-10-13 02:35:07.037 - info: netatmo-crawler.0 (26154) Getting data for stationid:70:ee:50:53:56:8c
      2021-10-13 02:35:07.187 - info: dwd.0 (26139) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2021-10-13 02:35:07.727 - info: host.raspberrypi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2021-10-13 02:35:09.214 - info: netatmo-crawler.0 (26154) Getting data for stationid:70:ee:50:06:8d:74
      2021-10-13 02:35:09.373 - info: netatmo-crawler.0 (26154) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
      2021-10-13 02:35:09.912 - info: host.raspberrypi instance system.adapter.netatmo-crawler.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2021-10-13 02:35:53.765 - info: knx.0 (1505) State value to set for "knx.0.Datum_Uhrzeit.Datum_und_Uhrzeit.Datum_und_Uhrzeit_Ip-Interface" has to be one of type "string", "number", "boolean" but received type "object"
      2021-10-13 02:40:00.115 - info: host.raspberrypi instance system.adapter.netatmo-crawler.0 started with pid 26398
      2021-10-13 02:40:02.416 - info: netatmo-crawler.0 (26398) starting. Version 0.5.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v12.22.6, js-controller: 3.3.18
      2021-10-13 02:40:02.484 - info: netatmo-crawler.0 (26398) Getting data for stationid:70:ee:50:53:56:8c
      2021-10-13 02:40:02.744 - info: netatmo-crawler.0 (26398) Getting data for stationid:70:ee:50:06:8d:74
      2021-10-13 02:40:02.908 - info: netatmo-crawler.0 (26398) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
      2021-10-13 02:40:03.449 - info: host.raspberrypi instance system.adapter.netatmo-crawler.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2021-10-13 02:40:04.166 - info: host.raspberrypi instance system.adapter.dwd.0 started with pid 26413
      2021-10-13 02:40:06.352 - info: dwd.0 (26413) starting. Version 2.7.7 in /opt/iobroker/node_modules/iobroker.dwd, node: v12.22.6, js-controller: 3.3.18
      2021-10-13 02:40:07.757 - info: dwd.0 (26413) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2021-10-13 02:40:08.313 - info: host.raspberrypi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2021-10-13 02:45:00.205 - info: host.raspberrypi instance system.adapter.dwd.0 started with pid 26670
      2021-10-13 02:45:02.880 - info: dwd.0 (26670) starting. Version 2.7.7 in /opt/iobroker/node_modules/iobroker.dwd, node: v12.22.6, js-controller: 3.3.18
      2021-10-13 02:45:04.241 - info: host.raspberrypi instance system.adapter.netatmo-crawler.0 started with pid 26685
      2021-10-13 02:45:07.437 - info: netatmo-crawler.0 (26685) starting. Version 0.5.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v12.22.6, js-controller: 3.3.18
      2021-10-13 02:45:07.533 - info: netatmo-crawler.0 (26685) Getting data for stationid:70:ee:50:53:56:8c
      2021-10-13 02:45:07.688 - info: dwd.0 (26670) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2021-10-13 02:45:07.860 - info: netatmo-crawler.0 (26685) Getting data for stationid:70:ee:50:06:8d:74
      2021-10-13 02:45:08.037 - info: netatmo-crawler.0 (26685) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
      2021-10-13 02:45:08.223 - info: host.raspberrypi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2021-10-13 02:45:08.272 - info: host.raspberrypi instance system.adapter.daswetter.0 started with pid 26700
      2021-10-13 02:45:08.576 - info: host.raspberrypi instance system.adapter.netatmo-crawler.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2021-10-13 02:45:10.785 - info: daswetter.0 (26700) starting. Version 3.0.7 in /opt/iobroker/node_modules/iobroker.daswetter, node: v12.22.6, js-controller: 3.3.18
      2021-10-13 02:45:12.303 - info: host.raspberrypi instance system.adapter.coronavirus-statistics.0 started with pid 26715
      2021-10-13 02:45:15.331 - info: coronavirus-statistics.0 (26715) starting. Version 0.8.3 in /opt/iobroker/node_modules/iobroker.coronavirus-statistics, node: v12.22.6, js-controller: 3.3.18
      2021-10-13 02:45:27.603 - info: coronavirus-statistics.0 (26715) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
      2021-10-13 02:45:28.149 - info: host.raspberrypi instance system.adapter.coronavirus-statistics.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2021-10-13 02:45:34.482 - info: daswetter.0 (26700) still wrong data structure from server received! repaired...
      2021-10-13 02:45:40.431 - info: daswetter.0 (26700) Terminated (NO_ERROR): Without reason
      2021-10-13 02:45:40.946 - info: daswetter.0 (26700) cleaned everything up...
      2021-10-13 02:45:40.960 - info: host.raspberrypi instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
      2021-10-13 02:45:53.759 - info: knx.0 (1505) State value to set for "knx.0.Datum_Uhrzeit.Datum_und_Uhrzeit.Datum_und_Uhrzeit_Ip-Interface" has to be one of type "string", "number", "boolean" but received type "object"
      2021-10-13 02:50:00.165 - info: host.raspberrypi instance system.adapter.netatmo-crawler.0 started with pid 26961
      2021-10-13 02:50:02.864 - info: netatmo-crawler.0 (26961) starting. Version 0.5.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v12.22.6, js-controller: 3.3.18
      2021-10-13 02:50:02.964 - info: netatmo-crawler.0 (26961) Getting data for stationid:70:ee:50:53:56:8c
      2021-10-13 02:50:03.286 - info: netatmo-crawler.0 (26961) Getting data for stationid:70:ee:50:06:8d:74
      2021-10-13 02:50:03.462 - info: netatmo-crawler.0 (26961) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
      2021-10-13 02:50:04.018 - info: host.raspberrypi instance system.adapter.netatmo-crawler.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2021-10-13 02:50:04.200 - info: host.raspberrypi instance system.adapter.dwd.0 started with pid 26976
      2021-10-13 02:50:06.827 - info: dwd.0 (26976) starting. Version 2.7.7 in /opt/iobroker/node_modules/iobroker.dwd, node: v12.22.6, js-controller: 3.3.18
      2021-10-13 02:50:08.131 - info: dwd.0 (26976) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2021-10-13 02:50:08.659 - info: host.raspberrypi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2021-10-13 02:55:00.128 - info: host.raspberrypi instance system.adapter.dwd.0 started with pid 27217
      2021-10-13 02:55:02.903 - info: dwd.0 (27217) starting. Version 2.7.7 in /opt/iobroker/node_modules/iobroker.dwd, node: v12.22.6, js-controller: 3.3.18
      2021-10-13 02:55:04.163 - info: host.raspberrypi instance system.adapter.netatmo-crawler.0 started with pid 27232
      2021-10-13 02:55:07.283 - info: netatmo-crawler.0 (27232) starting. Version 0.5.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v12.22.6, js-controller: 3.3.18
      2021-10-13 02:55:07.376 - info: netatmo-crawler.0 (27232) Getting data for stationid:70:ee:50:53:56:8c
      2021-10-13 02:55:07.465 - info: dwd.0 (27217) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2021-10-13 02:55:08.025 - info: host.raspberrypi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2021-10-13 02:55:08.707 - info: netatmo-crawler.0 (27232) Getting data for stationid:70:ee:50:06:8d:74
      2021-10-13 02:55:08.875 - info: netatmo-crawler.0 (27232) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
      2021-10-13 02:55:09.423 - info: host.raspberrypi instance system.adapter.netatmo-crawler.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2021-10-13 02:55:53.757 - info: knx.0 (1505) State value to set for "knx.0.Datum_Uhrzeit.Datum_und_Uhrzeit.Datum_und_Uhrzeit_Ip-Interface" has to be one of type "string", "number", "boolean" but received type "object"
      2021-10-13 03:00:00.036 - info: javascript.0 (825) script.js.Astro_ausführlich: Astro: Gültige Zeiten: [aktueller Tag: 13] | [nächster Tag: 1] | [Aktualisiert: 0] | Aktuelle Tageszeit: Mitternacht | Kommende Tageszeit: Früher Morgen
      2021-10-13 03:00:00.278 - info: host.raspberrypi instance system.adapter.netatmo-crawler.0 started with pid 27477
      2021-10-13 03:00:03.067 - info: netatmo-crawler.0 (27477) starting. Version 0.5.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v12.22.6, js-controller: 3.3.18
      2021-10-13 03:00:03.137 - info: netatmo-crawler.0 (27477) Getting data for stationid:70:ee:50:53:56:8c
      2021-10-13 03:00:04.251 - info: netatmo-crawler.0 (27477) Getting data for stationid:70:ee:50:06:8d:74
      2021-10-13 03:00:04.325 - info: host.raspberrypi instance system.adapter.dwd.0 started with pid 27492
      2021-10-13 03:00:05.115 - info: netatmo-crawler.0 (27477) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
      2021-10-13 03:00:05.676 - info: host.raspberrypi instance system.adapter.netatmo-crawler.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2021-10-13 03:00:06.912 - info: dwd.0 (27492) starting. Version 2.7.7 in /opt/iobroker/node_modules/iobroker.dwd, node: v12.22.6, js-controller: 3.3.18
      2021-10-13 03:00:08.364 - info: host.raspberrypi instance system.adapter.coronavirus-statistics.0 started with pid 27507
      2021-10-13 03:00:08.793 - info: dwd.0 (27492) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2021-10-13 03:00:09.343 - info: host.raspberrypi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2021-10-13 03:00:10.914 - info: coronavirus-statistics.0 (27507) starting. Version 0.8.3 in /opt/iobroker/node_modules/iobroker.coronavirus-statistics, node: v12.22.6, js-controller: 3.3.18
      2021-10-13 03:00:12.408 - info: host.raspberrypi instance system.adapter.daswetter.0 started with pid 27523
      2021-10-13 03:00:15.514 - info: daswetter.0 (27523) starting. Version 3.0.7 in /opt/iobroker/node_modules/iobroker.daswetter, node: v12.22.6, js-controller: 3.3.18
      2021-10-13 03:00:16.458 - info: host.raspberrypi instance system.adapter.ical.4 started with pid 27538
      2021-10-13 03:00:20.273 - info: ical.4 (27538) starting. Version 1.11.4 in /opt/iobroker/node_modules/iobroker.ical, node: v12.22.6, js-controller: 3.3.18
      2021-10-13 03:00:20.495 - info: host.raspberrypi instance system.adapter.ical.3 started with pid 27553
      2021-10-13 03:00:21.088 - info: ical.4 (27538) processing URL: calendar1 https://calendar.google.com/calendar/ical/bodb8db8cl9aj6ks81gq0rvsv0%40group.calendar.google.com/private-a297fa24a9c2ccd3c422eab38644d026/basic.ics
      2021-10-13 03:00:21.280 - info: coronavirus-statistics.0 (27507) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
      2021-10-13 03:00:21.828 - info: host.raspberrypi instance system.adapter.coronavirus-statistics.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2021-10-13 03:00:24.148 - info: ical.3 (27553) starting. Version 1.11.4 in /opt/iobroker/node_modules/iobroker.ical, node: v12.22.6, js-controller: 3.3.18
      2021-10-13 03:00:24.530 - info: host.raspberrypi instance system.adapter.ical.1 started with pid 27568
      2021-10-13 03:00:24.633 - info: ical.3 (27553) processing URL: Tom https://calendar.google.com/calendar/ical/k6qjv6gq9102nheldtj973mdu0%40group.calendar.google.com/private-c35a23b62937bd516a7637b1c02e7941/basic.ics
      2021-10-13 03:00:26.610 - info: ical.4 (27538) Terminated (NO_ERROR): Without reason
      2021-10-13 03:00:27.216 - info: host.raspberrypi instance system.adapter.ical.4 terminated with code 0 (NO_ERROR)
      2021-10-13 03:00:28.449 - info: ical.1 (27568) starting. Version 1.11.4 in /opt/iobroker/node_modules/iobroker.ical, node: v12.22.6, js-controller: 3.3.18
      2021-10-13 03:00:28.586 - info: host.raspberrypi instance system.adapter.ical.0 started with pid 27628
      2021-10-13 03:00:29.038 - info: ical.1 (27568) processing URL: Schichtplan https://calendar.google.com/calendar/ical/opljlsoo63f4urc934b94kfpr4%40group.calendar.google.com/private-d8521c5f76a79bff0e8c5bfd4a94f90c/basic.ics
      2021-10-13 03:00:29.754 - info: ical.3 (27553) Terminated (NO_ERROR): Without reason
      2021-10-13 03:00:30.297 - info: host.raspberrypi instance system.adapter.ical.3 terminated with code 0 (NO_ERROR)
      2021-10-13 03:00:32.207 - info: ical.0 (27628) starting. Version 1.11.4 in /opt/iobroker/node_modules/iobroker.ical, node: v12.22.6, js-controller: 3.3.18
      2021-10-13 03:00:32.949 - info: ical.0 (27628) processing URL: Geburtstage und Termine https://calendar.google.com/calendar/ical/stadlmayrs.strass%40gmail.com/private-505b1877c7abcf82f8d2949452f471f1/basic.ics
      2021-10-13 03:00:34.271 - info: ical.1 (27568) Terminated (NO_ERROR): Without reason
      2021-10-13 03:00:34.804 - info: host.raspberrypi instance system.adapter.ical.1 terminated with code 0 (NO_ERROR)
      2021-10-13 03:00:38.539 - info: ical.0 (27628) Terminated (NO_ERROR): Without reason
      2021-10-13 03:00:39.080 - info: host.raspberrypi instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
      2021-10-13 03:00:42.469 - info: daswetter.0 (27523) still wrong data structure from server received! repaired...
      2021-10-13 03:00:47.938 - info: daswetter.0 (27523) Terminated (NO_ERROR): Without reason
      2021-10-13 03:00:48.454 - info: daswetter.0 (27523) cleaned everything up...
      2021-10-13 03:00:48.470 - info: host.raspberrypi instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
      2021-10-13 03:05:00.115 - info: host.raspberrypi instance system.adapter.dwd.0 started with pid 27827
      2021-10-13 03:05:02.591 - info: dwd.0 (27827) starting. Version 2.7.7 in /opt/iobroker/node_modules/iobroker.dwd, node: v12.22.6, js-controller: 3.3.18
      2021-10-13 03:05:04.154 - info: host.raspberrypi instance system.adapter.netatmo-crawler.0 started with pid 27842
      2021-10-13 03:05:07.118 - info: netatmo-crawler.0 (27842) starting. Version 0.5.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v12.22.6, js-controller: 3.3.18
      2021-10-13 03:05:07.224 - info: netatmo-crawler.0 (27842) Getting data for stationid:70:ee:50:53:56:8c
      2021-10-13 03:05:07.371 - info: dwd.0 (27827) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2021-10-13 03:05:07.527 - info: netatmo-crawler.0 (27842) Getting data for stationid:70:ee:50:06:8d:74
      2021-10-13 03:05:07.707 - info: netatmo-crawler.0 (27842) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
      2021-10-13 03:05:07.919 - info: host.raspberrypi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2021-10-13 03:05:08.249 - info: host.raspberrypi instance system.adapter.netatmo-crawler.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2021-10-13 03:05:53.753 - info: knx.0 (1505) State value to set for "knx.0.Datum_Uhrzeit.Datum_und_Uhrzeit.Datum_und_Uhrzeit_Ip-Interface" has to be one of type "string", "number", "boolean" but received type "object"
      2021-10-13 03:09:19.881 - warn: sonnen.0 (1363) [REQUEST] <== Error: connect ECONNREFUSED 192.168.178.84:80
      2021-10-13 03:09:19.899 - warn: sonnen.0 (1363) [CONNECT] Connection failed
      2021-10-13 03:09:45.396 - warn: sonnen.0 (1363) [REQUEST] <== Error: connect EHOSTUNREACH 192.168.178.84:80
      2021-10-13 03:09:45.396 - warn: sonnen.0 (1363) [CONNECT] Connection failed
      2021-10-13 03:09:52.400 - warn: sonnen.0 (1363) [REQUEST] <== Error: connect ECONNREFUSED 192.168.178.84:80
      2021-10-13 03:09:52.400 - warn: sonnen.0 (1363) [CONNECT] Connection failed
      2021-10-13 03:10:00.136 - info: host.raspberrypi instance system.adapter.netatmo-crawler.0 started with pid 28084
      2021-10-13 03:10:03.048 - info: netatmo-crawler.0 (28084) starting. Version 0.5.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v12.22.6, js-controller: 3.3.18
      2021-10-13 03:10:03.125 - info: netatmo-crawler.0 (28084) Getting data for stationid:70:ee:50:53:56:8c
      2021-10-13 03:10:03.406 - info: netatmo-crawler.0 (28084) Getting data for stationid:70:ee:50:06:8d:74
      2021-10-13 03:10:03.582 - info: netatmo-crawler.0 (28084) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
      2021-10-13 03:10:04.126 - info: host.raspberrypi instance system.adapter.netatmo-crawler.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2021-10-13 03:10:04.181 - info: host.raspberrypi instance system.adapter.dwd.0 started with pid 28099
      2021-10-13 03:10:06.489 - warn: sonnen.0 (1363) [REQUEST] <== 502 - "\n\n\n\n\n\n\n\n\n\n\n
      \n
      \n
      \n
      Something went wrong
      \n
      sonnen Services not running, yet?
      \n
      Try again
      \n
      \n
      \n\n\n"
      2021-10-13 03:10:06.489 - warn: sonnen.0 (1363) [CONNECT] Connection failed
      2021-10-13 03:10:06.522 - info: dwd.0 (28099) starting. Version 2.7.7 in /opt/iobroker/node_modules/iobroker.dwd, node: v12.22.6, js-controller: 3.3.18
      2021-10-13 03:10:07.803 - info: dwd.0 (28099) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2021-10-13 03:10:08.336 - info: host.raspberrypi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2021-10-13 03:10:13.494 - warn: sonnen.0 (1363) [REQUEST] <== 502 - "\n\n\n\n\n\n\n\n\n\n\n
      \n
      \n
      \n
      \n
      \n
      Try again
      \n
      \n
      \n\n\n"
      2021-10-13 03:10:13.494 - warn: sonnen.0 (1363) [CONNECT] Connection failed
      2021-10-13 03:10:20.498 - warn: sonnen.0 (1363) [REQUEST] <== 502 - "\n\n\n\n\n\n\n\n\n\n\n
      \n
      \n
      \n
      \n
      \n
      Try again
      \n
      \n
      \n\n\n"
      2021-10-13 03:10:20.499 - warn: sonnen.0 (1363) [CONNECT] Connection failed
      2021-10-13 03:12:00.092 - info: host.raspberrypi instance system.adapter.weatherunderground.0 started with pid 28208
      2021-10-13 03:12:02.880 - info: weatherunderground.0 (28208) starting. Version 3.3.1 in /opt/iobroker/node_modules/iobroker.weatherunderground, node: v12.22.6, js-controller: 3.3.18
      2021-10-13 03:12:11.165 - info: weatherunderground.0 (28208) Terminated (NO_ERROR): Without reason
      2021-10-13 03:12:11.700 - info: host.raspberrypi instance system.adapter.weatherunderground.0 terminated with code 0 (NO_ERROR)
      2021-10-13 03:15:00.142 - info: host.raspberrypi instance system.adapter.dwd.0 started with pid 28362
      2021-10-13 03:15:02.678 - info: dwd.0 (28362) starting. Version 2.7.7 in /opt/iobroker/node_modules/iobroker.dwd, node: v12.22.6, js-controller: 3.3.18
      2021-10-13 03:15:04.186 - info: host.raspberrypi instance system.adapter.netatmo-crawler.0 started with pid 28377
      2021-10-13 03:15:07.309 - info: netatmo-crawler.0 (28377) starting. Version 0.5.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v12.22.6, js-controller: 3.3.18
      2021-10-13 03:15:07.442 - info: netatmo-crawler.0 (28377) Getting data for stationid:70:ee:50:53:56:8c
      2021-10-13 03:15:07.538 - info: dwd.0 (28362) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2021-10-13 03:15:07.752 - info: netatmo-crawler.0 (28377) Getting data for stationid:70:ee:50:06:8d:74
      2021-10-13 03:15:07.932 - info: netatmo-crawler.0 (28377) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
      2021-10-13 03:15:08.073 - info: host.raspberrypi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2021-10-13 03:15:08.216 - info: host.raspberrypi instance system.adapter.daswetter.0 started with pid 28392
      2021-10-13 03:15:08.473 - info: host.raspberrypi instance system.adapter.netatmo-crawler.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2021-10-13 03:15:10.787 - info: daswetter.0 (28392) starting. Version 3.0.7 in /opt/iobroker/node_modules/iobroker.daswetter, node: v12.22.6, js-controller: 3.3.18
      2021-10-13 03:15:12.248 - info: host.raspberrypi instance system.adapter.coronavirus-statistics.0 started with pid 28407
      2021-10-13 03:15:15.219 - info: coronavirus-statistics.0 (28407) starting. Version 0.8.3 in /opt/iobroker/node_modules/iobroker.coronavirus-statistics, node: v12.22.6, js-controller: 3.3.18
      2021-10-13 03:15:29.033 - info: coronavirus-statistics.0 (28407) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
      2021-10-13 03:15:29.571 - info: host.raspberrypi instance system.adapter.coronavirus-statistics.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2021-10-13 03:15:32.730 - info: daswetter.0 (28392) still wrong data structure from server received! repaired...
      2021-10-13 03:15:38.516 - info: daswetter.0 (28392) Terminated (NO_ERROR): Without reason
      2021-10-13 03:15:39.038 - info: daswetter.0 (28392) cleaned everything up...
      2021-10-13 03:15:39.060 - info: host.raspberrypi instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
      2021-10-13 03:15:53.751 - info: knx.0 (1505) State value to set for "knx.0.Datum_Uhrzeit.Datum_und_Uhrzeit.Datum_und_Uhrzeit_Ip-Interface" has to be one of type "string", "number", "boolean" but received type "object"
      2021-10-13 03:20:00.078 - info: host.raspberrypi instance system.adapter.netatmo-crawler.0 started with pid 28659
      2021-10-13 03:20:02.985 - info: netatmo-crawler.0 (28659) starting. Version 0.5.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v12.22.6, js-controller: 3.3.18
      2021-10-13 03:20:03.063 - info: netatmo-crawler.0 (28659) Getting data for stationid:70:ee:50:53:56:8c
      2021-10-13 03:20:03.380 - info: netatmo-crawler.0 (28659) Getting data for stationid:70:ee:50:06:8d:74
      2021-10-13 03:20:03.563 - info: netatmo-crawler.0 (28659) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
      2021-10-13 03:20:04.129 - info: host.raspberrypi instance system.adapter.dwd.0 started with pid 28674
      2021-10-13 03:20:04.135 - info: host.raspberrypi instance system.adapter.netatmo-crawler.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2021-10-13 03:20:06.718 - info: dwd.0 (28674) starting. Version 2.7.7 in /opt/iobroker/node_modules/iobroker.dwd, node: v12.22.6, js-controller: 3.3.18
      2021-10-13 03:20:08.255 - info: dwd.0 (28674) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2021-10-13 03:20:08.786 - info: host.raspberrypi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2021-10-13 03:20:51.839 - warn: telegram.0 (706) polling_error: EFATAL, EFATAL: Error: read ECONNRESET
      2021-10-13 03:21:16.837 - info: meross.0 (934) Device: 2007226276811490821748e1e9264b44 error: Error: read ECONNRESET
      2021-10-13 03:21:16.882 - info: meross.0 (934) Device: 2007226276811490821748e1e9264b44 closed: null
      2021-10-13 03:21:16.885 - info: meross.0 (934) Device: 2007220281502290821748e1e9264585 error: Error: read ECONNRESET
      2021-10-13 03:21:16.890 - info: meross.0 (934) Device: 2007220281502290821748e1e9264585 closed: null
      2021-10-13 03:21:17.214 - error: worx.0 (1475) MQTT ERROR: Error: read ECONNRESET
      2021-10-13 03:21:21.882 - info: meross.0 (934) Device: 2007226276811490821748e1e9264b44 reconnected
      2021-10-13 03:21:21.907 - info: meross.0 (934) Device: 2007220281502290821748e1e9264585 reconnected
      2021-10-13 03:21:22.090 - info: meross.0 (934) Device: 2007226276811490821748e1e9264b44 connected
      2021-10-13 03:21:22.097 - info: meross.0 (934) Device: 2007220281502290821748e1e9264585 connected
      2021-10-13 03:21:42.096 - warn: meross.0 (934) Can not get Abilities for Device 2007226276811490821748e1e9264b44: Error: Timeout / undefined
      2021-10-13 03:21:42.099 - warn: meross.0 (934) Can not get Abilities for Device 2007220281502290821748e1e9264585: Error: Timeout / undefined
      2021-10-13 03:23:00.099 - info: host.raspberrypi instance system.adapter.openweathermap.0 started with pid 28825
      2021-10-13 03:23:02.594 - info: openweathermap.0 (28825) starting. Version 0.1.0 in /opt/iobroker/node_modules/iobroker.openweathermap, node: v12.22.6, js-controller: 3.3.18
      2021-10-13 03:23:07.978 - info: openweathermap.0 (28825) Terminated (NO_ERROR): Without reason
      2021-10-13 03:23:08.511 - info: host.raspberrypi instance system.adapter.openweathermap.0 terminated with code 0 (NO_ERROR)
      2021-10-13 03:25:00.108 - info: host.raspberrypi instance system.adapter.dwd.0 started with pid 28931
      2021-10-13 03:25:02.642 - info: dwd.0 (28931) starting. Version 2.7.7 in /opt/iobroker/node_modules/iobroker.dwd, node: v12.22.6, js-controller: 3.3.18
      2021-10-13 03:25:04.164 - info: host.raspberrypi instance system.adapter.netatmo-crawler.0 started with pid 28946
      2021-10-13 03:25:07.154 - info: netatmo-crawler.0 (28946) starting. Version 0.5.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v12.22.6, js-controller: 3.3.18
      2021-10-13 03:25:07.250 - info: netatmo-crawler.0 (28946) Getting data for stationid:70:ee:50:53:56:8c
      2021-10-13 03:25:07.309 - info: dwd.0 (28931) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2021-10-13 03:25:07.773 - info: netatmo-crawler.0 (28946) Getting data for stationid:70:ee:50:06:8d:74
      2021-10-13 03:25:07.845 - info: host.raspberrypi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2021-10-13 03:25:09.480 - info: netatmo-crawler.0 (28946) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
      2021-10-13 03:25:10.011 - info: host.raspberrypi instance system.adapter.netatmo-crawler.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2021-10-13 03:25:53.748 - info: knx.0 (1505) State value to set for "knx.0.Datum_Uhrzeit.Datum_und_Uhrzeit.Datum_und_Uhrzeit_Ip-Interface" has to be one of type "string", "number", "boolean" but received type "object"
      2021-10-13 03:17:17.743 - info: host.raspberrypi iobroker.js-controller version 3.3.18 js-controller starting
      2021-10-13 03:17:17.748 - info: host.raspberrypi Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
      2021-10-13 03:17:17.749 - info: host.raspberrypi hostname: raspberrypi, node: v12.22.6
      2021-10-13 03:17:17.750 - info: host.raspberrypi ip addresses: 192.168.178.185 fe80::8570:e996:c644:2cf9
      2021-10-13 03:17:18.625 - info: host.raspberrypi connected to Objects and States
      2021-10-13 03:17:18.729 - info: host.raspberrypi added notifications configuration of host
      2021-10-13 03:17:19.830 - info: host.raspberrypi 65 instances found
      2021-10-13 03:17:19.935 - info: host.raspberrypi starting 43 instances
      2021-10-13 03:17:20.077 - info: host.raspberrypi instance system.adapter.admin.0 started with pid 647
      2021-10-13 03:17:21.877 - error: admin.0 (647) admin.0 already running
      2021-10-13 03:17:21.880 - warn: admin.0 (647) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
      2021-10-13 03:17:22.561 - error: host.raspberrypi instance system.adapter.admin.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      2021-10-13 03:17:22.562 - info: host.raspberrypi Restart adapter system.adapter.admin.0 because enabled
      2021-10-13 03:17:24.583 - info: host.raspberrypi instance system.adapter.javascript.0 started with pid 658
      2021-10-13 03:17:27.188 - error: javascript.0 (658) javascript.0 already running
      2021-10-13 03:17:27.191 - warn: javascript.0 (658) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
      2021-10-13 03:17:27.864 - error: host.raspberrypi instance system.adapter.javascript.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      2021-10-13 03:17:27.866 - info: host.raspberrypi Restart adapter system.adapter.javascript.0 because enabled
      2021-10-13 03:17:28.052 - info: host.raspberrypi instance system.adapter.node-red.0 started with pid 669
      2021-10-13 03:17:29.240 - error: node-red.0 (669) node-red.0 already running
      2021-10-13 03:17:29.242 - warn: node-red.0 (669) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
      2021-10-13 03:17:29.848 - error: host.raspberrypi instance system.adapter.node-red.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      2021-10-13 03:17:29.849 - info: host.raspberrypi Restart adapter system.adapter.node-red.0 because enabled
      2021-10-13 03:17:32.101 - info: host.raspberrypi instance system.adapter.telegram.0 started with pid 680
      2021-10-13 03:17:34.086 - error: telegram.0 (680) telegram.0 already running
      2021-10-13 03:17:34.088 - warn: telegram.0 (680) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
      2021-10-13 03:17:34.695 - error: host.raspberrypi instance system.adapter.telegram.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      2021-10-13 03:17:34.696 - info: host.raspberrypi Restart adapter system.adapter.telegram.0 because enabled
      Auf dem Pi sieht das ganze dann so aus:
      Was läuft hier falsch?
      Mfg
      Tom
        Thomas Braun Most Active @Steinmetz_4 last edited by
        @steinmetz_4
        Dateisystem defekt.
        SD-Karte (?) austauschen, Neuinstallation, Backup (von vor dem Defekt) einspielen.
          Steinmetz_4 @Thomas Braun last edited by
          Eine SD karte habe ich nicht, läuft über externe SSD.
          Du meinst, dass die hin ist?
            @steinmetz_4 Zumindest das Dateisystem hat 'nen Schuss. Defekte inodes. Kann z.B. durch 'Stromausfall' passieren. Also nie einfach den Saft abdrehen, immer sauber herunterfahren.
              Steinmetz_4 @Thomas Braun last edited by Steinmetz_4
              Stimmt, da war was. Nachts war mal der Strom weg...
              Eine Reparatur kommt nicht in frage?
              Also:
              jetzt meine ganzen Daten manuell kopieren und dann nach Neuinstallation wieder einfügen?
                @steinmetz_4
                Du hast kein Backup?
                Die Daten da jetzt runterzukratzen ist wenig sinnvoll, wer sagt denn das die nicht auch defekt sind?
                  Die Backups werden dann wohl auch im Eimer sein, weil das ja nicht so geklappt hat wie es soll...
                    @steinmetz_4
                    Hast du kein Backup von vorher auf einem externen Speichermedium?
                      Es ging alles schief, was schief gehen kann...
                      Es waren zwar Backups da, aber die waren unbrauchbar, weil schon fast zwei Wochen alt.
                      Irgendwann muss irgendwer (evtl. Ich) während des Schreibprozesses versehentlich im Wohnzimmer auf den MasterPowerOff-Schalter gedrückt haben.
                      Ich hab mir erst nichts dabei gedacht, lief ja noch alles.
                      Dann ein paar Tage keine Zeit gehabt was zu tun und siehe da, alles im Eimer.
                      Nun gut, is hald so. Mal kräftig geflucht, ein paar Frustbier und von vorn...
                      Hab mich jetzt zwei Tage hin gesetzt und mehr oder minder bei null angefangen und alles neu installiert. Nun läufts!
                      NAS mount und Automatische Sicherung waren das erste und laufen fehlerfrei. Meine Visu Daten habe ich aus manuellen Sicherungen weitestgehend wieder herstellen können, da ich als Windows Nutzer immer mal gerne sicherheitshalber den ein oder anderen Ordner Kopiere und auf mein NAS lege.
                      Jetzt aktuell gibt es noch zwei Probleme:
                      1. iobroker findet den Source Analytics Adapter nicht
                      2. mein FLOT-Adapter zeigt nach ein paar Stunden nur noch grün, der Link in der Visu läuft aber noch.
                      Mfg
                      Tom
                      • Glasfaser
                        Glasfaser @Steinmetz_4 last edited by
                        @steinmetz_4 sagte in Raspi stirbt nach Backup ab:
                        Das heißt , für uns Außenstehende was ?
                        ... steht was im Log , oder was meinst du !?
                          Steinmetz_4 @Glasfaser last edited by
                          @glasfaser
                          sorry, Du hast recht...
                          Das war natürlich ein Hilferuf, wenn auch nicht ganz offensichtlich.
                          Vielleicht hat jemand das selbe, oder ein ähnliches Problem schon mal gehabt und kann mir einen Schubs in die richtige Richtung geben. Ich hab in der Suche nichts gefunden und in der Log-Datei kann ich auch keinen Hinweis erkennen (weil ich auch gar nicht weis, wonach ich suchen soll).
                          • Glasfaser
                            Nochmal , wie erkennst du denn das
                            Fehlt der Adapter in der Liste
                            Fehlt die Instanz
                            Fehlt im Datenpunkt die Einstellung
                              Steinmetz_4 @Glasfaser last edited by Steinmetz_4
                              @glasfaser
                              Er taucht bei der Suche nicht auf.
                              • Glasfaser
                                Glasfaser @Steinmetz_4 last edited by Glasfaser
                                @steinmetz_4
                                Die Seite ist nicht richtig geladen , da fehlt z.b . die Ordner
                                  Homoran Global Moderator Administrators @Glasfaser last edited by
                                  @glasfaser sagte in Gelöst: Raspi stirbt nach Backup ab:
                                  das wird es nicht sein 😉
                                  github:	0.4.12-1
                                  latest:	0.4.12-1 for 49 days
                                  stable:	-.-.-
                                  • Glasfaser
                                    Glasfaser @Homoran last edited by
                                    @homoran sagte in Gelöst: Raspi stirbt nach Backup ab:
                                    Ja .. ist ja gut , sehe gerade ist default ... aber man weiß ja nicht ober er den Link geändert hat 🙂 ( brauchte eine Ausrede ... )
                                    Es wäre mal interessant ,
                                    ob auch so die Ordner fehlen , wenn er etwas in stable sucht !?
                                      puuuh!
                                      oder weil alles herausgefiltert ist und keinerlei Ordner existieren?
                                      habe gerade keine v5 zur Verfügung zum Testen
                                        Steinmetz_4 @Homoran last edited by
                                        Klingt, als hättet Ihr eine Idee?
                                        • Glasfaser
                                          @steinmetz_4
                                          Nimm mal Source Analytics aus der Suche .
                                          Fehlen da Ordner ?
                                          Zeige mal dann ein Screenshot davon mit der normalen Auflistung
                                            @glasfaser
                                            Ja, fehlen.
                                            Glasfaser S 2 Replies Last reply Reply Quote 0
                                            4338
