    4. Zigbee reboot Loop alle ca 20h
      Cybork1995 last edited by
      Moin Moin, ich hoffe ihr könnt mir helfen.
      Seit zwei Tagen habe ich Probleme mit meinem Zigbee (Version 1.5.6)
      Es wurden seitdem keine Updates gemacht.
      Komischerweise crasht das Netzwerk alle ca. 20h
      Die Meldung heist die ganze zeit reboot loop gefunden.
      Der Adapter lässt sich jedes mal von Hand starten ohne Probleme.
      Ich hoffe ihr könnt mir sagen was hier falsch läuft.
      Hier einmal ein Auszug aus dem Log. (Crash um 5 Uhr)
      2021-10-20 04:49:50.740  - warn: zigbee.0 (10422) State value to set for "zigbee.0.60a423fffeaeaf6d.link_quality" has value "255" greater than max "254"
      2021-10-20 04:49:51.540  - warn: zigbee.0 (10422) State value to set for "zigbee.0.60a423fffe61da9f.link_quality" has value "255" greater than max "254"
      2021-10-20 04:50:06.719  - warn: zigbee.0 (10422) State value to set for "zigbee.0.00158d0006e18262.link_quality" has value "255" greater than max "254"
      2021-10-20 04:50:20.341  - warn: zigbee.0 (10422) State value to set for "zigbee.0.00158d0006e12fe7.link_quality" has value "255" greater than max "254"
      2021-10-20 04:50:33.057  - warn: zigbee.0 (10422) State value to set for "zigbee.0.00158d0001e4dc27.link_quality" has value "255" greater than max "254"
      2021-10-20 04:50:38.332  - warn: zigbee.0 (10422) State value to set for "zigbee.0.00158d0006e12fe7.link_quality" has value "255" greater than max "254"
      2021-10-20 04:50:38.941  - warn: zigbee.0 (10422) State value to set for "zigbee.0.00158d0001e4d869.link_quality" has value "255" greater than max "254"
      2021-10-20 04:50:43.690  - warn: zigbee.0 (10422) State value to set for "zigbee.0.588e81fffed39533.link_quality" has value "255" greater than max "254"
      2021-10-20 04:50:49.338  - warn: zigbee.0 (10422) State value to set for "zigbee.0.60a423fffeae66aa.link_quality" has value "255" greater than max "254"
      2021-10-20 04:50:50.557  - warn: zigbee.0 (10422) State value to set for "zigbee.0.60a423fffead67b7.link_quality" has value "255" greater than max "254"
      2021-10-20 04:50:50.588  - warn: zigbee.0 (10422) State value to set for "zigbee.0.60a423fffead7b94.link_quality" has value "255" greater than max "254"
      2021-10-20 04:50:50.631  - warn: zigbee.0 (10422) State value to set for "zigbee.0.60a423fffeae69c6.link_quality" has value "255" greater than max "254"
      2021-10-20 04:50:50.632  - warn: zigbee.0 (10422) State value to set for "zigbee.0.60a423fffeae66aa.link_quality" has value "255" greater than max "254"
      2021-10-20 04:50:50.674  - warn: zigbee.0 (10422) State value to set for "zigbee.0.60a423fffe6206b7.link_quality" has value "255" greater than max "254"
      2021-10-20 04:50:50.717  - warn: zigbee.0 (10422) State value to set for "zigbee.0.588e81fffed39533.link_quality" has value "255" greater than max "254"
      2021-10-20 04:50:50.740  - warn: zigbee.0 (10422) State value to set for "zigbee.0.60a423fffe61da9f.link_quality" has value "255" greater than max "254"
      2021-10-20 04:50:50.749  - warn: zigbee.0 (10422) State value to set for "zigbee.0.60a423fffe620f8c.link_quality" has value "255" greater than max "254"
      2021-10-20 04:50:50.755  - warn: zigbee.0 (10422) State value to set for "zigbee.0.60a423fffeaeaf6d.link_quality" has value "255" greater than max "254"
      2021-10-20 04:50:55.728  - warn: zigbee.0 (10422) State value to set for "zigbee.0.00158d0006e18262.link_quality" has value "255" greater than max "254"
      2021-10-20 04:50:56.345  - warn: zigbee.0 (10422) State value to set for "zigbee.0.00158d0006e12fe7.link_quality" has value "255" greater than max "254"
      2021-10-20 04:51:10.513  - warn: zigbee.0 (10422) State value to set for "zigbee.0.60a423fffeae69c6.link_quality" has value "255" greater than max "254"
      2021-10-20 04:51:13.723  - warn: zigbee.0 (10422) State value to set for "zigbee.0.00158d0006e18262.link_quality" has value "255" greater than max "254"
      2021-10-20 04:51:31.732  - warn: zigbee.0 (10422) State value to set for "zigbee.0.00158d0006e18262.link_quality" has value "255" greater than max "254"
      2021-10-20 04:51:37.612  - warn: zigbee.0 (10422) State value to set for "zigbee.0.60a423fffe6206b7.link_quality" has value "255" greater than max "254"
      2021-10-20 04:51:45.552  - warn: zigbee.0 (10422) State value to set for "zigbee.0.00158d0006e12fe7.link_quality" has value "255" greater than max "254"
      2021-10-20 04:51:50.567  - warn: zigbee.0 (10422) State value to set for "zigbee.0.60a423fffead67b7.link_quality" has value "255" greater than max "254"
      2021-10-20 04:51:50.586  - error: zigbee.0 (10422) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      2021-10-20 04:51:50.587  - error: zigbee.0 (10422) unhandled promise rejection: undefined
      2021-10-20 04:51:50.587  - info: zigbee.0 (10422) cleaned everything up...
      2021-10-20 04:51:50.587  - info: zigbee.0 (10422) Zigbee: disabling joining new devices.
      2021-10-20 04:51:50.707  - warn: zigbee.0 (10422) State value to set for "zigbee.0.60a423fffead7b94.link_quality" has value "255" greater than max "254"
      2021-10-20 04:51:50.797  - info: zigbee.0 (10422) terminating
      2021-10-20 04:51:50.797  - warn: zigbee.0 (10422) Terminated (UNCAUGHT_EXCEPTION): Without reason
      2021-10-20 04:51:51.340  - error: host.iobroker instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
      2021-10-20 04:51:51.341  - info: host.iobroker Restart adapter system.adapter.zigbee.0 because enabled
      2021-10-20 04:52:21.355  - info: host.iobroker instance system.adapter.zigbee.0 started with pid 10516
      2021-10-20 04:52:22.136  - info: zigbee.0 (10516) starting. Version 1.5.6 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.22.7, js-controller: 3.3.18
      2021-10-20 04:52:22.169  - info: zigbee.0 (10516) Starting Zigbee  npm ...
      2021-10-20 04:52:22.268  - info: zigbee.0 (10516) Installed Version: iobroker.zigbee@1.5.6
      2021-10-20 04:52:22.321  - info: zigbee.0 (10516) Coordinator firmware version: {"type":"ConBee2/RaspBee2","meta":{"transportrev":0,"product":0,"majorrel":38,"minorrel":88,"maintrel":0,"revision":"0x26580700"}}
      2021-10-20 04:52:22.343  - info: zigbee.0 (10516) Unable to disable LED, unsupported function.
      2021-10-20 04:52:22.344  - info: zigbee.0 (10516)   --> transmitPower : normal
      2021-10-20 04:52:22.344  - info: zigbee.0 (10516) Unable to set transmit power, unsupported function.
      2021-10-20 04:52:22.349  - info: zigbee.0 (10516) Currently 48 devices are joined:
      2021-10-20 04:52:22.384  - info: zigbee.0 (10516) 0x00158d0006a25cff (addr 11939): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
      2021-10-20 04:52:22.385  - info: zigbee.0 (10516) 0x00158d0006a25f5e (addr 28949): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
      2021-10-20 04:52:22.386  - info: zigbee.0 (10516) 0x00158d0006a158d6 (addr 42775): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
      2021-10-20 04:52:22.386  - info: zigbee.0 (10516) 0x00158d0006a25fba (addr 61932): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
      2021-10-20 04:52:22.387  - info: zigbee.0 (10516) 0x00158d0002f64add (addr 40419): 404000/404005/404012 - Müller Licht Tint LED bulb GU10/E14/E27 350/470/806 lumen, dimmable, color, opal white (Router)
      2021-10-20 04:52:22.387  - info: zigbee.0 (10516) 0x00158d0006b6362c (addr 7735): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
      2021-10-20 04:52:22.387  - info: zigbee.0 (10516) 0x00158d000253bcf3 (addr 28306): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
      2021-10-20 04:52:22.388  - info: zigbee.0 (10516) 0x60a423fffead67b7 (addr 38002): TS0121_plug - TuYa 10A UK or 16A EU smart plug (Router)
      2021-10-20 04:52:22.388  - info: zigbee.0 (10516) 0x60a423fffead7b94 (addr 20417): TS0121_plug - TuYa 10A UK or 16A EU smart plug (Router)
      2021-10-20 04:52:22.389  - info: zigbee.0 (10516) 0x60a423fffeae69c6 (addr 6561): TS0121_plug - TuYa 10A UK or 16A EU smart plug (Router)
      2021-10-20 04:52:22.389  - info: zigbee.0 (10516) 0x60a423fffead7808 (addr 57884): TS0121_plug - TuYa 10A UK or 16A EU smart plug (Router)
      2021-10-20 04:52:22.389  - info: zigbee.0 (10516) 0x60a423fffeae66aa (addr 11721): TS0121_plug - TuYa 10A UK or 16A EU smart plug (Router)
      2021-10-20 04:52:22.390  - info: zigbee.0 (10516) 0x5c0272fffecca5b1 (addr 37838): TS0201 - TuYa Temperature & humidity sensor with display (EndDevice)
      2021-10-20 04:52:22.390  - info: zigbee.0 (10516) 0x847127fffe93ff10 (addr 50999): TS0601_thermostat - TuYa Radiator valve with thermostat (EndDevice)
      2021-10-20 04:52:22.390  - info: zigbee.0 (10516) 0x00158d0001e4dc27 (addr 54467): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
      2021-10-20 04:52:22.391  - info: zigbee.0 (10516) 0x60a423fffeec4734 (addr 4825): TS0601_cover - TuYa Curtain motor/roller blind motor/window pusher/tubular motor (Router)
      2021-10-20 04:52:22.391  - info: zigbee.0 (10516) 0x60a423fffe6c38a5 (addr 23860): TS0601_cover - TuYa Curtain motor/roller blind motor/window pusher/tubular motor (Router)
      2021-10-20 04:52:22.391  - info: zigbee.0 (10516) 0x60a423fffe6206b7 (addr 58684): TS0121_plug - TuYa 10A UK or 16A EU smart plug (Router)
      2021-10-20 04:52:22.392  - info: zigbee.0 (10516) 0x588e81fffed39533 (addr 40351): TS0121_plug - TuYa 10A UK or 16A EU smart plug (Router)
      2021-10-20 04:52:22.392  - info: zigbee.0 (10516) 0x60a423fffe61da9f (addr 55837): TS0121_plug - TuYa 10A UK or 16A EU smart plug (Router)
      2021-10-20 04:52:22.392  - info: zigbee.0 (10516) 0x60a423fffeaeaf6d (addr 20487): TS0121_plug - TuYa 10A UK or 16A EU smart plug (Router)
      2021-10-20 04:52:22.393  - info: zigbee.0 (10516) 0x00158d0001e4bbf8 (addr 16006): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
      2021-10-20 04:52:22.393  - info: zigbee.0 (10516) 0x847127fffe09b1b2 (addr 14721): TS0601_cover - TuYa Curtain motor/roller blind motor/window pusher/tubular motor (Router)
      2021-10-20 04:52:22.393  - info: zigbee.0 (10516) 0x5c0272fffedac780 (addr 33439): TS0601_thermostat - TuYa Radiator valve with thermostat (EndDevice)
      2021-10-20 04:52:22.394  - info: zigbee.0 (10516) 0x00158d0001e4dc2d (addr 50898): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
      2021-10-20 04:52:22.395  - info: zigbee.0 (10516) 0x00158d000253be72 (addr 24250): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
      2021-10-20 04:52:22.395  - info: zigbee.0 (10516) 0x804b50fffe1a4115 (addr 60950): TS0601_thermostat - TuYa Radiator valve with thermostat (EndDevice)
      2021-10-20 04:52:22.396  - info: zigbee.0 (10516) 0x5c0272fffecca0c2 (addr 23719): TS0201 - TuYa Temperature & humidity sensor with display (EndDevice)
      2021-10-20 04:52:22.396  - info: zigbee.0 (10516) 0x60a423fffe94be6a (addr 28120): ZTS-EU_3gang - Moes Wall touch light switch (3 gang) (EndDevice)
      2021-10-20 04:52:22.397  - info: zigbee.0 (10516) 0x04cf8cdf3c7d88b9 (addr 52133): WXCJKG13LM - Xiaomi Aqara Opple switch 3 bands (EndDevice)
      2021-10-20 04:52:22.397  - info: zigbee.0 (10516) 0x04cf8cdf3c7d8637 (addr 17967): WXCJKG13LM - Xiaomi Aqara Opple switch 3 bands (EndDevice)
      2021-10-20 04:52:22.398  - info: zigbee.0 (10516) 0x04cf8cdf3c7dd349 (addr 34793): WXCJKG13LM - Xiaomi Aqara Opple switch 3 bands (EndDevice)
      2021-10-20 04:52:22.399  - info: zigbee.0 (10516) 0x84fd27fffe05f053 (addr 41407): 404000/404005/404012 - Müller Licht Tint LED bulb GU10/E14/E27 350/470/806 lumen, dimmable, color, opal white (Router)
      2021-10-20 04:52:22.399  - info: zigbee.0 (10516) 0x84fd27fffe05e0ca (addr 45821): 404000/404005/404012 - Müller Licht Tint LED bulb GU10/E14/E27 350/470/806 lumen, dimmable, color, opal white (Router)
      2021-10-20 04:52:22.399  - info: zigbee.0 (10516) 0x84fd27fffe05e2b8 (addr 27982): 404000/404005/404012 - Müller Licht Tint LED bulb GU10/E14/E27 350/470/806 lumen, dimmable, color, opal white (Router)
      2021-10-20 04:52:22.400  - info: zigbee.0 (10516) 0x847127fffe0a8887 (addr 5595): TS0601_cover - TuYa Curtain motor/roller blind motor/window pusher/tubular motor (Router)
      2021-10-20 04:52:22.400  - info: zigbee.0 (10516) 0x5c0272fffedac4ce (addr 34728): TS0601_thermostat - TuYa Radiator valve with thermostat (EndDevice)
      2021-10-20 04:52:22.400  - info: zigbee.0 (10516) 0x00158d000253c16f (addr 59245): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
      2021-10-20 04:52:22.401  - info: zigbee.0 (10516) 0x00158d0002e3373e (addr 54462): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
      2021-10-20 04:52:22.401  - info: zigbee.0 (10516) 0x04cf8cdf3c7d8140 (addr 16100): WXCJKG13LM - Xiaomi Aqara Opple switch 3 bands (EndDevice)
      2021-10-20 04:52:22.401  - info: zigbee.0 (10516) 0x00158d0001e4d869 (addr 36634): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
      2021-10-20 04:52:22.401  - info: zigbee.0 (10516) 0x00158d0006b62576 (addr 28086): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
      2021-10-20 04:52:22.402  - info: zigbee.0 (10516) 0x00158d0006a28bce (addr 50798): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
      2021-10-20 04:52:22.402  - info: zigbee.0 (10516) 0x00158d0006b624db (addr 10039): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
      2021-10-20 04:52:22.402  - info: zigbee.0 (10516) 0x00158d0006e18262 (addr 32814): 81855 - AduroSmart ERIA smart plug (dimmer) (Router)
      2021-10-20 04:52:22.402  - info: zigbee.0 (10516) 0x00158d0006e18258 (addr 16992): 81855 - AduroSmart ERIA smart plug (dimmer) (Router)
      2021-10-20 04:52:22.403  - info: zigbee.0 (10516) 0x00158d0006e12fe7 (addr 14119): 81855 - AduroSmart ERIA smart plug (dimmer) (Router)
      2021-10-20 04:52:22.403  - info: zigbee.0 (10516) 0x60a423fffe620f8c (addr 16132): TS0121_plug - TuYa 10A UK or 16A EU smart plug (Router)
      2021-10-20 04:52:22.403  - info: zigbee.0 (10516) Zigbee started
      2021-10-20 04:52:22.569  - warn: zigbee.0 (10516) State value to set for "zigbee.0.00158d0006e12fe7.link_quality" has value "255" greater than max "254"
      2021-10-20 04:52:23.022  - warn: zigbee.0 (10516) State value to set for "zigbee.0.60a423fffead67b7.link_quality" has value "255" greater than max "254"
      2021-10-20 04:52:23.033  - warn: zigbee.0 (10516) State value to set for "zigbee.0.60a423fffead7b94.link_quality" has value "255" greater than max "254"
      2021-10-20 04:52:23.240  - warn: zigbee.0 (10516) State value to set for "zigbee.0.60a423fffeae69c6.link_quality" has value "255" greater than max "254"
      2021-10-20 04:52:23.644  - warn: zigbee.0 (10516) State value to set for "zigbee.0.60a423fffeae66aa.link_quality" has value "255" greater than max "254"
      2021-10-20 04:52:24.243  - warn: zigbee.0 (10516) State value to set for "zigbee.0.60a423fffe6206b7.link_quality" has value "255" greater than max "254"
      2021-10-20 04:52:24.435  - warn: zigbee.0 (10516) State value to set for "zigbee.0.588e81fffed39533.link_quality" has value "255" greater than max "254"
      2021-10-20 04:52:24.645  - warn: zigbee.0 (10516) State value to set for "zigbee.0.60a423fffe61da9f.link_quality" has value "255" greater than max "254"
      2021-10-20 04:52:24.906  - warn: zigbee.0 (10516) State value to set for "zigbee.0.60a423fffeaeaf6d.link_quality" has value "255" greater than max "254"
      2021-10-20 04:52:25.040  - warn: zigbee.0 (10516) State value to set for "zigbee.0.847127fffe09b1b2.link_quality" has value "255" greater than max "254"
      2021-10-20 04:52:25.297  - warn: zigbee.0 (10516) State value to set for "zigbee.0.84fd27fffe05f053.link_quality" has value "255" greater than max "254"
      2021-10-20 04:52:25.499  - warn: zigbee.0 (10516) State value to set for "zigbee.0.84fd27fffe05e0ca.link_quality" has value "255" greater than max "254"
      2021-10-20 04:52:25.711  - warn: zigbee.0 (10516) State value to set for "zigbee.0.84fd27fffe05e2b8.link_quality" has value "255" greater than max "254"
      2021-10-20 04:52:25.844  - warn: zigbee.0 (10516) State value to set for "zigbee.0.847127fffe0a8887.link_quality" has value "255" greater than max "254"
      2021-10-20 04:52:26.054  - warn: zigbee.0 (10516) State value to set for "zigbee.0.00158d0006e18262.link_quality" has value "255" greater than max "254"
      2021-10-20 04:52:26.459  - warn: zigbee.0 (10516) State value to set for "zigbee.0.00158d0006e12fe7.link_quality" has value "255" greater than max "254"
      2021-10-20 04:52:26.636  - warn: zigbee.0 (10516) State value to set for "zigbee.0.60a423fffe620f8c.link_quality" has value "255" greater than max "254"
      2021-10-20 04:52:38.734  - warn: zigbee.0 (10516) State value to set for "zigbee.0.00158d0006e18262.link_quality" has value "255" greater than max "254"
      2021-10-20 04:52:49.184  - warn: zigbee.0 (10516) State value to set for "zigbee.0.84fd27fffe05f053.link_quality" has value "255" greater than max "254"
      2021-10-20 04:52:52.292  - warn: zigbee.0 (10516) State value to set for "zigbee.0.84fd27fffe05f053.link_quality" has value "255" greater than max "254"
      2021-10-20 04:52:55.215  - warn: zigbee.0 (10516) State value to set for "zigbee.0.84fd27fffe05f053.link_quality" has value "255" greater than max "254"
      2021-10-20 04:52:56.732  - warn: zigbee.0 (10516) State value to set for "zigbee.0.00158d0006e18262.link_quality" has value "255" greater than max "254"
      2021-10-20 04:52:58.241  - warn: zigbee.0 (10516) State value to set for "zigbee.0.84fd27fffe05f053.link_quality" has value "255" greater than max "254"
      2021-10-20 04:53:01.259  - warn: zigbee.0 (10516) State value to set for "zigbee.0.84fd27fffe05f053.link_quality" has value "255" greater than max "254"
      2021-10-20 04:53:10.357  - warn: zigbee.0 (10516) State value to set for "zigbee.0.00158d0006e12fe7.link_quality" has value "255" greater than max "254"
      2021-10-20 04:53:17.063  - warn: zigbee.0 (10516) State value to set for "zigbee.0.60a423fffeaeaf6d.link_quality" has value "255" greater than max "254"
      2021-10-20 04:53:17.261  - warn: zigbee.0 (10516) State value to set for "zigbee.0.60a423fffeaeaf6d.link_quality" has value "255" greater than max "254"
      2021-10-20 04:53:22.686  - warn: zigbee.0 (10516) State value to set for "zigbee.0.60a423fffeae66aa.link_quality" has value "255" greater than max "254"
      2021-10-20 04:53:22.711  - warn: zigbee.0 (10516) State value to set for "zigbee.0.60a423fffe61da9f.link_quality" has value "255" greater than max "254"
      2021-10-20 04:53:22.739  - warn: zigbee.0 (10516) State value to set for "zigbee.0.588e81fffed39533.link_quality" has value "255" greater than max "254"
      2021-10-20 04:53:22.789  - warn: zigbee.0 (10516) State value to set for "zigbee.0.60a423fffe6206b7.link_quality" has value "255" greater than max "254"
      2021-10-20 04:53:28.349  - warn: zigbee.0 (10516) State value to set for "zigbee.0.00158d0006e12fe7.link_quality" has value "255" greater than max "254"
      2021-10-20 04:53:30.466  - warn: zigbee.0 (10516) State value to set for "zigbee.0.60a423fffe94be6a.link_quality" has value "255" greater than max "254"
      2021-10-20 04:53:36.512  - warn: zigbee.0 (10516) State value to set for "zigbee.0.60a423fffe620f8c.link_quality" has value "255" greater than max "254"
      2021-10-20 04:53:45.945  - warn: zigbee.0 (10516) State value to set for "zigbee.0.00158d0006e18262.link_quality" has value "255" greater than max "254"
      2021-10-20 04:53:46.481  - warn: zigbee.0 (10516) State value to set for "zigbee.0.00158d0006e12fe7.link_quality" has value "255" greater than max "254"
      2021-10-20 04:53:57.646  - warn: zigbee.0 (10516) State value to set for "zigbee.0.60a423fffead7b94.link_quality" has value "255" greater than max "254"
      2021-10-20 04:53:59.269  - warn: zigbee.0 (10516) State value to set for "zigbee.0.60a423fffe61da9f.link_quality" has value "255" greater than max "254"
      2021-10-20 04:54:02.617  - info: sonoff.0 (1115) Client [iobroker.mqtt.0] connection closed: timeout
      2021-10-20 04:54:02.618  - info: mqtt.0 (1100) Disconnected from localhost: undefined
      2021-10-20 04:54:02.629  - info: sonoff.0 (1115) Client [iobroker.mqtt.0] connected with secret 1634698442629_8246
      2021-10-20 04:54:02.630  - info: mqtt.0 (1100) Connected to localhost
      2021-10-20 04:54:02.630  - info: mqtt.0 (1100) Subscribe on: "#"
      2021-10-20 04:54:02.630  - info: mqtt.0 (1100) All states published
      2021-10-20 04:54:03.744  - warn: zigbee.0 (10516) State value to set for "zigbee.0.00158d0006e18262.link_quality" has value "255" greater than max "254"
      2021-10-20 04:54:06.956  - warn: zigbee.0 (10516) State value to set for "zigbee.0.588e81fffed39533.link_quality" has value "255" greater than max "254"
      2021-10-20 04:54:16.257  - warn: zigbee.0 (10516) State value to set for "zigbee.0.60a423fffead67b7.link_quality" has value "255" greater than max "254"
      2021-10-20 04:54:16.452  - warn: zigbee.0 (10516) State value to set for "zigbee.0.60a423fffead67b7.link_quality" has value "255" greater than max "254"
      2021-10-20 04:54:16.653  - warn: zigbee.0 (10516) State value to set for "zigbee.0.60a423fffead67b7.link_quality" has value "255" greater than max "254"
      2021-10-20 04:54:21.910  - warn: zigbee.0 (10516) State value to set for "zigbee.0.00158d0006e18262.link_quality" has value "255" greater than max "254"
      2021-10-20 04:54:22.743  - warn: zigbee.0 (10516) State value to set for "zigbee.0.60a423fffe6206b7.link_quality" has value "255" greater than max "254"
      2021-10-20 04:54:22.760  - warn: zigbee.0 (10516) State value to set for "zigbee.0.588e81fffed39533.link_quality" has value "255" greater than max "254"
      2021-10-20 04:54:22.768  - warn: zigbee.0 (10516) State value to set for "zigbee.0.60a423fffe61da9f.link_quality" has value "255" greater than max "254"
      2021-10-20 04:54:22.785  - warn: zigbee.0 (10516) State value to set for "zigbee.0.60a423fffeae66aa.link_quality" has value "255" greater than max "254"
      2021-10-20 04:54:24.331  - warn: zigbee.0 (10516) Failed to ping 0x60a423fffead7808 TS0121
      2021-10-20 04:54:24.740  - warn: zigbee.0 (10516) State value to set for "zigbee.0.84fd27fffe05e2b8.link_quality" has value "255" greater than max "254"
      2021-10-20 04:54:27.770  - warn: zigbee.0 (10516) State value to set for "zigbee.0.84fd27fffe05e2b8.link_quality" has value "255" greater than max "254"
      2021-10-20 04:54:30.801  - warn: zigbee.0 (10516) State value to set for "zigbee.0.84fd27fffe05e2b8.link_quality" has value "255" greater than max "254"
      2021-10-20 04:54:33.830  - warn: zigbee.0 (10516) State value to set for "zigbee.0.84fd27fffe05e2b8.link_quality" has value "255" greater than max "254"
      2021-10-20 04:54:35.355  - warn: zigbee.0 (10516) State value to set for "zigbee.0.00158d0006e12fe7.link_quality" has value "255" greater than max "254"
      2021-10-20 04:54:36.861  - warn: zigbee.0 (10516) State value to set for "zigbee.0.84fd27fffe05e2b8.link_quality" has value "255" greater than max "254"
      2021-10-20 04:54:51.313  - warn: zigbee.0 (10516) State value to set for "zigbee.0.60a423fffe61da9f.link_quality" has value "255" greater than max "254"
      2021-10-20 04:54:53.383  - warn: zigbee.0 (10516) State value to set for "zigbee.0.00158d0006e12fe7.link_quality" has value "255" greater than max "254"
      2021-10-20 04:55:00.021  - info: host.iobroker instance system.adapter.yr.0 started with pid 10533
      2021-10-20 04:55:00.609  - info: yr.0 (10533) starting. Version 3.0.5 in /opt/iobroker/node_modules/iobroker.yr, node: v12.22.7, js-controller: 3.3.18
      2021-10-20 04:55:00.622  - info: yr.0 (10533) longitude/longitude not set, get data from system
      2021-10-20 04:55:00.633  - info: yr.0 (10533) system latitude: 53.458337 longitude: 9.956273
      2021-10-20 04:55:01.249  - warn: zigbee.0 (10516) State value to set for "zigbee.0.04cf8cdf3c7dd349.link_quality" has value "255" greater than max "254"
      2021-10-20 04:55:03.649  - info: yr.0 (10533) Data updated.
      2021-10-20 04:55:03.650  - info: yr.0 (10533) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2021-10-20 04:55:04.162  - info: host.iobroker instance system.adapter.yr.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2021-10-20 04:55:10.740  - warn: zigbee.0 (10516) State value to set for "zigbee.0.00158d0006e18262.link_quality" has value "255" greater than max "254"
      2021-10-20 04:55:11.363  - warn: zigbee.0 (10516) State value to set for "zigbee.0.00158d0006e12fe7.link_quality" has value "255" greater than max "254"
      2021-10-20 04:55:22.545  - warn: zigbee.0 (10516) State value to set for "zigbee.0.60a423fffead67b7.link_quality" has value "255" greater than max "254"
      2021-10-20 04:55:22.566  - warn: zigbee.0 (10516) State value to set for "zigbee.0.60a423fffeae66aa.link_quality" has value "255" greater than max "254"
      2021-10-20 04:55:22.577  - warn: zigbee.0 (10516) State value to set for "zigbee.0.60a423fffe6206b7.link_quality" has value "255" greater than max "254"
      2021-10-20 04:55:22.581  - warn: zigbee.0 (10516) State value to set for "zigbee.0.588e81fffed39533.link_quality" has value "255" greater than max "254"
      2021-10-20 04:55:22.596  - warn: zigbee.0 (10516) State value to set for "zigbee.0.60a423fffe61da9f.link_quality" has value "255" greater than max "254"
      2021-10-20 04:55:22.606  - warn: zigbee.0 (10516) State value to set for "zigbee.0.60a423fffeae69c6.link_quality" has value "255" greater than max "254"
      2021-10-20 04:55:28.752  - warn: zigbee.0 (10516) State value to set for "zigbee.0.00158d0006e18262.link_quality" has value "255" greater than max "254"
      2021-10-20 04:55:46.742  - warn: zigbee.0 (10516) State value to set for "zigbee.0.00158d0006e18262.link_quality" has value "255" greater than max "254"
      2021-10-20 04:55:48.892  - warn: zigbee.0 (10516) State value to set for "zigbee.0.60a423fffeae66aa.link_quality" has value "255" greater than max "254"
      2021-10-20 04:55:54.614  - warn: zigbee.0 (10516) State value to set for "zigbee.0.60a423fffe6206b7.link_quality" has value "255" greater than max "254"
      2021-10-20 04:56:00.368  - warn: zigbee.0 (10516) State value to set for "zigbee.0.00158d0006e12fe7.link_quality" has value "255" greater than max "254"
      2021-10-20 04:56:09.432  - warn: zigbee.0 (10516) State value to set for "zigbee.0.60a423fffeae69c6.link_quality" has value "255" greater than max "254"
      2021-10-20 04:56:18.539  - warn: zigbee.0 (10516) State value to set for "zigbee.0.00158d0006e12fe7.link_quality" has value "255" greater than max "254"
      2021-10-20 04:56:22.671  - warn: zigbee.0 (10516) State value to set for "zigbee.0.60a423fffe6206b7.link_quality" has value "255" greater than max "254"
      2021-10-20 04:56:22.688  - warn: zigbee.0 (10516) State value to set for "zigbee.0.588e81fffed39533.link_quality" has value "255" greater than max "254"
      2021-10-20 04:56:22.693  - warn: zigbee.0 (10516) State value to set for "zigbee.0.60a423fffeae66aa.link_quality" has value "255" greater than max "254"
      2021-10-20 04:56:22.701  - warn: zigbee.0 (10516) State value to set for "zigbee.0.60a423fffe61da9f.link_quality" has value "255" greater than max "254"
      2021-10-20 04:56:35.751  - warn: zigbee.0 (10516) State value to set for "zigbee.0.00158d0006e18262.link_quality" has value "255" greater than max "254"
      2021-10-20 04:56:36.369  - warn: zigbee.0 (10516) State value to set for "zigbee.0.00158d0006e12fe7.link_quality" has value "255" greater than max "254"
      2021-10-20 04:56:36.379  - warn: zigbee.0 (10516) State value to set for "zigbee.0.60a423fffe6206b7.link_quality" has value "255" greater than max "254"
      2021-10-20 04:56:53.744  - warn: zigbee.0 (10516) State value to set for "zigbee.0.00158d0006e18262.link_quality" has value "255" greater than max "254"
      2021-10-20 04:57:08.595  - warn: zigbee.0 (10516) State value to set for "zigbee.0.60a423fffead67b7.link_quality" has value "255" greater than max "254"
      2021-10-20 04:57:11.748  - warn: zigbee.0 (10516) State value to set for "zigbee.0.00158d0006e18262.link_quality" has value "255" greater than max "254"
      2021-10-20 04:57:18.862  - warn: zigbee.0 (10516) State value to set for "zigbee.0.00158d0006a28bce.link_quality" has value "255" greater than max "254"
      2021-10-20 04:57:22.654  - warn: zigbee.0 (10516) State value to set for "zigbee.0.60a423fffeae66aa.link_quality" has value "255" greater than max "254"
      2021-10-20 04:57:22.672  - warn: zigbee.0 (10516) State value to set for "zigbee.0.60a423fffe6206b7.link_quality" has value "255" greater than max "254"
      2021-10-20 04:57:22.683  - warn: zigbee.0 (10516) State value to set for "zigbee.0.588e81fffed39533.link_quality" has value "255" greater than max "254"
      2021-10-20 04:57:22.703  - warn: zigbee.0 (10516) State value to set for "zigbee.0.60a423fffe61da9f.link_quality" has value "255" greater than max "254"
      2021-10-20 04:57:25.364  - warn: zigbee.0 (10516) State value to set for "zigbee.0.00158d0006e12fe7.link_quality" has value "255" greater than max "254"
      2021-10-20 04:57:43.363  - warn: zigbee.0 (10516) State value to set for "zigbee.0.00158d0006e12fe7.link_quality" has value "255" greater than max "254"
      2021-10-20 04:58:00.755  - warn: zigbee.0 (10516) State value to set for "zigbee.0.00158d0006e18262.link_quality" has value "255" greater than max "254"
      2021-10-20 04:58:01.372  - warn: zigbee.0 (10516) State value to set for "zigbee.0.00158d0006e12fe7.link_quality" has value "255" greater than max "254"
      2021-10-20 04:58:15.648  - warn: zigbee.0 (10516) State value to set for "zigbee.0.60a423fffeaeaf6d.link_quality" has value "255" greater than max "254"
      2021-10-20 04:58:15.849  - warn: zigbee.0 (10516) State value to set for "zigbee.0.60a423fffeaeaf6d.link_quality" has value "255" greater than max "254"
      2021-10-20 04:58:16.053  - warn: zigbee.0 (10516) State value to set for "zigbee.0.60a423fffeaeaf6d.link_quality" has value "255" greater than max "254"
      2021-10-20 04:58:16.243  - warn: zigbee.0 (10516) State value to set for "zigbee.0.60a423fffeaeaf6d.link_quality" has value "255" greater than max "254"
      2021-10-20 04:58:16.446  - warn: zigbee.0 (10516) State value to set for "zigbee.0.60a423fffeaeaf6d.link_quality" has value "255" greater than max "254"
      2021-10-20 04:58:16.648  - warn: zigbee.0 (10516) State value to set for "zigbee.0.60a423fffeaeaf6d.link_quality" has value "255" greater than max "254"
      2021-10-20 04:58:16.877  - warn: zigbee.0 (10516) State value to set for "zigbee.0.60a423fffeaeaf6d.link_quality" has value "255" greater than max "254"
      2021-10-20 04:58:17.036  - warn: zigbee.0 (10516) State value to set for "zigbee.0.60a423fffeaeaf6d.link_quality" has value "255" greater than max "254"
      2021-10-20 04:58:17.246  - warn: zigbee.0 (10516) State value to set for "zigbee.0.60a423fffeaeaf6d.link_quality" has value "255" greater than max "254"
      2021-10-20 04:58:18.744  - warn: zigbee.0 (10516) State value to set for "zigbee.0.00158d0006e18262.link_quality" has value "255" greater than max "254"
      2021-10-20 04:58:22.627  - warn: zigbee.0 (10516) State value to set for "zigbee.0.60a423fffe6206b7.link_quality" has value "255" greater than max "254"
      2021-10-20 04:58:22.630  - warn: zigbee.0 (10516) State value to set for "zigbee.0.60a423fffeae66aa.link_quality" has value "255" greater than max "254"
      2021-10-20 04:58:22.642  - warn: zigbee.0 (10516) State value to set for "zigbee.0.60a423fffead67b7.link_quality" has value "255" greater than max "254"
      2021-10-20 04:58:22.701  - warn: zigbee.0 (10516) State value to set for "zigbee.0.60a423fffe61da9f.link_quality" has value "255" greater than max "254"
      2021-10-20 04:58:36.016  - warn: zigbee.0 (10516) State value to set for "zigbee.0.60a423fffe620f8c.link_quality" has value "255" greater than max "254"
      2021-10-20 04:58:36.760  - warn: zigbee.0 (10516) State value to set for "zigbee.0.00158d0006e18262.link_quality" has value "255" greater than max "254"
      2021-10-20 04:58:50.372  - warn: zigbee.0 (10516) State value to set for "zigbee.0.00158d0006e12fe7.link_quality" has value "255" greater than max "254"
      2021-10-20 04:58:56.640  - warn: zigbee.0 (10516) State value to set for "zigbee.0.60a423fffead7b94.link_quality" has value "255" greater than max "254"
      2021-10-20 04:58:58.397  - warn: zigbee.0 (10516) State value to set for "zigbee.0.60a423fffe61da9f.link_quality" has value "255" greater than max "254"
      2021-10-20 04:59:02.631  - info: sonoff.0 (1115) Client [iobroker.mqtt.0] connection closed: timeout
      2021-10-20 04:59:02.632  - info: mqtt.0 (1100) Disconnected from localhost: undefined
      2021-10-20 04:59:02.645  - info: sonoff.0 (1115) Client [iobroker.mqtt.0] connected with secret 1634698742644_5082
      2021-10-20 04:59:02.645  - info: mqtt.0 (1100) Connected to localhost
      2021-10-20 04:59:02.645  - info: mqtt.0 (1100) Subscribe on: "#"
      2021-10-20 04:59:02.646  - info: mqtt.0 (1100) All states published
      2021-10-20 04:59:06.319  - warn: zigbee.0 (10516) State value to set for "zigbee.0.588e81fffed39533.link_quality" has value "255" greater than max "254"
      2021-10-20 04:59:08.368  - warn: zigbee.0 (10516) State value to set for "zigbee.0.00158d0006e12fe7.link_quality" has value "255" greater than max "254"
      2021-10-20 04:59:22.595  - warn: zigbee.0 (10516) State value to set for "zigbee.0.60a423fffeae69c6.link_quality" has value "255" greater than max "254"
      2021-10-20 04:59:22.607  - warn: zigbee.0 (10516) State value to set for "zigbee.0.60a423fffeae66aa.link_quality" has value "255" greater than max "254"
      2021-10-20 04:59:22.620  - warn: zigbee.0 (10516) State value to set for "zigbee.0.60a423fffe6206b7.link_quality" has value "255" greater than max "254"
      2021-10-20 04:59:22.635  - warn: zigbee.0 (10516) State value to set for "zigbee.0.60a423fffe61da9f.link_quality" has value "255" greater than max "254"
      2021-10-20 04:59:22.661  - error: zigbee.0 (10516) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      2021-10-20 04:59:22.661  - error: zigbee.0 (10516) unhandled promise rejection: undefined
      2021-10-20 04:59:22.662  - info: zigbee.0 (10516) cleaned everything up...
      2021-10-20 04:59:22.663  - info: zigbee.0 (10516) Zigbee: disabling joining new devices.
      2021-10-20 04:59:22.873  - info: zigbee.0 (10516) terminating
      2021-10-20 04:59:22.873  - warn: zigbee.0 (10516) Terminated (UNCAUGHT_EXCEPTION): Without reason
      2021-10-20 04:59:23.415  - error: host.iobroker instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
      2021-10-20 04:59:23.416  - info: host.iobroker Restart adapter system.adapter.zigbee.0 because enabled
      2021-10-20 04:59:53.432  - info: host.iobroker instance system.adapter.zigbee.0 started with pid 10549
      2021-10-20 04:59:54.180  - info: zigbee.0 (10549) starting. Version 1.5.6 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.22.7, js-controller: 3.3.18
      2021-10-20 04:59:54.213  - info: zigbee.0 (10549) Starting Zigbee  npm ...
      2021-10-20 04:59:54.324  - info: zigbee.0 (10549) Installed Version: iobroker.zigbee@1.5.6
      2021-10-20 04:59:54.676  - error: zigbee.0 (10549) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: Input/output error, cannot open /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2454946-if00'"
      2021-10-20 04:59:54.676  - error: zigbee.0 (10549) Failed to start Zigbee
      2021-10-20 04:59:54.678  - error: zigbee.0 (10549) Error herdsman start
      2021-10-20 05:00:00.016  - info: nut.0 (10311) Scheduled restart.
      2021-10-20 05:00:00.031  - info: nut.0 (10311) terminating
      2021-10-20 05:00:00.032  - info: nut.0 (10311) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
      2021-10-20 05:00:00.042  - info: host.iobroker instance system.adapter.yr.0 started with pid 10568
      2021-10-20 05:00:00.575  - info: host.iobroker instance system.adapter.nut.0 scheduled normal terminated and will be restarted on schedule.
      2021-10-20 05:00:00.575  - info: host.iobroker Restart adapter system.adapter.nut.0 because enabled
      2021-10-20 05:00:00.631  - info: yr.0 (10568) starting. Version 3.0.5 in /opt/iobroker/node_modules/iobroker.yr, node: v12.22.7, js-controller: 3.3.18
      2021-10-20 05:00:00.642  - info: yr.0 (10568) longitude/longitude not set, get data from system
      2021-10-20 05:00:00.650  - info: yr.0 (10568) system latitude: 53.458337 longitude: 9.956273
      2021-10-20 05:00:01.587  - info: host.iobroker instance system.adapter.nut.0 started with pid 10583
      2021-10-20 05:00:02.186  - info: nut.0 (10583) starting. Version 1.5.0 in /opt/iobroker/node_modules/iobroker.nut, node: v12.22.7, js-controller: 3.3.18
      2021-10-20 05:00:03.783  - info: yr.0 (10568) Data updated.
      2021-10-20 05:00:03.784  - info: yr.0 (10568) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2021-10-20 05:00:04.053  - info: host.iobroker instance system.adapter.daswetter.0 started with pid 10598
      2021-10-20 05:00:04.293  - info: host.iobroker instance system.adapter.yr.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2021-10-20 05:00:04.510  - info: daswetter.0 (10598) starting. Version 3.0.7 in /opt/iobroker/node_modules/iobroker.daswetter, node: v12.22.7, js-controller: 3.3.18
      2021-10-20 05:00:04.524  - info: daswetter.0 (10598) Terminated (NO_ERROR): Without reason
      2021-10-20 05:00:04.679  - info: zigbee.0 (10549) Try to reconnect. 1 attempts left
      2021-10-20 05:00:04.680  - info: zigbee.0 (10549) Starting Zigbee  npm ...
      2021-10-20 05:00:04.688  - info: zigbee.0 (10549) Installed Version: iobroker.zigbee@1.5.6
      2021-10-20 05:00:05.031  - info: daswetter.0 (10598) cleaned everything up...
      2021-10-20 05:00:05.034  - info: host.iobroker instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
      2021-10-20 05:00:08.065  - info: host.iobroker instance system.adapter.ical.0 started with pid 10614
      2021-10-20 05:00:08.654  - info: ical.0 (10614) starting. Version 1.11.4 in /opt/iobroker/node_modules/iobroker.ical, node: v12.22.7, js-controller: 3.3.18
      2021-10-20 05:00:08.769  - warn: ical.0 (10614) Error reading from URL "http://11111.ics": address not found!
      2021-10-20 05:00:08.769  - warn: ical.0 (10614) Error reading "http://11111.ics": Error: getaddrinfo ENOTFOUND 11111.ics
      2021-10-20 05:00:08.769  - info: ical.0 (10614) All calenders could not be processed, Do not clean up events
      2021-10-20 05:00:13.773  - info: ical.0 (10614) Terminated (NO_ERROR): Without reason
      2021-10-20 05:00:14.285  - info: host.iobroker instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
      2021-10-20 05:00:14.379  - info: zigbee.0 (10549) Coordinator firmware version: {"type":"ConBee2/RaspBee2","meta":{"transportrev":0,"product":0,"majorrel":38,"minorrel":88,"maintrel":0,"revision":"0x26580700"}}
      2021-10-20 05:00:29.281  - info: zigbee.0 (10549) Unable to disable LED, unsupported function.
      2021-10-20 05:00:29.282  - info: zigbee.0 (10549)   --> transmitPower : normal
      2021-10-20 05:00:29.282  - info: zigbee.0 (10549) Unable to set transmit power, unsupported function.
      2021-10-20 05:00:29.287  - info: zigbee.0 (10549) Currently 48 devices are joined:
      2021-10-20 05:00:29.314  - info: zigbee.0 (10549) 0x00158d0006a25cff (addr 11939): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
      2021-10-20 05:00:29.315  - info: zigbee.0 (10549) 0x00158d0006a25f5e (addr 28949): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
      2021-10-20 05:00:29.315  - info: zigbee.0 (10549) 0x00158d0006a158d6 (addr 42775): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
      2021-10-20 05:00:29.316  - info: zigbee.0 (10549) 0x00158d0006a25fba (addr 61932): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
      2021-10-20 05:00:29.316  - info: zigbee.0 (10549) 0x00158d0002f64add (addr 40419): 404000/404005/404012 - Müller Licht Tint LED bulb GU10/E14/E27 350/470/806 lumen, dimmable, color, opal white (Router)
      2021-10-20 05:00:29.316  - info: zigbee.0 (10549) 0x00158d0006b6362c (addr 7735): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
      2021-10-20 05:00:29.317  - info: zigbee.0 (10549) 0x00158d000253bcf3 (addr 28306): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
      2021-10-20 05:00:29.317  - info: zigbee.0 (10549) 0x60a423fffead67b7 (addr 38002): TS0121_plug - TuYa 10A UK or 16A EU smart plug (Router)
      2021-10-20 05:00:29.317  - info: zigbee.0 (10549) 0x60a423fffead7b94 (addr 20417): TS0121_plug - TuYa 10A UK or 16A EU smart plug (Router)
      2021-10-20 05:00:29.318  - info: zigbee.0 (10549) 0x60a423fffeae69c6 (addr 6561): TS0121_plug - TuYa 10A UK or 16A EU smart plug (Router)
      2021-10-20 05:00:29.318  - info: zigbee.0 (10549) 0x60a423fffead7808 (addr 57884): TS0121_plug - TuYa 10A UK or 16A EU smart plug (Router)
      2021-10-20 05:00:29.318  - info: zigbee.0 (10549) 0x60a423fffeae66aa (addr 11721): TS0121_plug - TuYa 10A UK or 16A EU smart plug (Router)
      2021-10-20 05:00:29.318  - info: zigbee.0 (10549) 0x5c0272fffecca5b1 (addr 37838): TS0201 - TuYa Temperature & humidity sensor with display (EndDevice)
      2021-10-20 05:00:29.319  - info: zigbee.0 (10549) 0x847127fffe93ff10 (addr 50999): TS0601_thermostat - TuYa Radiator valve with thermostat (EndDevice)
      2021-10-20 05:00:29.319  - info: zigbee.0 (10549) 0x00158d0001e4dc27 (addr 54467): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
      2021-10-20 05:00:29.319  - info: zigbee.0 (10549) 0x60a423fffeec4734 (addr 4825): TS0601_cover - TuYa Curtain motor/roller blind motor/window pusher/tubular motor (Router)
      2021-10-20 05:00:29.320  - info: zigbee.0 (10549) 0x60a423fffe6c38a5 (addr 23860): TS0601_cover - TuYa Curtain motor/roller blind motor/window pusher/tubular motor (Router)
      2021-10-20 05:00:29.320  - info: zigbee.0 (10549) 0x60a423fffe6206b7 (addr 58684): TS0121_plug - TuYa 10A UK or 16A EU smart plug (Router)
      2021-10-20 05:00:29.320  - info: zigbee.0 (10549) 0x588e81fffed39533 (addr 40351): TS0121_plug - TuYa 10A UK or 16A EU smart plug (Router)
      2021-10-20 05:00:29.321  - info: zigbee.0 (10549) 0x60a423fffe61da9f (addr 55837): TS0121_plug - TuYa 10A UK or 16A EU smart plug (Router)
      2021-10-20 05:00:29.321  - info: zigbee.0 (10549) 0x60a423fffeaeaf6d (addr 20487): TS0121_plug - TuYa 10A UK or 16A EU smart plug (Router)
      2021-10-20 05:00:29.322  - info: zigbee.0 (10549) 0x00158d0001e4bbf8 (addr 16006): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
      2021-10-20 05:00:29.322  - info: zigbee.0 (10549) 0x847127fffe09b1b2 (addr 14721): TS0601_cover - TuYa Curtain motor/roller blind motor/window pusher/tubular motor (Router)
      2021-10-20 05:00:29.322  - info: zigbee.0 (10549) 0x5c0272fffedac780 (addr 33439): TS0601_thermostat - TuYa Radiator valve with thermostat (EndDevice)
      2021-10-20 05:00:29.323  - info: zigbee.0 (10549) 0x00158d0001e4dc2d (addr 50898): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
      2021-10-20 05:00:29.323  - info: zigbee.0 (10549) 0x00158d000253be72 (addr 24250): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
      2021-10-20 05:00:29.323  - info: zigbee.0 (10549) 0x804b50fffe1a4115 (addr 60950): TS0601_thermostat - TuYa Radiator valve with thermostat (EndDevice)
      2021-10-20 05:00:29.323  - info: zigbee.0 (10549) 0x5c0272fffecca0c2 (addr 23719): TS0201 - TuYa Temperature & humidity sensor with display (EndDevice)
      2021-10-20 05:00:29.324  - info: zigbee.0 (10549) 0x60a423fffe94be6a (addr 28120): ZTS-EU_3gang - Moes Wall touch light switch (3 gang) (EndDevice)
      2021-10-20 05:00:29.324  - info: zigbee.0 (10549) 0x04cf8cdf3c7d88b9 (addr 52133): WXCJKG13LM - Xiaomi Aqara Opple switch 3 bands (EndDevice)
      2021-10-20 05:00:29.324  - info: zigbee.0 (10549) 0x04cf8cdf3c7d8637 (addr 17967): WXCJKG13LM - Xiaomi Aqara Opple switch 3 bands (EndDevice)
      2021-10-20 05:00:29.325  - info: zigbee.0 (10549) 0x04cf8cdf3c7dd349 (addr 34793): WXCJKG13LM - Xiaomi Aqara Opple switch 3 bands (EndDevice)
      2021-10-20 05:00:29.325  - info: zigbee.0 (10549) 0x84fd27fffe05f053 (addr 41407): 404000/404005/404012 - Müller Licht Tint LED bulb GU10/E14/E27 350/470/806 lumen, dimmable, color, opal white (Router)
      2021-10-20 05:00:29.326  - info: zigbee.0 (10549) 0x84fd27fffe05e0ca (addr 45821): 404000/404005/404012 - Müller Licht Tint LED bulb GU10/E14/E27 350/470/806 lumen, dimmable, color, opal white (Router)
      2021-10-20 05:00:29.326  - info: zigbee.0 (10549) 0x84fd27fffe05e2b8 (addr 27982): 404000/404005/404012 - Müller Licht Tint LED bulb GU10/E14/E27 350/470/806 lumen, dimmable, color, opal white (Router)
      2021-10-20 05:00:29.326  - info: zigbee.0 (10549) 0x847127fffe0a8887 (addr 5595): TS0601_cover - TuYa Curtain motor/roller blind motor/window pusher/tubular motor (Router)
      2021-10-20 05:00:29.327  - info: zigbee.0 (10549) 0x5c0272fffedac4ce (addr 34728): TS0601_thermostat - TuYa Radiator valve with thermostat (EndDevice)
      2021-10-20 05:00:29.327  - info: zigbee.0 (10549) 0x00158d000253c16f (addr 59245): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
      2021-10-20 05:00:29.327  - info: zigbee.0 (10549) 0x00158d0002e3373e (addr 54462): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
      2021-10-20 05:00:29.328  - info: zigbee.0 (10549) 0x04cf8cdf3c7d8140 (addr 16100): WXCJKG13LM - Xiaomi Aqara Opple switch 3 bands (EndDevice)
      2021-10-20 05:00:29.328  - info: zigbee.0 (10549) 0x00158d0001e4d869 (addr 36634): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
      2021-10-20 05:00:29.328  - info: zigbee.0 (10549) 0x00158d0006b62576 (addr 28086): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
      2021-10-20 05:00:29.329  - info: zigbee.0 (10549) 0x00158d0006a28bce (addr 50798): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
      2021-10-20 05:00:29.329  - info: zigbee.0 (10549) 0x00158d0006b624db (addr 10039): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
      2021-10-20 05:00:29.330  - info: zigbee.0 (10549) 0x00158d0006e18262 (addr 32814): 81855 - AduroSmart ERIA smart plug (dimmer) (Router)
      2021-10-20 05:00:29.330  - info: zigbee.0 (10549) 0x00158d0006e18258 (addr 16992): 81855 - AduroSmart ERIA smart plug (dimmer) (Router)
      2021-10-20 05:00:29.330  - info: zigbee.0 (10549) 0x00158d0006e12fe7 (addr 14119): 81855 - AduroSmart ERIA smart plug (dimmer) (Router)
      2021-10-20 05:00:29.330  - info: zigbee.0 (10549) 0x60a423fffe620f8c (addr 16132): TS0121_plug - TuYa 10A UK or 16A EU smart plug (Router)
      2021-10-20 05:00:29.331  - info: zigbee.0 (10549) Zigbee started
      2021-10-20 05:00:29.348  - error: zigbee.0 (10549) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      2021-10-20 05:00:29.348  - error: zigbee.0 (10549) unhandled promise rejection: Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'
      2021-10-20 05:00:29.348  - error: zigbee.0 (10549) Error: Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'
          at Driver.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/deconz/driver/driver.js:160:28)
          at Generator.next (<anonymous>)
          at /opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/deconz/driver/driver.js:8:71
          at new Promise (<anonymous>)
          at __awaiter (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/deconz/driver/driver.js:4:12)
          at SerialPort.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/deconz/driver/driver.js:158:45)
          at SerialPort._error (/opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/stream/lib/index.js:198:14)
          at /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/stream/lib/index.js:242:12
      2021-10-20 05:00:29.348  - error: zigbee.0 (10549) Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'
      2021-10-20 05:00:29.364  - info: zigbee.0 (10549) cleaned everything up...
      2021-10-20 05:00:29.365  - info: zigbee.0 (10549) Zigbee: disabling joining new devices.
      2021-10-20 05:00:29.865  - info: zigbee.0 (10549) terminating
      2021-10-20 05:00:29.866  - warn: zigbee.0 (10549) Terminated (UNCAUGHT_EXCEPTION): Without reason
      2021-10-20 05:00:30.374  - warn: zigbee.0 (10549) get state error: Connection is closed.
      2021-10-20 05:00:30.375  - warn: zigbee.0 (10549) get state error: DB closed
      2021-10-20 05:00:30.376  - warn: zigbee.0 (10549) get state error: DB closed
      2021-10-20 05:00:30.377  - warn: zigbee.0 (10549) get state error: DB closed
      2021-10-20 05:00:30.378  - warn: zigbee.0 (10549) get state error: DB closed
      2021-10-20 05:00:30.379  - warn: zigbee.0 (10549) get state error: DB closed
      2021-10-20 05:00:30.382  - warn: zigbee.0 (10549) get state error: Connection is closed.
      2021-10-20 05:00:30.383  - warn: zigbee.0 (10549) get state error: Connection is closed.
      2021-10-20 05:00:30.384  - warn: zigbee.0 (10549) get state error: Connection is closed.
      2021-10-20 05:00:30.386  - warn: zigbee.0 (10549) get state error: Connection is closed.
      2021-10-20 05:00:30.387  - warn: zigbee.0 (10549) get state error: Connection is closed.
      2021-10-20 05:00:30.424  - error: host.iobroker instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
      2021-10-20 05:00:30.425  - info: host.iobroker Restart adapter system.adapter.zigbee.0 because enabled
      2021-10-20 05:00:30.425  - warn: host.iobroker Do not restart adapter system.adapter.zigbee.0 because restart loop detected
      2021-10-20 05:04:02.647  - info: sonoff.0 (1115) Client [iobroker.mqtt.0] connection closed: timeout
      2021-10-20 05:04:02.648  - info: mqtt.0 (1100) Disconnected from localhost: undefined
      2021-10-20 05:04:02.660  - info: sonoff.0 (1115) Client [iobroker.mqtt.0] connected with secret 1634699042659_3716
      2021-10-20 05:04:02.660  - info: mqtt.0 (1100) Connected to localhost
      2021-10-20 05:04:02.661  - info: mqtt.0 (1100) Subscribe on: "#"
      2021-10-20 05:04:02.661  - info: mqtt.0 (1100) All states published
      2021-10-20 05:09:02.662  - info: sonoff.0 (1115) Client [iobroker.mqtt.0] connection closed: timeout
      2021-10-20 05:09:02.663  - info: mqtt.0 (1100) Disconnected from localhost: undefined
      2021-10-20 05:09:02.674  - info: sonoff.0 (1115) Client [iobroker.mqtt.0] connected with secret 1634699342673_2247
      2021-10-20 05:09:02.674  - info: mqtt.0 (1100) Connected to localhost
      2021-10-20 05:09:02.674  - info: mqtt.0 (1100) Subscribe on: "#"
      2021-10-20 05:09:02.675  - info: mqtt.0 (1100) All states published
      2021-10-20 05:11:00.023  - info: host.iobroker instance system.adapter.yr.0 started with pid 10632
      2021-10-20 05:11:00.584  - info: yr.0 (10632) starting. Version 3.0.5 in /opt/iobroker/node_modules/iobroker.yr, node: v12.22.7, js-controller: 3.3.18
      2021-10-20 05:11:00.595  - info: yr.0 (10632) longitude/longitude not set, get data from system
      2021-10-20 05:11:00.604  - info: yr.0 (10632) system latitude: 53.458337 longitude: 9.956273
      2021-10-20 05:11:03.530  - info: yr.0 (10632) Data updated.
      2021-10-20 05:11:03.531  - info: yr.0 (10632) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2021-10-20 05:11:04.042  - info: host.iobroker instance system.adapter.yr.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2021-10-20 05:14:02.675  - info: sonoff.0 (1115) Client [iobroker.mqtt.0] connection closed: timeout
      2021-10-20 05:14:02.677  - info: mqtt.0 (1100) Disconnected from localhost: undefined
      2021-10-20 05:14:02.689  - info: sonoff.0 (1115) Client [iobroker.mqtt.0] connected with secret 1634699642688_6714
      2021-10-20 05:14:02.689  - info: mqtt.0 (1100) Connected to localhost
      2021-10-20 05:14:02.689  - info: mqtt.0 (1100) Subscribe on: "#"
      2021-10-20 05:14:02.690  - info: mqtt.0 (1100) All states published
      2021-10-20 05:15:00.023  - info: host.iobroker instance system.adapter.daswetter.0 started with pid 10648
      2021-10-20 05:15:00.539  - info: daswetter.0 (10648) starting. Version 3.0.7 in /opt/iobroker/node_modules/iobroker.daswetter, node: v12.22.7, js-controller: 3.3.18
      2021-10-20 05:15:00.553  - info: daswetter.0 (10648) Terminated (NO_ERROR): Without reason
      2021-10-20 05:15:01.062  - info: daswetter.0 (10648) cleaned everything up...
      2021-10-20 05:15:01.069  - info: host.iobroker instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
      2021-10-20 05:19:02.691  - info: sonoff.0 (1115) Client [iobroker.mqtt.0] connection closed: timeout
      2021-10-20 05:19:02.692  - info: mqtt.0 (1100) Disconnected from localhost: undefined
      2021-10-20 05:19:02.704  - info: sonoff.0 (1115) Client [iobroker.mqtt.0] connected with secret 1634699942704_4445
      2021-10-20 05:19:02.705  - info: mqtt.0 (1100) Connected to localhost
      2021-10-20 05:19:02.705  - info: mqtt.0 (1100) Subscribe on: "#"
      2021-10-20 05:19:02.705  - info: mqtt.0 (1100) All states published
      2021-10-20 05:22:00.023  - info: host.iobroker instance system.adapter.yr.0 started with pid 10667
      2021-10-20 05:22:00.589  - info: yr.0 (10667) starting. Version 3.0.5 in /opt/iobroker/node_modules/iobroker.yr, node: v12.22.7, js-controller: 3.3.18
      2021-10-20 05:22:00.603  - info: yr.0 (10667) longitude/longitude not set, get data from system
      2021-10-20 05:22:00.614  - info: yr.0 (10667) system latitude: 53.458337 longitude: 9.956273
      2021-10-20 05:22:03.604  - info: yr.0 (10667) Data updated.
      2021-10-20 05:22:03.605  - info: yr.0 (10667) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2021-10-20 05:22:04.116  - info: host.iobroker instance system.adapter.yr.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2021-10-20 05:24:02.707  - info: sonoff.0 (1115) Client [iobroker.mqtt.0] connection closed: timeout
      2021-10-20 05:24:02.708  - info: mqtt.0 (1100) Disconnected from localhost: undefined
      2021-10-20 05:24:02.719  - info: sonoff.0 (1115) Client [iobroker.mqtt.0] connected with secret 1634700242719_8416
      2021-10-20 05:24:02.720  - info: mqtt.0 (1100) Connected to localhost
      2021-10-20 05:24:02.720  - info: mqtt.0 (1100) Subscribe on: "#"
      2021-10-20 05:24:02.720  - info: mqtt.0 (1100) All states published
      2021-10-20 05:29:02.721  - info: sonoff.0 (1115) Client [iobroker.mqtt.0] connection closed: timeout
      2021-10-20 05:29:02.723  - info: mqtt.0 (1100) Disconnected from localhost: undefined
      2021-10-20 05:29:02.734  - info: sonoff.0 (1115) Client [iobroker.mqtt.0] connected with secret 1634700542734_6238
      2021-10-20 05:29:02.735  - info: mqtt.0 (1100) Connected to localhost
      2021-10-20 05:29:02.735  - info: mqtt.0 (1100) Subscribe on: "#"
      2021-10-20 05:29:02.735  - info: mqtt.0 (1100) All states published
      2021-10-20 05:30:00.031  - info: host.iobroker instance system.adapter.daswetter.0 started with pid 10683
      2021-10-20 05:30:00.555  - info: daswetter.0 (10683) starting. Version 3.0.7 in /opt/iobroker/node_modules/iobroker.daswetter, node: v12.22.7, js-controller: 3.3.18
      2021-10-20 05:30:00.571  - info: daswetter.0 (10683) Terminated (NO_ERROR): Without reason
      2021-10-20 05:30:01.079  - info: daswetter.0 (10683) cleaned everything up...
      2021-10-20 05:30:01.083  - info: host.iobroker instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
      2021-10-20 05:30:04.042  - info: host.iobroker instance system.adapter.ical.0 started with pid 10698
      2021-10-20 05:30:04.621  - info: ical.0 (10698) starting. Version 1.11.4 in /opt/iobroker/node_modules/iobroker.ical, node: v12.22.7, js-controller: 3.3.18
      2021-10-20 05:30:04.665  - warn: ical.0 (10698) Error reading from URL "http://11111.ics": address not found!
      2021-10-20 05:30:04.666  - warn: ical.0 (10698) Error reading "http://11111.ics": Error: getaddrinfo ENOTFOUND 11111.ics
      2021-10-20 05:30:04.666  - info: ical.0 (10698) All calenders could not be processed, Do not clean up events
      2021-10-20 05:30:09.669  - info: ical.0 (10698) Terminated (NO_ERROR): Without reason
      2021-10-20 05:30:10.180  - info: host.iobroker instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
      2021-10-20 05:33:00.022  - info: host.iobroker instance system.adapter.yr.0 started with pid 10714
      2021-10-20 05:33:00.609  - info: yr.0 (10714) starting. Version 3.0.5 in /opt/iobroker/node_modules/iobroker.yr, node: v12.22.7, js-controller: 3.3.18
      2021-10-20 05:33:00.622  - info: yr.0 (10714) longitude/longitude not set, get data from system
      2021-10-20 05:33:00.632  - info: yr.0 (10714) system latitude: 53.458337 longitude: 9.956273
      2021-10-20 05:33:03.756  - info: yr.0 (10714) Data updated.
      2021-10-20 05:33:03.757  - info: yr.0 (10714) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2021-10-20 05:33:04.269  - info: host.iobroker instance system.adapter.yr.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2021-10-20 05:34:02.737  - info: sonoff.0 (1115) Client [iobroker.mqtt.0] connection closed: timeout
      2021-10-20 05:34:02.738  - info: mqtt.0 (1100) Disconnected from localhost: undefined
      2021-10-20 05:34:02.749  - info: sonoff.0 (1115) Client [iobroker.mqtt.0] connected with secret 1634700842749_8966
      2021-10-20 05:34:02.750  - info: mqtt.0 (1100) Connected to localhost
      2021-10-20 05:34:02.750  - info: mqtt.0 (1100) Subscribe on: "#"
      2021-10-20 05:34:02.750  - info: mqtt.0 (1100) All states published
      2021-10-20 05:39:02.751  - info: sonoff.0 (1115) Client [iobroker.mqtt.0] connection closed: timeout
      2021-10-20 05:39:02.752  - info: mqtt.0 (1100) Disconnected from localhost: undefined
      2021-10-20 05:39:02.763  - info: sonoff.0 (1115) Client [iobroker.mqtt.0] connected with secret 1634701142763_3460
      2021-10-20 05:39:02.764  - info: mqtt.0 (1100) Connected to localhost
      2021-10-20 05:39:02.764  - info: mqtt.0 (1100) Subscribe on: "#"
      2021-10-20 05:39:02.764  - info: mqtt.0 (1100) All states published
      2021-10-20 05:44:00.023  - info: host.iobroker instance system.adapter.yr.0 started with pid 10730
      2021-10-20 05:44:00.620  - info: yr.0 (10730) starting. Version 3.0.5 in /opt/iobroker/node_modules/iobroker.yr, node: v12.22.7, js-controller: 3.3.18
      2021-10-20 05:44:00.633  - info: yr.0 (10730) longitude/longitude not set, get data from system
      2021-10-20 05:44:00.643  - info: yr.0 (10730) system latitude: 53.458337 longitude: 9.956273
      2021-10-20 05:44:02.766  - info: sonoff.0 (1115) Client [iobroker.mqtt.0] connection closed: timeout
      2021-10-20 05:44:02.767  - info: mqtt.0 (1100) Disconnected from localhost: undefined
      2021-10-20 05:44:02.778  - info: sonoff.0 (1115) Client [iobroker.mqtt.0] connected with secret 1634701442778_2782
      2021-10-20 05:44:02.779  - info: mqtt.0 (1100) Connected to localhost
      2021-10-20 05:44:02.779  - info: mqtt.0 (1100) Subscribe on: "#"
      2021-10-20 05:44:02.779  - info: mqtt.0 (1100) All states published
      2021-10-20 05:44:03.520  - info: yr.0 (10730) Data updated.
      Systemdata Bitte Ausfüllen
      Hardwaresystem: Intel Nuc
      Arbeitsspeicher: 8GB
      Festplattenart: SSD
      Betriebssystem: Proxmox / Ubuntu
      Node-Version: 12.22.7
      Nodejs-Version: 12.22.7
      NPM-Version: 6.14.15
      Installationsart: Skript
      Image genutzt: Nein ```
      arteck Asgothian 2 Replies Last reply Reply Quote 0
        arteck Developer Most Active @Cybork1995 last edited by
        @cybork1995 installier mal bitte von git die 1.6.4
        • Asgothian
          Asgothian Developer @Cybork1995 last edited by
          @cybork1995
          Es gab (gibt?) einen Bug in der Conbee/RaspBee Unterstützung des Zigbee Adapters der insbesondere dann auftritt wenn viele TS0121_plug Geräte im Netz eingesetzt werden. Es ist denkbar das Du davon betroffen bist.
          Mir ist es bisher (mangels Hardware) nicht gelungen den bug nachzustellen und damit dafür zu sorgen das er nicht wieder auftritt.
          Es ist denkbar das die neue Herdsman-Version die mit dem aktuellen Adapter von Github installiert wird diesen Fehler nicht mehr aufweist. Daher ist der Rat von @arteck gut und kann das Problem lösen.
          A.
          reboot loop zigbee zigbee proxmox nuc
