    4. Fehler bei SQL 1.4.2
    • sissiwup
      sissiwup last edited by
      wenn ich einen Adapter update (habe die neue Version des REGA-Adapters installiert)
      kachelt regelmäßig der SQL-Adapter ab:
      host.zotac	2017-02-11 09:09:29.342	error	instance system.adapter.sql.0 terminated with code 6 (uncaught exception)
      sql.0	2017-02-11 09:09:29.115	warn	Exception: TypeError: Cannot read property 'sql.0' of undefined
      sql.0	2017-02-11 09:09:29.114	error	at Immediate._tickCallback (internal/process/next_tick.js:98:9)
      sql.0	2017-02-11 09:09:29.114	error	at _combinedTickCallback (internal/process/next_tick.js:71:11)
      sql.0	2017-02-11 09:09:29.114	error	at listOnTimeoutNT (timers.js:255:26)
      sql.0	2017-02-11 09:09:29.114	error	at Timer.listOnTimeout (timers.js:207:5)
      sql.0	2017-02-11 09:09:29.114	error	at tryOnTimeout (timers.js:237:5)
      sql.0	2017-02-11 09:09:29.114	error	at ontimeout (timers.js:365:14)
      sql.0	2017-02-11 09:09:29.114	error	at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:746:30)
      sql.0	2017-02-11 09:09:29.114	error	at Adapter.emit (events.js:191:7)
      sql.0	2017-02-11 09:09:29.114	error	at emitTwo (events.js:106:13)
      sql.0	2017-02-11 09:09:29.114	error	at Adapter. (/opt/iobroker/node_modules/iobroker.sql/main.js:42:49)
      sql.0	2017-02-11 09:09:29.114	error	TypeError: Cannot read property 'sql.0' of undefined
      sql.0	2017-02-11 09:09:29.113	error	uncaught exception: Cannot read property 'sql.0' of undefined
      sql.0	2017-02-11 09:09:29.111	warn	Exception: TypeError: Cannot read property 'sql.0' of undefined
      sql.0	2017-02-11 09:09:29.110	error	at Immediate._tickCallback (internal/process/next_tick.js:98:9)
      sql.0	2017-02-11 09:09:29.110	error	at _combinedTickCallback (internal/process/next_tick.js:71:11)
      sql.0	2017-02-11 09:09:29.110	error	at listOnTimeoutNT (timers.js:255:26)
      sql.0	2017-02-11 09:09:29.110	error	at Timer.listOnTimeout (timers.js:207:5)
      sql.0	2017-02-11 09:09:29.110	error	at tryOnTimeout (timers.js:237:5)
      sql.0	2017-02-11 09:09:29.110	error	at ontimeout (timers.js:365:14)
      sql.0	2017-02-11 09:09:29.110	error	at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:746:30)
      sql.0	2017-02-11 09:09:29.110	error	at Adapter.emit (events.js:191:7)
      sql.0	2017-02-11 09:09:29.110	error	at emitTwo (events.js:106:13)
      sql.0	2017-02-11 09:09:29.110	error	at Adapter. (/opt/iobroker/node_modules/iobroker.sql/main.js:42:49)
      sql.0	2017-02-11 09:09:29.110	error	TypeError: Cannot read property 'sql.0' of undefined
      sql.0	2017-02-11 09:09:29.103	error	uncaught exception: Cannot read property 'sql.0' of undefined
      sql.0	2017-02-11 09:09:29.100	warn	Exception: TypeError: Cannot read property 'sql.0' of undefined
      Nach einem manuellen Neustart des SQL-Adapters ist wieder alles gut.
      Ist das in der 1.4.3 behoben? Leider zeigt er mir das Update nur in grau an, obwohl alles andere bei mir aktuell ist?
      PS: Echte MySQL-DB auf gesonderten Server.
      • apollon77
        apollon77 last edited by
        Für die neueste sql-version muss auch dein admin-Adapter aktuell sein. Dann geht das "graue" weg.
        Und du hast nen kleinen Bug gefunden 🙂 Nach dem Admin-Update SQL neu von Github installieren und testen bitte. Danke
        • sissiwup
          @apollon77:
          Und du hast nen kleinen Bug gefunden 🙂 Nach dem Admin-Update SQL neu von Github installieren und testen bitte. Danke `
          ich habe 1.16.11 vom Admin. Was neueres wird mir nicht angezeigt.
          • apollon77
            Und der js-controller muss >=0.12.0 sein. Was hast Du?
            Was kommt denn als Mouseover wenn DU über das graue Icon gehst?
            • sissiwup
              @apollon77:
              Was kommt denn als Mouseover wenn DU über das graue Icon gehst? `
              Hallo, der JS-Controller ist 0.15.3
              PS: Den SQL-Adapter habe ich manuell aktualisert.
              Der Fehler ist aber immer noch da. Nachdem ich den REGA-Adapter neu gestartet habe, stürzt der SQL-Adapter ab.
              sql.0	2017-02-17 09:40:29.986	error	TypeError: Cannot read property 'sql.0' of undefined
              sql.0	2017-02-17 09:40:29.986	error	uncaught exception: Cannot read property 'sql.0' of undefined
              sql.0	2017-02-17 09:40:29.978	warn	Exception: TypeError: Cannot read property 'sql.0' of undefined
              sql.0	2017-02-17 09:40:29.973	error	at Timer.listOnTimeout (timers.js:207:5)
              sql.0	2017-02-17 09:40:29.973	error	at tryOnTimeout (timers.js:237:5)
              sql.0	2017-02-17 09:40:29.973	error	at ontimeout (timers.js:365:14)
              sql.0	2017-02-17 09:40:29.973	error	at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:746:30)
              sql.0	2017-02-17 09:40:29.973	error	at Adapter.emit (events.js:191:7)
              sql.0	2017-02-17 09:40:29.973	error	at emitTwo (events.js:106:13)
              sql.0	2017-02-17 09:40:29.973	error	at Adapter. (/opt/iobroker/node_modules/iobroker.sql/main.js:42:49)
              sql.0	2017-02-17 09:40:29.973	error	TypeError: Cannot read property 'sql.0' of undefined
              sql.0	2017-02-17 09:40:29.965	error	uncaught exception: Cannot read property 'sql.0' of undefined
              hm-rega.0	2017-02-17 09:40:29.938	info	added/updated 89 programs
              hm-rega.0	2017-02-17 09:40:29.707	info	got 89 programs
              hm-rega.0	2017-02-17 09:40:27.975	info	added/updated rooms to enum.rooms
              hm-rega.0	2017-02-17 09:40:27.697	info	added/updated functions to enum.functions
              hm-rega.0	2017-02-17 09:40:27.243	info	added/updated 26 favorites to enum.favorites
              hm-rega.0	2017-02-17 09:40:26.747	info	time difference local-ccu 1s
              hm-rega.0	2017-02-17 09:40:26.669	info	ReGaHSS 192.168.1.11 up
              hm-rega.0	2017-02-17 09:40:25.534	info	subscribe hm-rpc.0.BidCoS-RF.50.PRESS_SHORT
              hm-rega.0	2017-02-17 09:40:25.476	info	starting. Version 1.4.3 in /opt/iobroker/node_modules/iobroker.hm-rega, node: v6.9.2
              host.zotac	2017-02-17 09:40:24.156	info	instance system.adapter.hm-rega.0 started with pid 28888
              host.zotac	2017-02-17 09:40:21.742	info	instance system.adapter.hm-rega.0 terminated with code 0 (OK)
              hm-rega.0	2017-02-17 09:40:21.636	info	terminating
              host.zotac	2017-02-17 09:40:21.582	info	stopInstance system.adapter.hm-rega.0 killing pid 6778
              host.zotac	2017-02-17 09:40:21.580	info	stopInstance system.adapter.hm-rega.0
              host.zotac	2017-02-17 09:40:21.572	info	object change system.adapter.hm-rega.0
              • apollon77
                Hast Du normal aktualisiert oder vom github aktualisiert? Musst von Githuvb holen weil erstmal nur da der Fehler gefixt ist (zum testen)
                • sissiwup
                  @apollon77:
                  Hast Du normal aktualisiert oder vom github aktualisiert? Musst von Githuvb holen weil erstmal nur da der Fehler gefixt ist (zum testen) `
                  Habe ich jetzt:
                  SQL 1.4.4
                  bei admin gibt es aber:
                  $ ./iobroker url "https://github.com/ioBroker/ioBroker.admin/tarball/master" admin
                  install https://github.com/ioBroker/ioBroker.admin/tarball/master
                  npm install https://github.com/ioBroker/ioBroker.admin/tarball/master --production --prefix "/opt/iobroker" (System call)
                  npm WARN
                   enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/buildmail/package.json'npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/commist/package.json'
                  npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/concat-stream/package.json'
                  npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/duplexify/package.json'
                  npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/follow-redirects/package.json'
                  npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/glob-stream/package.json'
                  npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/imap/package.json'
                  ERROR: host.zotac Cannot install https://github.com/ioBroker/ioBroker.admin/tarball/master: 1
                  ERROR: process exited with code 25
                  • apollon77
                    Admin brauchst DU an sich nicht vom Github. Der Bugfix von mir war in sql drin.
                    • sissiwup
                      @apollon77:
                      Admin brauchst DU an sich nicht vom Github. Der Bugfix von mir war in sql drin. `
                      Ok,
                      nach Neustart Rega kommt jetzt:
                      hm-rega.0	2017-02-17 14:31:30.565	info	hm-rega.0 added/updated 66 variables
                      zotac	2017-02-17 14:31:28.887	info	host.zotac Restart adapter system.adapter.sql.0 because enabled
                      zotac	2017-02-17 14:31:28.886	error	host.zotac instance system.adapter.sql.0 terminated with code 0 (OK)
                      hm-rega.0	2017-02-17 14:31:28.824	info	hm-rega.0 got 66 variables
                      sql.0	2017-02-17 14:31:27.924	warn	sql.0 Exception: TypeError: Cannot read property 'sql.0' of undefined
                      sql.0	2017-02-17 14:31:27.924	error	sql.0 TypeError: Cannot read property 'sql.0' of undefined at Adapter. (/opt/iobroker/node_modules/iobroker.sql/main.js:42:49) at emitTwo (events.js:106:13) at Adapter.emit (eve
                      sql.0	2017-02-17 14:31:27.924	error	sql.0 uncaught exception: Cannot read property 'sql.0' of undefined
                      sql.0	2017-02-17 14:31:27.922	warn	sql.0 Exception: TypeError: Cannot read property 'sql.0' of undefined
                      sql.0	2017-02-17 14:31:27.922	error	sql.0 TypeError: Cannot read property 'sql.0' of undefined at Adapter. (/opt/iobroker/node_modules/iobroker.sql/main.js:42:49) at emitTwo (events.js:106:13) at Adapter.emit (eve
                      sql.0	2017-02-17 14:31:27.920	error	sql.0 uncaught exception: Cannot read property 'sql.0' of undefined
                      hm-rega.0	2017-02-17 14:31:27.874	info	hm-rega.0 deleted 0 programs
                      hm-rega.0	2017-02-17 14:31:27.874	info	hm-rega.0 added/updated 89 programs
                      hm-rega.0	2017-02-17 14:31:27.553	info	hm-rega.0 got 89 programs
                      • apollon77
                        Ich kapiere es nicht …
                        Schau bitte mal auf der Platte in /opt/iobroker/node_modules/iobroker.sql/main.js in Zeile 42. Diese sollte mit dem Github Update so aussehen:
                                (obj.common.history && obj.common.history[adapter.namespace]) ||
                        Wenn nein ändere Sie mal so, dann hast Du irgendwie doch das upfdate von Github nicht bekommen (was komisch wäre). Aber erstmal egal 🙂
                        • sissiwup
                          da steht:
                          38 var adapter = utils.adapter('sql');
                               39 adapter.on('objectChange', function (id, obj) {
                               40     if (obj && obj.common && (
                               41             // todo remove history sometime (2016.08) - Do not forget object selector in io-package.json
                               42         (obj.common.history && obj.common.history[adapter.namespace]) ||
                               43         (obj.common.custom  && obj.common.custom[adapter.namespace])) &&
                               44         (obj.common.custom[adapter.namespace].enabled)
                               45     ) {
                               46         if (!sqlDPs[id] && !subscribeAll) {
                          • apollon77
                            jetzt kapier ichs nimmer … versuch nochmal nicht das beim letzten update nicht neu gestartet war und deswegen noch das alte lief ... 😉
                            ANsonsten kann ichs echt nicht mehr verstehen weil jetzt auch die Spaltennummer nicht mehr 49 sein kann ...
                            • sissiwup
                              Neustart hat er heute Nacht automatisch gemacht.
                              Restart REGA-Adapter:
                              hm-rega.0	2017-02-18 10:57:05.154	info	added/updated 66 variables
                              hm-rega.0	2017-02-18 10:57:04.640	info	got 66 variables
                              zotac	2017-02-18 10:57:04.637	info	host.zotac Restart adapter system.adapter.sql.0 because enabled
                              zotac	2017-02-18 10:57:04.636	error	host.zotac instance system.adapter.sql.0 terminated with code 6 (uncaught exception)
                              sql.0	2017-02-18 10:57:03.650	warn	Exception: TypeError: Cannot read property 'sql.0' of undefined
                              sql.0	2017-02-18 10:57:03.650	error	TypeError: Cannot read property 'sql.0' of undefined at Adapter. (/opt/iobroker/node_modules/iobroker.sql/main.js:44:27) at emitTwo (events.js:106:13) at Adapter.emit (events.js
                              sql.0	2017-02-18 10:57:03.650	error	uncaught exception: Cannot read property 'sql.0' of undefined
                              sql.0	2017-02-18 10:57:03.649	warn	Exception: TypeError: Cannot read property 'sql.0' of undefined
                              sql.0	2017-02-18 10:57:03.649	error	TypeError: Cannot read property 'sql.0' of undefined at Adapter. (/opt/iobroker/node_modules/iobroker.sql/main.js:44:27) at emitTwo (events.js:106:13) at Adapter.emit (events.js
                              sql.0	2017-02-18 10:57:03.648	error	uncaught exception: Cannot read property 'sql.0' of undefined
                              sql.0	2017-02-18 10:57:03.648	warn	Exception: TypeError: Cannot read property 'sql.0' of undefined
                              sql.0	2017-02-18 10:57:03.647	error	TypeError: Cannot read property 'sql.0' of undefined at Adapter. (/opt/iobroker/node_modules/iobroker.sql/main.js:44:27) at emitTwo (events.js:106:13) at Adapter.emit (events.js
                              sql.0	2017-02-18 10:57:03.647	error	uncaught exception: Cannot read property 'sql.0' of undefined
                              sql.0	2017-02-18 10:57:03.647	warn	Exception: TypeError: Cannot read property 'sql.0' of undefined
                              sql.0	2017-02-18 10:57:03.646	error	uncaught exception: Cannot read property 'sql.0' of undefined
                              sql.0	2017-02-18 10:57:03.646	warn	Exception: TypeError: Cannot read property 'sql.0' of undefined
                              sql.0	2017-02-18 10:57:03.646	error	TypeError: Cannot read property 'sql.0' of undefined at Adapter. (/opt/iobroker/node_modules/iobroker.sql/main.js:44:27) at emitTwo (events.js:106:13) at Adapter.emit (events.js
                              sql.0	2017-02-18 10:57:03.644	error	uncaught exception: Cannot read property 'sql.0' of undefined
                              sql.0	2017-02-18 10:57:03.644	warn	Exception: TypeError: Cannot read property 'sql.0' of undefined
                              sql.0	2017-02-18 10:57:03.644	error	TypeError: Cannot read property 'sql.0' of undefined at Adapter. (/opt/iobroker/node_modules/iobroker.sql/main.js:44:27) at emitTwo (events.js:106:13) at Adapter.emit (events.js
                              sql.0	2017-02-18 10:57:03.643	error	uncaught exception: Cannot read property 'sql.0' of undefined
                              sql.0	2017-02-18 10:57:03.643	warn	Exception: TypeError: Cannot read property 'sql.0' of undefined
                              sql.0	2017-02-18 10:57:03.643	error	TypeError: Cannot read property 'sql.0' of undefined at Adapter. (/opt/iobroker/node_modules/iobroker.sql/main.js:44:27) at emitTwo (events.js:106:13) at Adapter.emit (events.js
                              sql.0	2017-02-18 10:57:03.642	error	uncaught exception: Cannot read property 'sql.0' of undefined
                              sql.0	2017-02-18 10:57:03.344	warn	Exception: TypeError: Cannot read property 'sql.0' of undefined
                              sql.0	2017-02-18 10:57:03.318	error	TypeError: Cannot read property 'sql.0' of undefined at Adapter. (/opt/iobroker/node_modules/iobroker.sql/main.js:44:27) at emitTwo (events.js:106:13) at Adapter.emit (events.js
                              sql.0	2017-02-18 10:57:03.316	error	uncaught exception: Cannot read property 'sql.0' of undefined
                              hm-rega.0	2017-02-18 10:57:03.278	info	deleted 0 programs
                              hm-rega.0	2017-02-18 10:57:03.278	info	added/updated 89 programs
                              hm-rega.0	2017-02-18 10:57:02.944	info	got 89 programs
                              hm-rega.0	2017-02-18 10:57:00.781	info	added/updated rooms to enum.room
                              • apollon77
                                Jetzt ists auch ne andere Zeilennummer 🙂
                                Kannst Du mir einen gefallen tun (sonst muss ich weiter raten): Überleg mal welcher der hm-Datenpunkte die DU loggst der ist der am längsten loggt. Un bei den gehst DU in der "Objekte"-Ansicht auf den Stift rechts am Ende. Dort auf "Raw-Ansicht (Experten only)" und schick mir mal das JSON was Du da siehst. Dann sollte das simpel sein final zu fixen weil ich das Problem jetzt im Blick hab
                                • sissiwup
                                    "common": {
                                      "name": "HZ-01:4.ACTUAL_TEMPERATURE",
                                      "type": "number",
                                      "unit": "°C",
                                      "role": "value.temperature",
                                      "def": 0,
                                      "min": -10,
                                      "max": 56,
                                      "read": true,
                                      "write": false,
                                      "custom": {
                                        "history.0": {
                                          "enabled": true,
                                          "changesOnly": true,
                                          "minLength": 480,
                                          "maxLength": 960,
                                          "retention": 0,
                                          "debounce": 10000
                                        "sql.0": {
                                          "enabled": true,
                                          "changesOnly": false,
                                          "debounce": 1000,
                                          "retention": 63072000
                                    "native": {
                                      "CONTROL": "HEATING_CONTROL.TEMPERATURE",
                                      "ID": "ACTUAL_TEMPERATURE",
                                      "TYPE": "FLOAT",
                                      "UNIT": "�C",
                                      "DEFAULT": 0,
                                      "FLAGS": 1,
                                      "MAX": 56,
                                      "MIN": -10,
                                      "OPERATIONS": 5,
                                      "TAB_ORDER": 5
                                    "acl": {
                                      "object": 1638,
                                      "owner": "system.user.admin",
                                      "ownerGroup": "system.group.administrator",
                                      "state": 1638
                                    "_id": "hm-rpc.0.MEQ0008905.4.ACTUAL_TEMPERATURE",
                                    "type": "state"
                                  • apollon77
                                    Der kanns nicht sein … aber naja ... versuch mal neu mit der github version ... und nach install (ist dann die 1.4.5) neu startenvom sql Adapter und dann versuch nochmal
                                    • sissiwup
                                      welcher der wirklich älteste ist, weiss ich nicht, habe einen recht alten ausgewählt.
                                      Mit neuer Version 1.4.5:
                                      sql.0	2017-02-19 15:36:24.010	warn	Exception: TypeError: Cannot read property 'sql.0' of undefined
                                      sql.0	2017-02-19 15:36:24.010	error	TypeError: Cannot read property 'sql.0' of undefined at Adapter. (/opt/iobroker/node_modules/iobroker.sql/main.js:44:27) at emitTwo (events.js:106:13) at Adapter.emit (events.js
                                      sql.0	2017-02-19 15:36:24.010	error	uncaught exception: Cannot read property 'sql.0' of undefined
                                      sql.0	2017-02-19 15:36:24.009	error	uncaught exception: Cannot read property 'sql.0' of undefined
                                      sql.0	2017-02-19 15:36:24.009	warn	Exception: TypeError: Cannot read property 'sql.0' of undefined
                                      sql.0	2017-02-19 15:36:24.009	error	TypeError: Cannot read property 'sql.0' of undefined at Adapter. (/opt/iobroker/node_modules/iobroker.sql/main.js:44:27) at emitTwo (events.js:106:13) at Adapter.emit (events.js
                                      sql.0	2017-02-19 15:36:23.694	warn	Exception: TypeError: Cannot read property 'sql.0' of undefined
                                      sql.0	2017-02-19 15:36:23.694	error	TypeError: Cannot read property 'sql.0' of undefined at Adapter. (/opt/iobroker/node_modules/iobroker.sql/main.js:44:27) at emitTwo (events.js:106:13) at Adapter.emit (events.js
                                      sql.0	2017-02-19 15:36:23.693	error	uncaught exception: Cannot read property 'sql.0' of undefined
                                      sql.0	2017-02-19 15:36:23.570	warn	Exception: TypeError: Cannot read property 'sql.0' of undefined
                                      sql.0	2017-02-19 15:36:23.569	error	TypeError: Cannot read property 'sql.0' of undefined at Adapter. (/opt/iobroker/node_modules/iobroker.sql/main.js:44:27) at emitTwo (events.js:106:13) at Adapter.emit (events.js
                                      sql.0	2017-02-19 15:36:23.569	error	uncaught exception: Cannot read property 'sql.0' of undefined
                                      sql.0	2017-02-19 15:36:23.569	warn	Exception: TypeError: Cannot read property 'sql.0' of undefined
                                      sql.0	2017-02-19 15:36:23.568	error	uncaught exception: Cannot read property 'sql.0' of undefined
                                      sql.0	2017-02-19 15:36:23.568	warn	Exception: TypeError: Cannot read property 'sql.0' of undefined
                                      sql.0	2017-02-19 15:36:23.568	error	TypeError: Cannot read property 'sql.0' of undefined at Adapter. (/opt/iobroker/node_modules/iobroker.sql/main.js:44:27) at emitTwo (events.js:106:13) at Adapter.emit (events.js
                                      sql.0	2017-02-19 15:36:23.562	warn	Exception: TypeError: Cannot read property 'sql.0' of undefined
                                      sql.0	2017-02-19 15:36:23.562	error	TypeError: Cannot read property 'sql.0' of undefined at Adapter. (/opt/iobroker/node_modules/iobroker.sql/main.js:44:27) at emitTwo (events.js:106:13) at Adapter.emit (events.js
                                      sql.0	2017-02-19 15:36:23.562	error	uncaught exception: Cannot read property 'sql.0' of undefined
                                      sql.0	2017-02-19 15:36:23.561	warn	Exception: TypeError: Cannot read property 'sql.0' of undefined
                                      sql.0	2017-02-19 15:36:23.561	error	TypeError: Cannot read property 'sql.0' of undefined at Adapter. (/opt/iobroker/node_modules/iobroker.sql/main.js:44:27) at emitTwo (events.js:106:13) at Adapter.emit (events.js
                                      sql.0	2017-02-19 15:36:23.561	error	uncaught exception: Cannot read property 'sql.0' of undefined
                                      sql.0	2017-02-19 15:36:23.560	error	uncaught exception: Cannot read property 'sql.0' of undefined
                                      sql.0	2017-02-19 15:36:23.306	warn	Exception: TypeError: Cannot read property 'sql.0' of undefined
                                      sql.0	2017-02-19 15:36:23.306	error	TypeError: Cannot read property 'sql.0' of undefined at Adapter. (/opt/iobroker/node_modules/iobroker.sql/main.js:44:27) at emitTwo (events.js:106:13) at Adapter.emit (events.js
                                      sql.0	2017-02-19 15:36:23.305	error	uncaught exception: Cannot read property 'sql.0' of undefined
                                      hm-rega.0	2017-02-19 15:36:23.278	info	deleted 0 programs
                                      hm-rega.0	2017-02-19 15:36:23.278	info	added/updated 89 programs
                                      hm-rega.0	2017-02-19 15:36:22.923	info	got 89 programs
                                      hm-rega.0	2017-02-19 15:36:21.147	info	added/updated rooms to enum.rooms
                                      hm-rega.0	2017-02-19 15:36:20.872	info	added/updated functions to enum.functions
                                      hm-rega.0	2017-02-19 15:36:20.385	info	added/updated 26 favorites to enum.favorites
                                      hm-rega.0	2017-02-19 15:36:20.077	info	time difference local-ccu 0s
                                      hm-rega.0	2017-02-19 15:36:20.004	info	ReGaHSS 192.168.1.11 up
                                      hm-rega.0	2017-02-19 15:36:18.934	info	subscribe hm-rpc.0.BidCoS-RF.50.PRESS_SHORT
                                      hm-rega.0	2017-02-19 15:36:18.917	info	starting. Version 1.4.3 in /opt/iobroker/node_modules/iobroker.hm-rega, node: v6.9.2
                                      host.zotac	2017-02-19 15:36:17.848	info	instance system.adapter.hm-rega.0 started with pid 397
                                      host.zotac	2017-02-19 15:36:15.410	info	instance system.adapter.hm-rega.0 terminated with code 0 (OK)
                                      hm-rega.0	2017-02-19 15:36:15.343	info	terminating
                                      host.zotac	2017-02-19 15:36:15.287	info	stopInstance system.adapter.hm-rega.0 killing pid 19130
                                      host.zotac	2017-02-19 15:36:15.284	info	object change system.adapter.hm-rega.0
                                      host.zotac	2017-02-19 15:34:42.429	info	Update repository "default" under "conf/sources-dist.json"
                                      iobroker	2017-02-19 15:34:42.114	info	exit 0
                                      • apollon77
                                        Also irgendwie hat Install von Github nicht geklappt oder restart hat gefehlt.Zeilennnummer des Fehlers passen wieder nicht zur neuen Version 🙂
                                        Ab Zeile 40 muss es so aussehen: https://github.com/ioBroker/ioBroker.sq … ain.js#L40
                                        • sissiwup
                                          der sql-Adapter ist immer neu gestartet. Der Rest natürlich nicht.
                                          Aber nach Neustart heute Nacht kommt folgendes:
                                          admin.0	2017-02-20 11:53:06.174	info	received all states
                                          admin.0	2017-02-20 11:53:05.196	info	Subscribe on all states again
                                          admin.0	2017-02-20 11:52:33.385	info	Unsubscribe from all states, except system's, because over 3 seconds the number of events is over 200 (in last second 0)
                                          hm-rega.0	2017-02-20 11:52:30.021	info	got state values
                                          hm-rega.0	2017-02-20 11:52:25.223	info	request state values
                                          hm-rega.0	2017-02-20 11:52:25.221	info	deleted 0 variables
                                          hm-rega.0	2017-02-20 11:52:25.220	info	added/updated 66 variables
                                          hm-rega.0	2017-02-20 11:52:24.707	info	got 66 variables
                                          hm-rega.0	2017-02-20 11:52:23.758	info	deleted 0 programs
                                          hm-rega.0	2017-02-20 11:52:23.757	info	added/updated 89 programs
                                          hm-rega.0	2017-02-20 11:52:23.430	info	got 89 programs
                                          hm-rega.0	2017-02-20 11:52:22.050	info	added/updated rooms to enum.rooms
                                          hm-rega.0	2017-02-20 11:52:21.348	info	added/updated functions to enum.functions
                                          hm-rega.0	2017-02-20 11:52:20.867	info	added/updated 26 favorites to enum.favorites
                                          hm-rega.0	2017-02-20 11:52:20.517	info	time difference local-ccu 1s
                                          hm-rega.0	2017-02-20 11:52:20.439	info	ReGaHSS 192.168.1.11 up
                                          hm-rega.0	2017-02-20 11:52:19.394	info	subscribe hm-rpc.0.BidCoS-RF.50.PRESS_SHORT
                                          hm-rega.0	2017-02-20 11:52:19.377	info	starting. Version 1.4.3 in /opt/iobroker/node_modules/iobroker.hm-rega, node: v6.9.2
                                          host.zotac	2017-02-20 11:52:18.155	info	instance system.adapter.hm-rega.0 started with pid 31795
                                          host.zotac	2017-02-20 11:52:15.724	info	instance system.adapter.hm-rega.0 terminated with code 0 (OK)
                                          hm-rega.0	2017-02-20 11:52:15.652	info	terminating
                                          host.zotac	2017-02-20 11:52:15.607	info	stopInstance system.adapter.hm-rega.0 killing pid 21557
                                          host.zotac	2017-02-20 11:52:15.605	info	stopInstance system.adapter.hm-rega.0
                                          host.zotac	2017-02-20 11:52:15.598	info	object change system.adapter.hm-rega.0
                                          host.zotac	2017-02-20 11:46:03.026	info	instance system.adapter.tankerkoenig.0 terminated with code 0 (OK)
                                          • apollon77
                                            Ja das sieht doch dann nach "kein Fehler mehr "aus, oder ?! :-)))
                                            81.0k
                                            1782
